Over-torquing non-carbon components?
Postby prox » Wed May 09, 2018 2:33 pm
I was wondering if I could get some thoughts from the community about the relevance of correctly torqued non-carbon components...
I see the obvious necessity of only tightening carbon components to the recommended torque values - if you over-tighten them, you could easily damage the carbon fibres and render your investment useless. That makes total sense to me.
But for parts made from more pliable materials like 6061 alum, or steel, or even potentially titanium, is there really such a concern with torquing components to values higher than recommended specs?
What's your opinion and/or experience on this topic?
- P!N20
Re: Over-torquing non-carbon components?
Postby P!N20 » Wed May 09, 2018 2:40 pm
Postby prox » Wed May 09, 2018 3:01 pm
How do you know?P!N20 wrote:^ The main risk is stripping threads (ask me how I know.)
- Tim
Postby Tim » Wed May 09, 2018 4:08 pm
There is a right way, and many wrong ways of doing a job.
Over-tightening parts is just plain wrong and unskilled. You risk stripped threads as mentioned, broken bolts and studs and damaged parts. An example; overtightening a front derailleur band clamp can crush the frame seat tube, especially an aluminium one, ruining it.
Non-carbon parts don't necessarily need precise torquing ie. measured with a torque wrench but they do need to be tightened correctly within a slightly more forgiving range of ham-fisted butchery.
Carbon fittings can be tightened without a torque wrench with a degree of skilled and experienced feel.
- Thoglette
Postby Thoglette » Wed May 09, 2018 4:09 pm
No.prox wrote: is there really such a concern with torquing components to values higher than recommended specs?
Traditional materials; engineering and tool design meant that a reasonably calibrated wrist would get it close enough 90% of the time.prox wrote:What's your opinion and/or experience on this topic?
It was only rare high stress (e.g. head bolts; connecting rods or bus/truck wheels) that needed enough preload to warrant cracking out the torque wrench. Or really fragile structures.
And bikes didn't have any of these.
- 10speedsemiracer
Postby 10speedsemiracer » Wed May 09, 2018 4:40 pm
+1Thoglette wrote:....It was only rare high stress (e.g. head bolts; connecting rods or bus/truck wheels) that needed enough preload to warrant cracking out the torque wrench. Or really fragile structures.
Have only ever used a torque wrench for head studs, VW cases, conrod bolts, that sort of thing. The one and only time I have used a torque wrench on a bike was installing a new BB on a carbon Bianchi Intenso, because it wasn't mine.
Postby human909 » Wed May 09, 2018 5:15 pm
Of course plenty of things are supposed to be torqued up correctly. But for the smaller stuff that is where a thoglette's 'reasonably calibrated wrist' comes into play... For average structural steel it normally is just a badly calibrated rattle gun and massively over engineered bolted connections.
That said on the other side of the fence there are plenty of mission critical needs for torque bolts reliably and accurately.
- Thoglette
Postby Thoglette » Wed May 09, 2018 5:22 pm
Oh, the fun I've had over the years having to explain "snug-tight " (as referenced in AS/NZ for tower construction) to QA inspectors who have a torque wrench fixation.human909 wrote:Of course plenty of things are supposed to be torqued up correctly.
Postby mikgit » Wed May 09, 2018 5:40 pm
- P!N20
Postby P!N20 » Thu May 10, 2018 9:06 am
Managed to strip a Shimano 600 crank thread using a crank extractor incorrectly.prox wrote:How do you know?
Still, it's pretty hard to do.
- duncan16v
Postby duncan16v » Sat May 12, 2018 9:18 am
Postby ball bearing » Sat May 12, 2018 11:14 am
Postby eeksll » Sat May 12, 2018 4:03 pm
e.g I have a alloy seatpost/collar/frame and the seatpost keeps slipping, if I keep tightening that thing up until it does not slip and the screw threads haven't been stripped, am I "A-OK"?
Postby duncanm » Sun May 13, 2018 6:07 pm
I had a handlebar that kept slipping. Had it nice and tight (4-5mm allen key, so not spanner-like tight), and one day the bolt went 'ping' on me.eeksll wrote:sounds like the OP is wandering what negative/failures occur when over tightening non-carbon components. Stripped threads seems to be one.
It had a crevice-corrosion type failure that took some time to develop. Half the break was rusty.
- Mulger bill
Postby Mulger bill » Sun May 13, 2018 8:49 pm
All good.duncanm wrote:http://nla.gov.au/nla.obj-160219588
The bloke on the ladders job is to say "CLICK" when "she's about right"...
- RonK
Postby RonK » Sun May 13, 2018 10:15 pm
Perhaps, but that degree of feel takes years of experience to acquire. Few amateur bike mechanics would have it, or be likely to develop it.Thoglette wrote:Traditional materials; engineering and tool design meant that a reasonably calibrated wrist would get it close enough 90% of the time.
Typical fasteners used on bicycles tend to be of small diameter and low tensile strength, thus are easily damaged.
For amateurs the smart thing to do is to use a torque wrench.
- Thoglette
Postby Thoglette » Mon May 14, 2018 12:42 pm
A very interesting line of thought.RonK wrote:Perhaps, but that degree of feel takes years of experience to acquire. Few amateur bike mechanics would have it, or be likely to develop it.
I've been "wrenching" (if you'll excuse the Americanism) since primary school. Paying someone to look after one's bike (or later one's car) was an unaffordable luxury, so you did it all yourself. Or walked (the shame!)
When stuck, you sought advice (and special tools) from an older relative or a neighbour. I particularly recall being coached in determining whether a bearing surface was knackered - this is something that would be very hard to pickup online.
It's a bit like picking where to go fishing; or surfing; or sailing; or knots; or firearm safety (yes, I'm that old): these things were just "common sense". Common sense which was handed down, not just by the family but the whole community.
I still have a habit of using things until they are utterly beyond repair. And as a resultsometimes get stuck by the road for the sake of $50 ($150rrp) of prevention.
- RonK
Postby RonK » Mon May 14, 2018 2:20 pm
Not a thought bubble - real world experience observed during a 5 year apprenticeship and subsequent 15 year career in the automotive industry.Thoglette wrote:A very interesting line of thought.RonK wrote:Perhaps, but that degree of feel takes years of experience to acquire. Few amateur bike mechanics would have it, or be likely to develop it.
Oh, and a torque wrench is the only wrench in my toolbox - all the rest are spanners.
Postby skyblot » Mon May 14, 2018 9:09 pm
After 40 years driving spanners in the aviation game, I know I have a habit of under-torquing fasteners, and I've also learnt that using a torque wrench is the only way to know the fastener is correctly tightened.
By all means do it by feel, but be aware that the chances of being right are not that good. Fortunately most of our bike bits are pretty tolerant and we get away with a lot.
- Thoglette
Postby Thoglette » Tue May 15, 2018 1:07 pm
Agree with all that you and RonK said. But this is the relevant punchline.skyblot wrote: Fortunately most of our bike bits are pretty tolerant and we get away with a lot.
However, don't let me discourage anyone from using RonK & Skyblot comments to justify buying (and perhaps even using) a couple of torque wrenches
- Duck!
Postby Duck! » Tue May 15, 2018 8:50 pm
Probably a lot of pros won't get it either... I'd say I have a reasonably calculated feel, but accurate, no. My calculated feel tends to be slightly under, but that's probably better than overdoing it. And for small bolts typical of bikes, it's not a calibrated wrist, but calibrated fingers, or usually just one.RonK wrote:Perhaps, but that degree of feel takes years of experience to acquire. Few amateur bike mechanics would have it, or be likely to develop it.Thoglette wrote:Traditional materials; engineering and tool design meant that a reasonably calibrated wrist would get it close enough 90% of the time.
Postby CKinnard » Tue May 15, 2018 9:31 pm
- headsets can get loose quickly and contribute to aptly named death wobble.
- loose stems = no steering.
I even saw a guy do a wheel stand and the steerer tube/fork/front wheel fell off the bike and he came down hard.
- loose handlebars = use your imagination
- pedals can come off cranks and cause serious injury, as I've seen in crit sprints.
- loose cleats and sprinting out of the saddle
- brake cables can slip out of securing bolts
- chain can jam and throw you off the bike when the front derailleur cable slips through its securing bolt.
- saddle to seat post or seat post to seat tube can fail. happened to a guy 200 meters from the start of a charity ride, and I just managed to get around him without going down myself.
if you value your life and limb, respect what bolts do, and learn how to torque to spec, and use either grease or loctite as appropriate.
yes bikes are not as complex as cars, but everything on them is so critical that any failure = catastrophic failure.
I have done a lot of touring and audax length rides over the decades, and seen non torqued to spec bolts work their way loose.
I have a habit of checking most bolts before big rides and/or every ~2000km.
At least half the loose bolts I've experienced during rides were after a LBS were the last to adjust them, so I don't trust anyone to adjust bolts correctly. Learn to do it yourself.
And components can come loose with under, correct, or over-torquing (thread stripping or otherwise weakening surrounding metal). grease or loctite can help prevent loosening with correct torque.
re carbon component specs, it's not unusual for the components to be damaged torquing them to spec. Many torque them much less.
Postby human909 » Wed May 16, 2018 7:32 am
Or just tighten the bolts appropriately without measuring torque....CKinnard wrote:ways to kill yourself by not torqueing bolts to spec:
Let's not be overdramatic here.CKinnard wrote:if you value your life and limb, respect what bolts do, and learn how to torque to spec, and use either grease or loctite as appropriate.
Lets for a second speculate on how many bikes have been built and are still being built without a way of measuring torque. Both for past and present I would say it is the majority.
It is a wonder our roads aren't littered with fatalities from imprecise torquing.
- P!N20
Postby P!N20 » Wed May 16, 2018 10:08 am
Or it just leaves the chain on the inner ring and you keep happily riding along. Catastrophic.CKinnard wrote:- chain can jam and throw you off the bike when the front derailleur cable slips through its securing bolt.
