Bullock barn find Resto!
reeva65
Postby reeva65 » Thu Sep 26, 2013 2:05 pm
daacha
Re: Bullock barn find Resto!
Postby daacha » Thu Sep 26, 2013 3:25 pm
Wow friggin wow !!!
rangersac
Postby rangersac » Thu Sep 26, 2013 3:58 pm
Awesome!
De Rosa Macro | Intense Primer | Wayward Cape York | Cotic Rocket
Derny Driver
Postby Derny Driver » Thu Sep 26, 2013 4:05 pm
Beautiful job!
rebilda
Postby rebilda » Thu Sep 26, 2013 4:16 pm
Looks great!
.........have you perhaps got one of the crank, cotter pins in, around the wrong way?
My Garage = Restored Paino - the "Fixie" - Giant Trance X2 - Azzurri Forza Pro Di2 - GT Avalanche 1 & 2
reeva65
Postby reeva65 » Thu Sep 26, 2013 4:53 pm
Cotter pins?? im not sure.. will it make a difference ?
WyvernRH
Postby WyvernRH » Thu Sep 26, 2013 5:12 pm
reeva65 wrote:Cotter pins?? im not sure.. will it make a difference ?
Yup, if cotter pins are not put in from opposing directions the cranks will not line up correctly.
So, when viewed from top with the cranks vertical, the left hand crank has the nut on the pin facing back and the right hand crank has the nut on the pin facing forward.
Doesn't really matter which side faces which way actually as long as they are in opposite directions.
From the pictures your cranks are out of line so the first suggestion is that both pins are in from the same side.
If the pins are in correctly then you may have non-matched cotter pins or you may have to file the cotter pin flats to line them up.
rebilda
Postby rebilda » Thu Sep 26, 2013 5:14 pm
Sure does!
Looking at the photo, the crank arms seem just a little out of line with each other. Could be the angle the shot was taken from, but if both cotter pins are inserted in the same direction, this will cause the cranks to look like the arms of a clock, at 5 O'clock. To correct this, remove one of the cotter pins and make sure it is then inserted in the opposite direction, to the pin on the opposing crank arm. The cranks should now be at 6 O'clock :)
....does that make sense?
Woah...beaten to the punch by wyvernRH :)
reeva65
Postby reeva65 » Thu Sep 26, 2013 6:52 pm
Makes perfect scenes..i checked it out and you were right. It was about 10 or so degrees out. A little filing and it slipped straight in.
Thank you
Postby ldrcycles » Thu Sep 26, 2013 7:08 pm
Strong candidate for restoration of the year! I can't believe that's the same bike as in the original thread, I would never have thought it would clean up so well, it's absolutely magnificent. Fantastic work reeva :D .
Road Record Association of Australia
reeva65
Postby reeva65 » Thu Sep 26, 2013 7:42 pm
i tried to clean it up as best as i could but the nickel was too far gone.. I actually got it re nickelled.
WyvernRH
Postby WyvernRH » Thu Sep 26, 2013 9:36 pm
ldrcycles wrote:Strong candidate for restoration of the year! I can't believe that's the same bike as in the original thread, I would never have thought it would clean up so well, it's absolutely magnificent. Fantastic work reeva :D .
Yes +1 to that.
Meant to add that it was a great resto into the cotter pin thing but forgot.... :roll: Nice combo of patina and new stuff.
iestyn
Postby iestyn » Fri Sep 27, 2013 2:38 pm
If you don't mind us asking - how much does it cost to get an old frame renickled?
FXST01
Postby FXST01 » Fri Sep 27, 2013 3:27 pm
Sweeeeeeeeet
reeva65
Postby reeva65 » Fri Sep 27, 2013 3:33 pm
iestyn wrote:If you don't mind us asking - how much does it cost to get an old frame renickled?
it wasnt cheap... cost me $300.. More for a labour of love than a sound financial decision.
Imwit
Postby Imwit » Fri Sep 27, 2013 4:45 pm
Looks awesome.
worth it i reckon
Imwit
Postby Imwit » Fri Sep 27, 2013 4:46 pm
Imwit wrote:Looks awesome.
reeva65 wrote: it wasnt cheap... cost me $300.. More for a labour of love than a sound financial decision.
worth it i reckon
Postby ldrcycles » Fri Sep 27, 2013 6:33 pm
worth it i reckon
+1, and that sounds like a pretty good deal to me, I know nickel plating isn't as expensive as chrome but a set of cranks and a stem cost me $120.
WyvernRH
Postby WyvernRH » Fri Sep 27, 2013 9:02 pm
worth it i reckon
Also +1
That's a pretty good price for what looks like a good job. A basic good paint job is up there in the $200-250 mark as a starter.
