Hi myforwik (and other Möbius users)myforwik wrote:I use a external battery back, just some 5000mahr card shaped thing with a mobile phone like battery in it. With that i can get 10 hoursjasonc wrote:as long as the ride doesn't go longer than 60 minutesInTheWoods wrote:For example I just use 720p on my mobius and I can read numberplates much further back than 4.8m.
I bought a Möbius a couple of years ago as a safety cam for my bike but stopped using it due to the short battery life and the pain of having to manually wipe the card every week. I want to give it another go with an external battery pack, my thinking is to leave the möbius 'permanently' mounted to the handlebars and remove / recharge the external battery once a week.
Am keen to hear more about what is working for you to:
- waterproof the camera. Am tossing up between Joovuu's hard case and the rubber version from möbius-actioncam.com. Either way, I want something a little more elegant than glad wrap or rhino tape!
- resolution. From the comments here, am getting the impression that the 720p mode gives the best clarity for (eg.) identifying number plates; is that right or have I misread?
- loop recording. I didn't realise the möbius could be configured to loop over old recordings, am almost positive mine stopped recording when the card got full. Is that something I configure in the möbius PC app? I suspect this feature might have been introduced after I bought mine and will require a firmware update
- card capacity. How much footage can I expect to capture on a 32gb card in loop mode?
- finally, front or rear. More of a general question but if you only have one cam and you are using it for safety, which way would you point it?
If my setup works, my next step will be to buy a second möbius and connect it to the same additional battery pack. The one I have, which is for a mobile phone, has two USB outputs so as long as the capacity is enough to power both I have a very simple solution. Also, by setting the cameras to dash cam mode (so they start recording automatically when external power is connected) I simply plug / unplug at each end of the ride, not buttons required! At least, that's the plan ...
Cheers - Sim
