Tubeless roadbike tyres
Postby con » Mon Nov 12, 2018 4:06 pm
Have been running Schwalbe Pro 1 Tubeless on my !!! Chinese Spam Brand !!! wheels. After 2500km the puncture resistance is terrible. Does anyone have any tubeless tyre recommendations for lasting longer than Schwalbe Pro 1. Thanks
Andy.
Re: Tubeless roadbike tyres
Postby Rhubarb » Mon Nov 12, 2018 8:32 pm
- Mububban
Postby Mububban » Tue Nov 13, 2018 11:24 am
What sealant are you using? Are you confident it's always topped up and not dried out?con wrote:Hey all.
Have been running Schwalbe Pro 1 Tubeless on my !!! Spam Paradise !!! wheels. After 2500km the puncture resistance is terrible. Does anyone have any tubeless tyre recommendations for lasting longer than Schwalbe Pro 1. Thanks
Andy.
Postby Robdog » Thu Nov 15, 2018 11:37 am
I'm running down a bottle of Stan's at the moment and will probably go to Orange Seal once it's empty or stops performing.
201x S-Works Shiv
2009 Avanti Cadent Team
Postby ianK » Fri Nov 16, 2018 10:17 pm
Agree with Rhubarb - Orange Seal is excellent.
Maybe the new Conti 5000 is worth a look (I loved the 4000 when I used to run tubes!) But, atm I will stick with Pro One
Postby Rhubarb » Sun Nov 18, 2018 9:24 am
Shane was using Doc Blue. Rhubarb had bad experiences with Doc Blue too, but Rhubarb changed to Orange Seal Regular and lived happily ever after.Arbuckle23 wrote:Shane had a bad experience
- trailgumby
Postby trailgumby » Sun Nov 18, 2018 1:31 pm
Ahhh, that was funny.Arbuckle23 wrote:Shane had a bad experience
I have not yet gone to road tubeless, but my 10 years plus experience with MTB tubeless provides a few lessons.
If the bead is so stretched that you can get the tyre off without levers, that's a problem with the tyre. You're going to struggle to get it to bead up. Secondly, I *always* put the sealant in first. If you don't, you're going to gum up your valves. The valve stem needs to remain clean. The sealant helps the beading-up process.
Thirdly, he made no attempt to pre-seat the bead. I always go around the rim and try to pull the bead out onto the shoulder to minimise the air gaps. Soapy water is a last resort.
I've never had a tyre not bead up. The only time I have to use soapy water is when the bead is stretched like in the vid, which has been on old-ish (1 year+) tyres.
Postby Bennoz » Sun Nov 18, 2018 8:14 pm
LOLArbuckle23 wrote:Shane had a bad experience
Been there done that ! can totally relate
biggest and best tip i got was to pour sealant into the tire before trying to seat the bead.
+1 to everything theretrailgumby wrote:...tips
Postby madmacca » Wed Nov 21, 2018 7:52 pm
But it seemed to me from the video that it was pretty obvious that the existing tacky dried sealant was causing the beads to stick together, and that he should have removed that. Of course, if Shane were to respond that he'd had enough, and just wanted to go and ride his bike, he'd probably be right in that too.
Postby Ken Ho » Sun Jul 07, 2019 5:48 pm
Lessons, if league is an issue, use the Race version of sealant with the heavier grit. Also, when tyres are old, they puncture easy;yt and leak air a lot. I'm pretty sure I have a bunch of punctures in my current tyre, but no flats. FWIW< I've been running sealant in my tubulars too, the lighter grit version, and no flats there either, despite !! BAN ME NOW FOR SWEARING !! road shoulder littered with radial tyre wires and glass. Have not had a flat in months since using either tubeless or tubes loaded with sealant.
- Thoglette
Postby Thoglette » Sun Jul 07, 2019 8:10 pm
+1 ish - I have a bottle of sealant as my "puncture kit" for tubulars. It works.Ken Ho wrote:FWIW< I've been running sealant in my tubulars too, the lighter grit version, and no flats there either, despite !! BAN ME NOW FOR SWEARING !! road shoulder littered with radial tyre wires and glass.
- Duck!
Postby Duck! » Sun Jul 07, 2019 9:42 pm
Stan's/Doc Blue/Giant house-brand/possibly a few other labels sealant is not good for road tubeless; it's not thick & tacky enough for the high pressure. I've heard good things about Orange, but have never used it. Muc-Off is good; thicker than Stan's (and its relabelled siblings) and with a fibrous filler, it handles the high pressure of road tyres a lot better, and is more likely to seal a puncture, up to a point - there are some holes even the best sealant can't heal. Finish Line sealant is good in theory, it's thick & chunky and should fix some decent-sized holes, but the reality is it's too thick and doesn't spread around the tyre very well, significantly reducing its effectiveness. You need to thin it down with a bit of water to allow it to flow around the tyre.Rhubarb wrote:Shane was using Doc Blue. Rhubarb had bad experiences with Doc Blue too, but Rhubarb changed to Orange Seal Regular and lived happily ever after.Arbuckle23 wrote:Shane had a bad experience
- Duck!
Postby Duck! » Sun Jul 07, 2019 10:11 pm
Road tubeless is a very temperamental beast, and although helpful, MTB experience doesn't guarantee a successful setup. The main issue is that road tyres, due to being so much narrower, are not anywhere near as supple as MTB tyres, and the construction necessary for tubeless accentuates it. Further, moulding inconsistencies, packaging-induced bead kinks etc will all conspire to a poorly-fitting tyre that can be damn near impossible to seat. It's best to do a dry run, without sealant, to ensure the tyre will seat; if, as per common and usually successful MTB practise, you put the sealant in first without testing the seating, you'll fairly probably be wearing a large portion of said sealant!trailgumby wrote:Ahhh, that was funny.Arbuckle23 wrote:Shane had a bad experience
Probably the most reliable, but still not guaranteed successful method for road tubeless is to remove the valve core and use a compressor to blast air into the tyre to get it to seat. GENTLY release the pressure to minimise the risk of the beads unseating, inject sealant, refit the valve core, then inflate.
Sometimes though there is no choice but to chuck a tube in, run it for a couple of weeks and leave it in the sun as much as possible (drop the pressure a bit if it's hot) to soften and conform to the rim before going for tubeless.
- Tim
Postby Tim » Mon Jul 08, 2019 10:27 am
Tubes in road bike tyres seem easier.
- trailgumby
Postby trailgumby » Mon Jul 08, 2019 8:23 pm
Yeah, I haven't bothered with it yet. None of my road rims are tubeless.Tim wrote:Sounds like an awful lot of faffing around with different products and procedures.
- g-boaf
Postby g-boaf » Mon Jul 08, 2019 8:30 pm
My wheels can be run as tubeless, I even have the valves for that. I was tempted to go that way, but reading this post it seems like no benefit. I think I'll just avoid that altogether. Seems like a lot of pain and frustration for not much benefit.Tim wrote:Sounds like an awful lot of faffing around with different products and procedures.
- P!N20
Postby P!N20 » Tue Jul 09, 2019 10:58 am
Just think of the weight savings g-boaf!g-boaf wrote:Seems like a lot of pain and frustration for not much benefit.
- g-boaf
Postby g-boaf » Tue Jul 09, 2019 6:44 pm
Don't think there is anything to save in weight - just seems like too much fuss.P!N20 wrote:Just think of the weight savings g-boaf!g-boaf wrote:Seems like a lot of pain and frustration for not much benefit.
- Thoglette
Postby Thoglette » Tue Jul 09, 2019 7:30 pm
Where's my popcorn?g-boaf wrote:Don't think there is anything to save in weight - just seems like too much fuss.
- g-boaf
Postby g-boaf » Tue Jul 09, 2019 8:09 pm
Those tubeless tyres at the moment seem like they don't offer any real benefit, but a whole lot of fuss in having to fit them.Thoglette wrote:Where's my popcorn?g-boaf wrote:Don't think there is anything to save in weight - just seems like too much fuss.
Maybe instead of worrying about your popcorn, you could try those tubeless tyre systems out for 5000km or so and let us know how you go by the end of the year. Should keep you busy.
Postby Chris249 » Tue Jul 09, 2019 10:21 pm
Como Vivente road 2009
Principia track track 2014
Cervelo P2K TT 2003
Merida CX4 2010
Concaeio road
- g-boaf
Postby g-boaf » Tue Jul 09, 2019 11:03 pm
That’s the worry I have. I also do a lot of riding and have no desire to be stuck by the road side.Chris249 wrote:My wife's had road tubeless on two bikes and I really dislike them. They seat OK but the very prominent bead etc or some other issue with the tires makes them very hard to fit. And if you do the riding she does, including 44km of country and town commuting every day, you can easily end up with a hole too big for sealant. The tightness and mess means that putting a tube in is a nightmare, so tubeless tires have left her stranded on the roadside.
I actually did ride a bike with that setup last year. Didn’t realise it - just rode the bike and gave it back when done. I didn’t have any problems, but then the country roads I rode on were also very clean. You don’t see so much smashed glass on the roads in France.
- Thoglette
Postby Thoglette » Tue Jul 09, 2019 11:35 pm
I'll only manage that by Xmas and I've still old skool - tubes above 30mm and tubulars below that. I don't have to deal with caltrop/double-gees or hypo-low tyre pressures so I don't feel that I have a good reason to change.g-boaf wrote:Maybe instead of worrying about your popcorn, you could try those tubeless tyre systems out for 5000km or so and let us know how you go by the end of the year. Should keep you busy.
Others have more strident views. Hence the popcorn.
Postby Damo380 » Sun Jul 14, 2019 9:21 pm
However today I got a cut in the tread that was about 8mm long and went all the way through. No glue was going to seal that sucker. I put a tube in to get me home and will replace the tyre this week.
I like the lower pressure they run at as well a little bit more comfortable.
