Debuted at Interbike 2018. Time will tell whether or not we see this material make its way into bike manufacturing. Sounds pretty nifty.
It will be a couple years at least before we see mountain bike frames made from Super Magnesium, but early prototypes seem to indicate it’s on the horizon. Pricing for a Super Magnesium bike will likely come in above aluminum, but less than carbon fiber.
Allite has three different alloys, one that's designed to be welded, one that's best suited for casting, and another that's meant for forging. That means it could be used for rocker links, stems, or even a complete frame. Given the myriad of potential applications for Super Magnesium in the bike world it'll be interesting to see which, if any, manufacturers decide to give it a try.
The cost of a complete frame constructed from the material will be more expensive than aluminum, but still less expensive than carbon, and as an added bonus it can be recycled at the end of its lifespan.
https://gearjunkie.com/allite-super-magnesium
Just launched in the consumer world today, Allite Super Magnesium is a proprietary alloy created with magnesium and rare earth elements.
Originally developed for classified, military use, the material is 33% lighter than aluminum. Not only is it lightweight, the material is said to be more environmentally-friendly than either carbon or aluminum.
It claims Super Magnesium is all of the following: 50 percent lighter than titanium, 56 percent stronger than grade-one titanium, 20 times more shock-absorbing than aluminum, 21 percent stronger than 6061 aluminum, and 75 percent lighter than steel.
The resulting material weighs just 1.83 grams per cubic centimeter. It’s the lightest of all structural metals.
“It will be positioned at comparable pricing with aluminum,” Kristiansen said. “Less expensive than carbon fiber.”
Magnesium has been used regularly in the bike industry for frames, rims and for most suspension fork legs. But Allite said its material is more versatile, allowing it to accommodate various manufacturing processes including forging, extruding, die casting and welding, and it can be finished in a number of ways.
Its capacity to dampen vibrations is about 20 times higher than aluminum and it absorbs vibrations more or less on the level of carbon.
Cost-wise, Allite's alloy will be about 50 percent less expensive than carbon and on par with aluminum. Maier said Allite can work with OEs to manufacture finished product or deliver raw material and consult on the manufacturing process.
