Milligan Street / Wellington Street junction
Postby farnorth » Wed Jan 21, 2015 12:57 am
Riders travelling north on Milligan have to mingle with, or squeeze between, other vehicles whilst waiting to cross Wellington Street.
The traffic light timings are excessively long, encouraging cyclists to sneak across the pedestrian crossings when they get tired of waiting for a green light.
Advance Stop Lines could be included in the road markings and the traffic light timings shortened to reduce rider frustration.
Any other ideas?
- jaseyjase
Re: Milligan Street / Wellington Street junction
Postby jaseyjase » Wed Jan 21, 2015 2:50 am
Cant speak for the arvo, i always take the Horse Shoe.
I assume most riders filter to the front anyway as most motorist are either turning left or right?
- rolandp
Postby rolandp » Wed Jan 21, 2015 9:13 am
Milligan St - Integrated Cycling Route - Between Mounts Bay Road and Wellington St – create an integrated cycling route with associated road markings and signage to create a shared zone between motorists and cyclists. Where possible incorporate on-road cycle lanes with treatment at various intersections for bicycle priority
When - 2013-14
Suggest you write to City of Perth asking what will be done as they are a little late in delivering.
I recall sitting at these lights one morning and CEO from BWA was there. I asked the question how this junction would be better managed given that there was a number of cyclists riding through the red lights. His response surprised me, 'BWA was not there to police cyclists' - I was hopeful that it would have been more along the line of 'Yes we will work with the City to get better access into the CBD'.
- Thoglette
Postby Thoglette » Wed Jan 21, 2015 10:36 am
When is their AGM? [ah- last year was end of April. Fittingly, membership is under "shop"]rolandp wrote: and CEO from BWA was there'.
Postby Karati » Wed Jan 21, 2015 5:13 pm
1. Leaving the city there ought to be a bike box or something at the head of the lights so drivers turning can see the cyclists. Had a couple of close calls here with people turning right from the arena side not paying attention/cyclists not being visible enough. It would make it safer for the cars turning left from the city side too to get all the bikes away from that lane.
2. People running the lights/using the pedestrian crossing. I think there is two options. Because its such a big intersection they could have a combined pedestrian and bike crossing. Alternatively and probably better, get the cops down there and fine the tools who break the lights.
- Aushiker
Postby Aushiker » Wed Jan 21, 2015 6:48 pm
April 27, 2015Thoglette wrote:When is their AGM? [ah- last year was end of April. Fittingly, membership is under "shop"]rolandp wrote: and CEO from BWA was there'.
Aushiker.com
Postby wellington_street » Fri Jan 30, 2015 5:57 pm
Apart from reducing the cycle time, the following should be implemented:
- southbound left turn lane marked as 'bicycles excepted' (this allows bicycles coming out of the arena to head straight ahead into Milligan without having to queue behind right turners)
- northbound cycle lane + bike box installed between the left turn and through/right lanes
- to facilitate this, one of the southbound lanes is removed and replaced by a kerbside cycle lane
- Murray St intersection reconfigured to provide one cycle lane, one traffic lane and one right turn lane in each direction (replacing the current two traffic lanes in each direction)
- Hay St intersection reconfigured in the same layout
- Cycle lanes provided for the full length to St Georges Tce intersection
It's pretty simple stuff - the most expensive bit is moving the traffic signal poles which are in the centre of the road.
Postby worzel » Fri Jan 30, 2015 9:12 pm
Hear hear. Especially - northbound cycle lane + bike box installed between the left turn and through/right laneswellington_street wrote:I usually from Murray St into Milligan to head north and almost always get to the lights just after the green phase is finished, so I'm quite familiar with waiting here. The cycle is unnecessarily long with a lot of 'dead' time where there are no vehicles on Wellington St (this is when others get the temptation to cross on the red).
Postby Sinner » Mon Feb 02, 2015 11:16 am
wellington_street wrote:It's pretty simple stuff - the most expensive bit is moving the traffic signal poles which are in the centre of the road.
What would happen to these? Would you want them removed? If so, wouldn't you need mast arms?
Postby wellington_street » Mon Feb 02, 2015 1:41 pm
They can either be shifted onto the new median position or removed completely. Mast arms are not required for a city intersection.Sinner wrote:What would happen to these? Would you want them removed? If so, wouldn't you need mast arms?wellington_street wrote:It's pretty simple stuff - the most expensive bit is moving the traffic signal poles which are in the centre of the road.
Postby Sinner » Tue Feb 03, 2015 4:11 pm
Hmm, not sure if the powers that be at Main roads would agree. There should be a mast arm at William/The Esplanade - well at least the hole is there, but they haven't put it up yet!
Postby wellington_street » Tue Feb 03, 2015 4:34 pm
Main roads' own traffic signal guidelines state that the use of mast arms should be minimised. They are only warranted where there is a sight distance issue preventing adequate visibility of ordinary post-mounted signals. As an aside, there are no mast arms at Wellington St/Milligan St intersection.Sinner wrote:Hmm, not sure if the powers that be at Main roads would agree. There should be a mast arm at William/The Esplanade - well at least the hole is there, but they haven't put it up yet!
- rolandp
Postby rolandp » Wed Feb 04, 2015 12:00 am
Postby wellington_street » Tue Feb 10, 2015 1:50 pm
Main Roads have just installed brand new traffic signal poles in the middle of the Mounts Bay Rd shared path. Neither path nor signal heads were there before, so what is their excuse? Mast arms would be the simple solution.rolandp wrote:Mast arms were used for traffic lights when the exit to Mitchell Fay/Thomas St was rebuild in 2013. When I asked if a mast arm could also be used to replace the traffic light located in the middle of the western lane of the shared path, the answer was no. So we still have the traffic light pole that we ride around daily. I'm sure there is logic somewhere to these decisions.
Postby eldavo » Tue Feb 10, 2015 2:36 pm
Postby citywomble » Wed Feb 11, 2015 12:49 am
The problem here is compartmentalisation with little coordination between differing design elements and construction.Main Roads have just installed brand new traffic signal poles in the middle of the Mounts Bay Rd shared path. Neither path nor signal heads were there before, so what is their excuse? Mast arms would be the simple solution.
The design for the intersection and paths would provide for connectivity and proper alignment of pedestrian and cycling pathways. Unfortunately when the design gets passed to the specialist signal designers the focus is on the control of vehicles and this has to meet standards and equipment locations as viewed from the location of stop lines and kerb lines. It is all road/vehicle centric and little awareness of pedestrian/cyclist pathways. This is then further compounded when site constraints and service locations then cause further minor relocations, again vehicle centric with no awareness of the other pathways.
It's about time the design drawings included for an absolute 'clear zone' along the pedestrian/cyclist pathways where installation of any equipment street furniture is prohibited. It doesn't need a rocket scientist, only a competent designer with an awareness of the 'other' traffic that Main Roads are not really experienced with. The name, Main Roads, says it all really.
What is interesting is that obstructed pathways could, in more extreme circumstances where a wheelchair user was obstructed, be in direct conflict with the Disability Discrimination Act, which is Federal Legislation, where the HREOC or a Federal court could find Main Roads in breach of their obligations.
- Thoglette
Postby Thoglette » Wed Feb 11, 2015 4:47 am
Throw that as "potentially obstructed" and you've got something looking like matches.citywomble wrote:What is interesting is that obstructed pathways could, in more extreme circumstances where a wheelchair user was obstructed, be in direct conflict with the Disability Discrimination Act, which is Federal Legislation, where the HREOC or a Federal court could find Main Roads in breach of their obligations.
