Cheap, easy & solid camera mount
- Nate
Postby Nate » Wed Sep 30, 2009 8:15 pm
Here's the parts:
#1 - bracing or strapping, from bunnings/hardware store, comes in 1m lengths & costs <$5
#2 - bolt, 1/4" x whatever length you need, for oversized bars 2" works well, you'll need it threaded the FULL length of the bolt
- a nut (or small length of tube), of any diameter that fits over the bolt easily, it doesnt have to be the correct thread
#3 - some wingnuts (1/4" of course) and a few washers
Method:
- wrap the strapping around the bar to find the correct length & how much you need
- take it off the bar & cut to length, or you can just bend it back & forward a few times & it breaks easily (can be done by hands, its thin stuff)
- drill holes slightly larger than 1/4" for the bolt, on oversized bars it matches up with the existing holes
- cut some inner tube & slide it over the strapping
- assemble as below!
The nut is there to allow it to be tightened a lot more evenly, instead of just the outer most side & the washers are there for the same reason.
Its incredibly strong, easy to remove the camera (<5secs), and could take a decent load.
Assembled:
Re: Cheap, easy & solid camera mount
Postby }SkOrPn--7 » Wed Sep 30, 2009 10:12 pm
- WWBikeRider
Postby WWBikeRider » Wed Sep 30, 2009 11:13 pm
- bowie
Postby bowie » Thu Oct 01, 2009 10:08 am
- Mulger bill
Postby Mulger bill » Thu Oct 01, 2009 9:08 pm
Shaun
- Nate
Postby Nate » Fri Oct 02, 2009 10:45 am
viewtopic.php?f=12&t=19584Mulger bill wrote:Nice one MacGyver . What camera do you run?
Shaun
Camera:
http://www.dealsdirect.com.au/p/otek-we ... eo-camera/
- Spiza
Postby Spiza » Fri Oct 02, 2009 10:49 am
- Boognoss
Postby Boognoss » Sun Dec 13, 2009 7:07 pm
Just waiting for the camera to arrive (same as yours - tomorrow according to the site I ordered it from).
A busy commuting cockpit:
- Nate
Postby Nate » Mon Dec 14, 2009 9:09 am
So i had to dodgy up a new mount.
Basically you just need an "L" bracket that you glue to the front of the camera & then attach to the "Mount de Nate".
I also put some screws through it - but that meant undoing the camera case & voiding the warranty etc...
- Boognoss
Postby Boognoss » Mon Dec 14, 2009 10:09 am
I'm about to change from 23mm to 28mm tyres on the commuter so I'll see how the mount and camera go to start with. How long have you been using the camera before it cracked up?
- Nate
Postby Nate » Mon Dec 14, 2009 11:31 am
A couple of months i think - its just that the bolt only goes in about 15mm in the bottom - then there's another 80mm of weight above it, so plenty of leverage to eventually fatigue the mounting inside the case & make it eventually give way.Boognoss wrote:Bummer Nate.
Postby ksteinhoff » Tue Dec 15, 2009 9:51 pm
It's not the cheapest solution, but here's what I use to mount a video camera on my Surly Long Haul Trucker.
If it didn't bounce off on this ride, it's not going to.
One caution: make sure the 1/4 x 20 bolt you use is just the right length. If you make it too long, it'll punch right through the camera bottom. I've seen a lot of cameras ruined that way over the years.
- Nate
Postby Nate » Wed Feb 17, 2010 10:55 am
There was a clicky noise the last few days - couldnt locate it & it seems it was the mount.
It snapped at the point where the washers are pressing against the strap close to the handlebars - obvious as its the stress point.
So i'd recommend 2 layers of strap - or use a few more spacers (nuts) to reduce the angle the strap has to bend/flex at the bolt.
- Nate
Postby Nate » Fri Feb 26, 2010 3:02 pm
I'll most likely try & do a few molds to see if i can make a couple of the mounts for others if needed
Watch in 720p Versions (360 is still being up processed)
Old:
http://www.youtube.com/watch?v=Wxt8TraEJP4
New:
http://www.youtube.com/watch?v=ZL2EpVuKIdw
- blkmcs
Postby blkmcs » Wed Jul 21, 2010 11:00 am
Now my problem has been solved by the release of the Bike Pod - $12.48 from the UK with free postage.
http://www.hama.co.uk/portal/articleId* ... ction*2563
- m@
Postby m@ » Wed Jul 21, 2010 11:13 am
I hear that there are far superior models on the market...blkmcs wrote:I,ve been meaning to make one of these ever since Nate started this thread but laziness soon put a stop to my ambitions.
- blkmcs
Postby blkmcs » Wed Jul 21, 2010 11:45 am
Certainly looks more solid.m@ wrote:...I hear that there are far superior models on the market...
I didn't realise that was out there or would have sent my money in that direction, which I might still do if the Hama one turns out to be too flimsy.
Postby Missy24 » Wed Jul 21, 2010 11:49 am
- Boognoss
Postby Boognoss » Wed Jul 21, 2010 11:51 am
It's not that bad.Missy24 wrote: Bloody hell...
My roadie only has the Ayup light mount and computer. I've saved all the crap for the daily commute .
Postby Missy24 » Wed Jul 21, 2010 11:52 am
Thankfully thats a personal opinionBoognoss wrote:It's not that bad.Missy24 wrote: Bloody hell...
- Boognoss
Postby Boognoss » Wed Jul 21, 2010 12:00 pm
TouchéMissy24 wrote:Thankfully thats a personal opinionBoognoss wrote:It's not that bad.Missy24 wrote: Bloody hell...
- Christine Tham
Postby Christine Tham » Wed Jul 21, 2010 12:47 pm
Missy Missy Missy you need to take a look at my set up one day. Still trying to fit the portable DVD player in.Missy24 wrote: Bloody hell...
- Boognoss
Postby Boognoss » Wed Jul 21, 2010 1:33 pm
Thanks for the backup CT. Weight weenies we are not .Christine Tham wrote:Missy Missy Missy you need to take a look at my set up one day. Still trying to fit the portable DVD player in.Missy24 wrote: Bloody hell...
- Nate
Postby Nate » Wed Jul 21, 2010 1:53 pm
ROFL - cheers M@blkmcs wrote:Certainly looks more solid.m@ wrote:...I hear that there are far superior models on the market...
<potential advertisement>
blkmcs,
Generally the mounts that use a single bolt in the bottom of the camera are completely ineffective - you need to grip around the whole camera. They just can stop the shaking of a camera by holding it in one little point at the bottom.
Also the cameras need to be at a max of around 130g (hence the Kodak ZX1 is basically unusable - due to using AA batteries).
The other issue you need to be VERY careful with - the camera you're screwing into MUST MUST MUST have a metal frame - if you screw info a light weight plastic frame - SNAP (been there, done that), the continual flexing is just too much over time.
</potential advertisement>
There is an important downside - you must have a SPECIFIC camera for a "rigid mount" - around $100
Users browsing this forum: am50em, blizzard, Cyclophiliac
