Hi,
I need some help identifying what type of bottom bracket my bike has, it is a Shimano Hasa R5 2015 and in the specs of the bike it shows - BOTTOM BRACKET: NECO CH-51 Cartridge Type
I am looking at a crankset that comes with bottom bracket and my 2 options are:
Shimano 4600 BB Cups (34/35/4500 double/triple)
OR
Shimano BB-RS500 BB Cups (Tiagra 4700)
My first guess was Shimano 4600 BB Cups (34/35/4500 double/triple)
Thanks!
What Type of Bottom Bracket Do I Have?
- techsupport
Postby techsupport » Mon Jan 23, 2017 4:03 pm
Is that a bird or a plane?
- find_bruce
- Moderator
Re: What Type of Bottom Bracket Do I Have?
Postby find_bruce » Mon Jan 23, 2017 4:27 pm
It is not clear to me what you want.
If you are replacing the bottom bracket & keeping the crank, the NECO CH-51 Cartridge Type is a square taper, pretty much like a Shimano UN55
If you are replacing the crank, you need a bottom bracket that suits both your frame, which will be 68mm English thread, and the new crank.
There is, as far as I am aware, no difference between a 4600 & 4700 bottom bracket
- techsupport
Postby techsupport » Mon Jan 23, 2017 4:52 pm
Here is a link to the page, when you configure options asks for either of those 2 bottom brackets. The Bottom bracket comes with the http://www.ribblecycles.com/au/shimano- ... groupset-1find_bruce wrote:It is not clear to me what you want.
- A_P
Postby A_P » Mon Jan 23, 2017 5:03 pm
of the 2 choices, one of them will likely be for italian thread BB.
- find_bruce
- Moderator
Postby find_bruce » Mon Jan 23, 2017 8:14 pm
A_P wins the prize - the first option is "Shimano 4600 BB Cups (34/35/4500 double/triple) Ital " - ie Italian thread. You want the second option "Shimano BB-RS500 BB Cups (Tiagra 4700)" which should be English thread. Personally I would send them a message to confirm that the second option is English thread
- Duck!
Postby Duck! » Mon Jan 23, 2017 11:37 pm
Not so. Like the higher-spec models trickled down from 9000 Dura-ace, the RS500 (4700-level) bottom bracket has a smaller external diameter and corresponding low-profile bearings, along with improved, lower-friction seals compared to 4600. The critical dimensions of assembled width and internal diameter are unchanged.find_bruce wrote: There is, as far as I am aware, no difference between a 4600 & 4700 bottom bracket
- techsupport
Postby techsupport » Tue Jan 24, 2017 8:08 am
So mine is the 4600?Duck! wrote:Not so. Like the higher-spec models trickled down from 9000 Dura-ace, the RS500 (4700-level) bottom bracket has a smaller external diameter and corresponding low-profile bearings, along with improved, lower-friction seals compared to 4600. The critical dimensions of assembled width and internal diameter are unchanged.find_bruce wrote: There is, as far as I am aware, no difference between a 4600 & 4700 bottom bracket
- Duck!
Postby Duck! » Tue Jan 24, 2017 9:07 am
No, yours is a square taper internal cartridge.
- techsupport
Postby techsupport » Tue Jan 24, 2017 10:25 am
Will either bottom bracket fit on my frame? 4600 or 4700Duck! wrote:No, yours is a square taper internal cartridge.
- Duck!
Postby Duck! » Tue Jan 24, 2017 1:30 pm
Yes, just be sure to get the English thread version.
