Perth Cycle Ring
- rolandp
Perth Cycle Ring
Postby rolandp » Sat May 30, 2015 11:39 am
The Perth Cycle Ring report sets out a high-level vision for the next stage of growth for the Perth bike lane network. It has been written and endorsed by a diverse group of local community organisations.
Make sure you click on the PDF link to see their suggestion, as the web site is currently just a holding page.
Thoughts? Would you use a cycling ring route which includes Stirling, Fremantle and Curtin?
I love that someone/some group is thinking of alternatives.
Re: Perth Cycle Ring
Postby cj7hawk » Sat May 30, 2015 1:17 pm
There is a massive amount of roadworks in this area, all made bicycle unfriendly. It's great for cars, but impossibly dangerous for cyclists - because all the roads connecting the suburbs in this area are high speed ( eg, 100 kph ) with no cycling paths - There's a few here and there, but Roe Hwy really ensures that the area will remain cycling-unfriendly for a long time... It badly needs a good cycle path connecting up it's entire length - Unlike other highways in the region, it's pretty major and there's not a lot of choices of other paths around it -
David
Postby Baalzamon » Sat May 30, 2015 1:24 pm
http://gatewaywa.com.au/assets/Cycle-Ma ... l-2015.pdf is what they are looking at doing.
Postby just4tehhalibut » Sat May 30, 2015 1:26 pm
You'd get a better traffic solution by lobbying for a ring public rail line around Perth, as opposed to the rail lines all radiating out, and usually what follows the building of a new rail line is the building of adjacent bike paths. The new rail line would get those people out of cars who wouldn't necessarily want to cycle to work.
- Thoglette
Re: Perth Cycle Ring - who the hell are they?
Postby Thoglette » Sat May 30, 2015 1:51 pm
+ several.just4tehhalibut wrote:The usual etiquette is to put a name on the report and if it is endorsed then list those organisations involved.
Frankly a link to a pseudo anonymous "wix" is going to go way down my list of "is it worth even clicking?"
Who the hell is it?
+ several morejust4tehhalibut wrote:You'd get a better traffic solution by lobbying for a ring public rail line around Perth,
Postby cj7hawk » Sat May 30, 2015 2:19 pm
Thank you Baalzamon - That's useful information -Baalzamon wrote:Cj7hawk it might pay to have a look at the gateway project which is doing all the roadworks and associated bikepaths
Though it appears to stop at Berkshire road Hopefully at some stage they'll decide there's a justification for a path all the way up Roe to Midland -
David -
- Thoglette
Postby Thoglette » Sat May 30, 2015 3:33 pm
Logos from BTA, Bike Doctor and a bunch of local (mostly eastern) suburb groups. No authors listed, no publication date, no funding listed, seems to be published on 1st March by a shadowy organisation called the "Vic Park Transition Network" (facebook, since Feb 2014, googlegroups since June 2013). Wikipedia has some information on Transition TownsThoglette wrote:Who the hell is it?
It highlights some (low cost) design techniques not utilised in Perth.
Proposes on road infrastructure following the 98/99 bus routes, which isn't a bad thing.
- ColinOldnCranky
Postby ColinOldnCranky » Sat May 30, 2015 10:05 pm
Justification will presumably be on the basis of estimates of takeup. The area you are concerned with is not as flat as (nor probably as populated as) most of the perth metro so I can understand it being given the back seat. Even relatively affordable cycling infrastructure will be rationalised economically.cj7hawk wrote:Thank you Baalzamon - That's useful information -Baalzamon wrote:Cj7hawk it might pay to have a look at the gateway project which is doing all the roadworks and associated bikepaths
David -
Now I see why you are so supportive of powered bikes.
Postby cj7hawk » Sun May 31, 2015 11:55 am
Lots of hills there - Though I referring to the flat areas from the base of the hill to the airport as well - What little cycling infrastructure that does exist there is not connected to anything, so has no real commute value whatsoever... To travel between two adjacent suburbs, you need a car.ColinOldnCranky wrote:Justification will presumably be on the basis of estimates of takeup. The area you are concerned with is not as flat as (nor probably as populated as) most of the perth metro so I can understand it being given the back seat. Even relatively affordable cycling infrastructure will be rationalised economically.cj7hawk wrote:Thank you Baalzamon - That's useful information -Baalzamon wrote:Cj7hawk it might pay to have a look at the gateway project which is doing all the roadworks and associated bikepaths
David -
If you look at the Green's bicycle map, the issue becomes apparent.
Not only is the bicycle infrastructure through that area unconnected, there are no local roads either - Roe Highway is the only connecting road - So all of these suburbs are basically "cycling islands" - they are cut-off from the rest of WA. I tried to explore down there once or twice... There's no way to get there, because the highway becomes an effective barrier that cycles cannot legally pass and there are no back-roads either - All access to these suburbs was radial from the city - and now they are connected by a highway.
There is about 50m of cycling infrastructure on Roe Hwy in this region, but it's illegal to get to it by bicycle.
It's great for cars, but cannot ever be used by bicycle...
This is all in part why I support powered cycling so much, and there's community advocacy as well, not to mention I like electric and electric hybrid vehicles and have been wanting to put an engine on my bike since I was 6...
But mainly it's because I'm old, fat and lazy.
I keep looking for a suitable cycling advocacy group to join, but they are slow to catch on to new forms of cycling and groups within those new areas haven't spontaneously formed yet -
Regards
David
- Aushiker
Postby Aushiker » Sun May 31, 2015 12:44 pm
Aushiker.com
Postby nachoman » Sun May 31, 2015 3:06 pm
This link from the local newspaper has some more detailsThoglette wrote:Frankly a link to a pseudo anonymous "wix" is going to go way down my list of "is it worth even clicking?"
Who the hell is it?
- Thoglette
Postby Thoglette » Sun May 31, 2015 4:38 pm
Thanks. Gold. @aushiker - author details within.nachoman wrote:This link from the local newspaper has some more details
Postby dmwill » Mon Jun 01, 2015 1:48 am
Although it's not a deal breaker, If there is a house I like, I try to see if there are any safe cycling routes to that would get me to the Freeway/City/Coast, etc.
- Aushiker
Postby Aushiker » Thu Jun 04, 2015 8:22 pm
Thanks. Still not that informed but having not heard of either of the groups mentioned.Thoglette wrote:Thanks. Gold. @aushiker - author details within.nachoman wrote:This link from the local newspaper has some more details
Aushiker.com
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
