Why SS/Fixie
- AlexHuggs
Why SS/Fixie
Postby AlexHuggs » Wed Aug 26, 2015 7:35 am
- bychosis
Re: Why SS/Fixie
Postby bychosis » Wed Aug 26, 2015 7:45 am
More conversations here
I like the simplicity, extra workout and clean look of the bike.
Re: Why SS/Fixie
Postby Gunlock » Wed Aug 26, 2015 8:53 am
my SS commuter has led a very tough life without a lot of love and it just keeps on working.
Re: Why SS/Fixie
Postby clint66 » Wed Aug 26, 2015 12:49 pm
I commute about 50kms a day on my single speed. I live in Perth, so not particularly hilly, maybe 300-400m a day in elevation. But some of the hills are a challenge and so are the flats at times. I think its great fun to be on the cycle path and look behind to see that you are towing 3 or 4 guys with gears.
Generally though, I do think it has build a bit more strength in my legs from doing it. Plus it does teach you to carry a broader range of cadence.
We had organised a few single speed/fixie only group rides at my cycling club. We didnt get huge turn outs, maybe 10-15 each time. But doing a 50km group ride on a SS changes the dynamics of the group ride and does make for a fun ride. We even included the sprint and hill climb points.
- AlexHuggs
Re: Why SS/Fixie
Postby AlexHuggs » Wed Aug 26, 2015 2:38 pm
Re: Why SS/Fixie
Postby dalai47 » Wed Aug 26, 2015 4:04 pm
- jaseyjase
Re: Why SS/Fixie
Postby jaseyjase » Wed Aug 26, 2015 4:14 pm
As mentioned above, simplicity, maintenance, clean look as well as strength/cadence training are all good reasons enough!
Of course having a relatively flat geography helps alot too!
- Thoglette
Re: Why SS/Fixie
Postby Thoglette » Wed Aug 26, 2015 4:23 pm
Good choice - until your knees harden up. Plus commuting is different to "going for a ride" - some days you're full of beans, some days full of flu. Different gear ratios are applicable!AlexHuggs wrote:I'm in Perth. Slightly shorter commute (when I start - a few medical complications) and less elevation. But I think I'll still start with a geared bike. Not great knees and not fit.
As usual, Sheldon had something to say
- nickobec
Re: Why SS/Fixie
Postby nickobec » Wed Aug 26, 2015 7:13 pm
I have a singlespeed in my stable, I use to commute regularly on it. Went from 52/19 to 52/16 over a couple years.
Still ride it, not as often, because I got a little more serious about my training and like to track my TSS ( I have a powertap wheel for my geared bikes)
The Good of single speeds- fun to ride, easy, simple, get you legs working at different cadences, CCR.
The Bad, gearing that works for the ride in, does not work into 30kph+ Freo Doctor on the way home, you get stronger (I did) or catch the train home (did that too). Also gearing for the 32km on the bike path with one intersection, does not work well in the CBD, ie stopped at the lights at Barrack and Wellington and having to climb the Beaufort Street bridge
First commuter, go geared, after a while try a singlespeed or fixed to see if it works for you.
- AlexHuggs
- nickobec
Re: Why SS/Fixie
Postby nickobec » Wed Aug 26, 2015 11:23 pm
42kms one way, depending on weather, training plan for the day, mood, traffic and bike chosenAlexHuggs wrote:Wow. How long does 80km take you?
Currently anywhere between 1:12 and 1:40
When I first started riding Calista to West Perth
90 minutes to ride, drive or catch a bus.
Took close to 120 minutes on return trip into the headwind, instead of 90 minutes driving or bus,
Which meant for 30 minute investment got 3:30 of aerobic workout.
- Cycleops70
Re: Why SS/Fixie
Postby Cycleops70 » Thu Aug 27, 2015 12:13 am
It's just good simple cheap fun.
Shame I live at the top of a hill really.
It is hard work, but feels smooth & compelling.
For the first couple of Km I'll forget it's fixed & almost get ejected over the bars, but then it's all good.
Re: Why SS/Fixie
Postby mitchj » Mon Aug 31, 2015 9:38 pm
Re: Why SS/Fixie
Postby clint66 » Tue Sep 01, 2015 6:18 pm
Plus depending on your frame (horizontal/semi vertical) dropouts, changing gear ratios is a little difficult. Mine is an old steel frame with semi vertical drop outs. I just don't have quite enough adjustment on some ratios. I have been contemplating running a chain tensioner, but I don't like the look of them. I just run it with an overly slack chain. I get a lot of comments about my chain being loose, but it has never come off.
Also trap for young players.... an 8 speed chain is different to a single speed chain.
- Mulger bill
Re: Why SS/Fixie
Postby Mulger bill » Tue Sep 01, 2015 7:44 pm
The force is strong in this onemitchj wrote:I'm new to the fixie world - just got my first one up & running a month or so ago, but I have to agree with all of the above - simple, clean lines, good exercise etc - grass roots cycling really. As soon as you leave home, that's it - up hill, down hill, head wind, stop signs, whatever - no gears, no freewheel - you have to deal with it. Love it!
- AlexHuggs
Re: Why SS/Fixie
Postby AlexHuggs » Tue Sep 01, 2015 9:33 pm
Re: Why SS/Fixie
Postby Ant_S » Fri Sep 04, 2015 12:53 pm
I guess I found I was just used to SS and happy to stick it out. Worst is the wind really, if there is a strong headwind it gets a bit annoying. Otherwise it's all good. I reckon if you get used to gears you'll probably miss them, whereas the other way around you won't
- Gordonhooker
Re: Why SS/Fixie
Postby Gordonhooker » Tue Sep 08, 2015 9:53 am
Simple answer for me is - it is a fun and no fuss way to enjoy cycling....AlexHuggs wrote:Hi, I'm wondering what the attraction of a SS and/or Fixie road bike is. I never new this was a thing beyond BMX bikes. Is there a practical benefit or is it one those quirky personal things (which I'm all into, so no offence intended)? Why do you ride a Fixie?
- Nate
Re: Why SS/Fixie
Postby Nate » Fri Sep 11, 2015 9:23 am
that chunky Single Speed chain is golden & lasts a lifetime compared to a 10/11 speed chain. lube it whenever.
Add some disc brakes & its the perfect commuter.
feels more relaxed when you ride, you get rollin & up to speed whenever... just cruising along.
- bigfriendlyvegan
Re: Why SS/Fixie
Postby bigfriendlyvegan » Fri Sep 11, 2015 10:37 am
Why fixie? Initially for shots and giggles. I persisted for a good workout. I'll keep doing it because it's fun. And when I feel tired, I can just switch it to SS and ride that.
Re: Why SS/Fixie
Postby Nobody » Fri Sep 11, 2015 11:02 am
- Thoglette
Re: Why SS/Fixie
Postby Thoglette » Fri Sep 11, 2015 12:09 pm
Re: Why SS/Fixie
Postby elfoam » Sat Nov 07, 2015 11:37 pm
I actually have a 7kg sram force carbon bike myself that I never ride. Like as in its done maybe 500km. Never enjoyed riding it.
- HappyHumber
Re: Why SS/Fixie
Postby HappyHumber » Sun Nov 08, 2015 12:06 am
- europa
Re: Why SS/Fixie
Postby europa » Sat Nov 28, 2015 1:14 am
When I go to the bike wall, all else being equal, I choose my Hillbrick (fixed) over my beloved Europa (now geared). You're welcome to choose something else.
Return to “Fixed Gear/ Single Speed”
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
