Page 1 of 1
How to maintain this chain? (pic inside!)
Posted: Sun Sep 30, 2012 3:00 pm
by Xplora
Hi team, what do I do to this? I took the best pic I could to describe the overall condition.
upload pictures
Re: How to maintain this chain? (pic inside!)
Posted: Sun Sep 30, 2012 4:28 pm
by RonK
It looks ok to me - I'd give it a liberal flush with Rock'n'Roll Gold, wipe off the excess, and ride...
Posted: Sun Sep 30, 2012 4:29 pm
by Le Velo
Best way to clean the chain (for me and no doubt everyone has a different technique) is with some citrus cleaner and a toothbrush. I spray the cleaner on the chain on the bottom section of the chain stay so it will drip directly out on the ground (lawn as I clean the bike outside) then spin the crank a bit, spray and scrub again with the toothbrush until you have gone all around. Et into the cassette while you are at it and the jockey wheels on the RD as well. Then wash it all off and I dry the chain with a rag then let it air dry for a few hours or overnight then relube and voila . This should get you on your way for a much smoother gear change also
Posted: Sun Sep 30, 2012 5:36 pm
by bychosis
RonK wrote:It looks ok to me - I'd give it a liberal flush with Rock'n'Roll Gold, wipe off the excess, and ride...
Plus one. Should take less than 5min. Would only go to greater measures if it is not moving freely. Cleaned plenty that look like that after a mud run on the MTB and only used Rock n Roll in the last couple of years.
Posted: Sun Sep 30, 2012 9:13 pm
by DavidS
Looks like a normal amount of gunk. Chains do pick up gunk.
I wash mine once a month by soaking it in kero, using toothbrush to clean it and then I let it dry. After this I too use Rock and Roll gold to lubricate and off we go. Since my bike is for commuting the chain and bike can get dirty so can do with a clean once a month.
DS
Posted: Sun Sep 30, 2012 9:42 pm
by jacks1071
DavidS wrote:Looks like a normal amount of gunk. Chains do pick up gunk.
DS
+1 this is good advice, if you use rock and roll lube you'd probably be flat out needing a propper clean once a month.
Posted: Sun Sep 30, 2012 11:14 pm
by Mulger bill
Meh, scrube the bejabbers out of it with kero and toothbrush, apply
Purple Extreme. Ignore for 4-500 kms
Posted: Mon Oct 01, 2012 11:31 am
by Reman
Sheldon gives you the only method guaranteed to get a clean chain
http://sheldonbrown.com/chainclean.html
Posted: Mon Oct 01, 2012 1:44 pm
by Aushiker
+ 1 or otherwise degrease the chain and relube. Not a bit issue either way by the looks of it.
