Signs painted either side of Narrows
- flashpixx
Postby flashpixx » Wed Mar 18, 2015 12:44 am
Riding: Trek Domane SLR 7
PLEASE SLOW DOWN
Postby rodneythellama » Wed Mar 18, 2015 10:09 am
No-one can disagree with the general sentiment of encouraging safety and "politeness".
What I found particularly touching was the placement of cyclist PLEASE SLOW DOWN signs along the section of PSP between Mt Henry Bridge and Cranford Ave. The path here is quite narrow and winding, with bumps and all, leading up to the crossing at Cranford Ave where you are prone to cars speeding on and off the freeway.
I had already sent in my suggestions for what to do about the PSP here. Call me ungrateful but the gluing down of blue advisory messages was not among my hopes for action to improve the PSP.
- Timeonabike
Re: Signs painted either side of Narrows
Postby Timeonabike » Wed Mar 18, 2015 11:33 am
Postby worzel » Wed Mar 18, 2015 11:35 am
+1moosterbounce wrote:^ like
We could do with those on the Mitchell PSP. I think most pedestrians just think naughty cyclists are riding on their footpath and do not recognise it is for sharing.
Postby Robinho » Wed Mar 18, 2015 11:47 am
- bychosis
Postby bychosis » Wed Mar 18, 2015 1:04 pm
But yes, they are a good idea. The local ones are 'keep left' or 'ring when passing' i think.
- Troy C
Postby Troy C » Wed Mar 18, 2015 3:18 pm
Postby Karati » Wed Mar 18, 2015 4:36 pm
- rolandp
Postby rolandp » Wed Mar 18, 2015 11:52 pm
Haven't seen them on the Mitchell Fway PSP, or the PSP section to Subiaco, only on the south side. From this observation, you south boys need to be reminded otherwise, why install these signs?
Wonder if they could also be stuck on roads, indicating 1m matters.
Postby argybargy » Thu Mar 19, 2015 10:23 am
Is there a law that says pedestraians should be going single file, or are you speaking of general courtesy?Troy C wrote:Should be signs saying "All Users Single File" Bikes and Walkers
I run the Canning Bridge - Subiaco several mornings a week and could fill a book with expletives about lack of courtesy from people overtaking me on bikes.
* its worth noting I also ride my bike along the same section ~ albiet a much longer route when i'm on two wheels.
Postby just4tehhalibut » Thu Mar 19, 2015 11:43 am
pedestrians (or cyclists) should not be travelling two-abreast on the PSPs,
pedestrians should not walk counterflow (on the wrong side of the path, into oncoming traffic)
and although they may have 'right of way' this a legal phrasing for the protection of the slower moving folk, not to proclaim yourself prince of all you see. Perhaps as a counter to this there is an offence for pedestrians who block traffic.
I got stuck once trying to cross the Causeway during a walking event, it was however funny to watch all the walkers going two-abreast each way and the pairs not wanting to yield to each other, 'right of way' sparring. When bad habits collide.
- Lizzy
Postby Lizzy » Thu Mar 19, 2015 12:20 pm
Postby rodneythellama » Thu Mar 19, 2015 12:21 pm
2. bychosis: the signs are glued on. When they were putting them down, I can't remember seeing a peel-off backing.
3. rolandp: along the PSP in Mt Pleasant there is one with the corner lifting up, and one which was completely removed. I like your line of thinking with stickers on roads ... it would be nice to see "please slow down" signs at the PSP/Cranford Ave intersection at least.
4. Robinho: There are "please slow down" stickers at the danger points (underpasses) near Leach Hwy. But there are also "please slow down" in seemingly random places where you wouldn't need to slow down (at least I perceive no danger).
5. To my mind, the placement of "please slow down" signs at the underpasses near Leach Hwy is a condemnation of the design (it was rebuilt not so long ago). That is, the underpasses were designed too narrow, the corners were designed too tight, and the gradients are too steep.
6. I note that the problem with water run-off from the South St interchange is brought clearly into view by the new blue stickers. Pretty much every time it rains significantly, there is sand washed onto the path at the tight blind corner under the freeway on-ramp in Bateman. You can see the sand now obscures the sign.
7. While I was posing my bike for the photo, I hit my head on this sign and cut my skin. This made me wonder about the purpose of a direction sign with no directions. It's a pity that Main Roads haven't fixed the signs that they have already before putting up new ones (of questionable utility).
- Timeonabike
Postby Timeonabike » Thu Mar 19, 2015 1:12 pm
I wonder how slippery they get in the wet?
Breakfast was good - hotdogs and coffee - true breakfast of champions.
- CXCommuter
Postby CXCommuter » Fri Mar 20, 2015 9:30 am
Postby Robinho » Fri Mar 20, 2015 11:11 am
they will have started to fall off in a couple of days then, I think I've spotted about 5 on my ride by the side of the pathCXCommuter wrote:Heaps of these signs appeared yesterday afternoon along the Mitchell Freeway PSP- something blue and repetitive to look out for. I did notice also some new intersection markings on entrances to the PSP north of Glendalough Station- ie give way etc.
Postby matthecat » Fri Mar 20, 2015 12:51 pm
Postby redned » Fri Mar 20, 2015 2:35 pm
Cyclists definitely should not travel two abreast on shared paths. It breaches the road traffic code. Pedestrians have no such obligation.just4tehhalibut wrote:Others can quote the legislation but basically
Although I am sympathetic with your view on the convention, pedestrians also have no obligation to walk on the left. There is no "wrong" side of the path. Pedestrians can't create an obstruction, but walking two abreast or counterflow is not an obstruction.
Postby citywomble » Fri Mar 20, 2015 3:09 pm
In 2000 the Road Traffic Code was revised and deliberately removed an requirement for pedestrians to walk on the left on shared paths. The reason for this was that pedestrians are required to walk on the right, facing oncoming traffic, when walking on the road, to be consistent they are permitted to walk on the right facing oncoming bike traffic on shared paths although many do walk left.
Essentially shared paths are footpaths which cyclists 'may' share while pedestrians are merely 'encouraged' to share 'their' path. To take the Dutch concept of bicycle roads where cars are allowed to share, the cyclist only rides as the 'guest'.
For this reason cyclists have got to start campaigning for their own BIKE paths. Shared paths are a poor substitute for faster cyclist facilities because they belong to pedestrians not cyclists. And that what the law says.
- ColinOldnCranky
Postby ColinOldnCranky » Sun Mar 22, 2015 8:23 pm
ru serious? Why would a pair of walkers want to walk in company one behind the other?Troy C wrote:Should be signs saying "All Users Single File" Bikes and Walkers
People have been walking together for a hundred thousand years. Why should they lose one of lifes simple uncomplicated pleasures just because technology gives us bikes and you and I take up riding?
Peds in pairs on paths are seldom a problem. I wish I could say the same about riders.
- Troy C
Postby Troy C » Mon Mar 23, 2015 2:04 pm
Why, because the Dual Use Path is not wide enough.
I understand your point, but The modern PSP does not accommodate .
Postby Robinho » Mon Mar 23, 2015 2:25 pm
playing devils advocate, most PSP's I see and ride on are wide enough to accommodate 2 people walking or jogging side by side. Yes they take up a full "lane" but in that case I need to move over to safely pass where there is sufficient space and visibility or slow until there is. Same as you'd expect a car to do behind you on the road. Most of the time of you do that, and/or ring a bell they move into single file or take a step onto the grass, very few make it difficult. It's not ideal, and I'd far rather a path which was dedicated to bikes to allow uninterrupted progress, but it's a startTroy C wrote:Yes I am serious
- Tornado
Postby Tornado » Mon Mar 23, 2015 3:35 pm
Although I don't think it's allowed, I have no issue with riders two abreast either if they can keep inside the dividing line.
2015 Specialized Tarmac
2012 Avanti Giro3
Postby worzel » Tue Mar 24, 2015 11:32 am
-They are placed only about 5m from the side paths so by the time a cyclists sees them and processes what they say they will be 50m past the junction so presumably they are aimed more at peds?
-There was nothing within a couple of km either side of Greenwood station which is one of the worst spots for swerving around people getting off the train with their head still in a book / smartphone. (Hopefully that is because they are going to resurface it - wishful thinking?)
-There were cones / a large yellow sign telling pedestrians (no mention of cyclists) to be cautious which were almost entirely blocking the path just north of Warwick station - I assume that is because another sign is to be installed there?
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
