Just tested the cheap little Aldi pump.
- uart
Postby uart » Sat Mar 19, 2016 10:35 am
First impressions are: it works. Well for a sub $10 pump that's a win right there, because a lot of the cheap ones are total pieces of poo. I bought a similarly priced one from kmart a few months ago and seriously it ended up going almost straight into the rubbish bin. It was supposed to be suitable for high pressure tires and it could barely manage 20 psi, leaked air everywhere and every time I tried to use it I actually ended up losing pressure. I was totally pissed off with myself for not keeping the receipt on that kmart one, because crap like that needs to be returned to them so that they get the appropriate feedback and stop selling it.
Anyway, the little one from Aldi has a HP/HV switch, and that actually works too. In the high volume mode it get the first 25 PSI in fairly quickly, and in the HP mode I had no problems getting 100 psi. It has the "locking lever" type arrangement and seals well on the valve with no air leaks. It also has the double outlet thingy so it can do car/MTB valves as well, though I've only tested it with the high pressure presta valves so far.
It's also got an inbuilt pressure gauge which is a nice touch. Actually the only complaint I'd have is that the pressure gauge on the one I received seems pretty inaccurate. I'll have to test it against a more accurate one later to confirm, but it appears to read a bit under.
- Moderator
Re: Just tested the cheap little Aldi pump.
Postby thomashouseman » Sat Mar 19, 2016 10:41 pm
Postby SteveTheTiger » Sat Mar 19, 2016 11:45 pm
Does anyone know an Aldi store in Sydney Metro area that has any left?
- Mulger bill
Postby Mulger bill » Sat Mar 19, 2016 11:51 pm
I'm going to my local in Melbs before work tomorrow, want me to have a look?SteveTheTiger wrote:I missed out on finding the pump in stock at my local Aldi, despite going on the day it was released.
Postby Patt0 » Sun Mar 20, 2016 8:12 am
thomashouseman wrote:I bought the Aldi Huge gigantic floor pump for a runout $4. It too works a treat. No complaints whatsoever.
I got two of those on runout for 10bux a piece. One for work and one at home. Used them everyday for over two months. Still works the same, just dont have to use it as often. When I bought my new bike and had the tyres changed to 28mm the bike shop left in the small tube. Now with an appropriate tube it dont go down.
- uart
Postby uart » Sun Mar 20, 2016 1:44 pm
By "floor pump" do you guys mean a floor hand pump (like hand operated with a vertical barrel) or are you referring to a foot pump (which obviously also sits on the floor).thomashouseman wrote:I bought the Aldi Huge gigantic floor pump for a runout $4. It too works a treat. No complaints whatsoever.
I've got the Aldi double barrel foot pump which I've had for quite a few years now, and it works great too. That one's also got outlets for both Presta and Schroder valves, but up until recently I'd only ever used it for Schroder. I thought that it would only be suitable for low pressure because it's just ridiculously high volume. But recently I've been using it for my HP presta stuff as well, and though you've really stand on it, it works just fine. Oh and man is it fast!
- uart
Postby uart » Sun Mar 20, 2016 1:56 pm
I forgot to go and look when they were on sale, and to be honest I was surprised to see that lone one sitting there yesterday. I thought they be sold out too. Maybe mine was a return or something, because the package did look like it might have been opened, and the pressure gauge is pretty far off the mark on this one (so maybe someone didn't like that and returned it).SteveTheTiger wrote:I missed out on finding the pump in stock at my local Aldi, despite going on the day it was released. Does anyone know an Aldi store in Sydney Metro area that has any left?
TBH though I don't really care too much about the pressure reading, as long as it's repeatable then I'll figure it out. Just doing a quick test now confirms that it definitely reads under. It looks like it reads about 5 Bar when the actual pressure is 6 Bar (75 psi when actually 90 psi).
The pump itself works great though. A little slow in HP mode, but it definitely gets you there in the end. With both valve types covered this thing will be really handy to carry out on the road or trail.
Postby elfoam » Wed Mar 23, 2016 2:22 am
- uart
Postby uart » Wed Mar 23, 2016 1:12 pm
Thanks elfoam. Tall vertical, yeah that's your classic floor pump. I never saw that one at Aldi, only the foot ones. I guess I must have missed it.elfoam wrote:The pump im talking about is the talll alloy vertical. The double barrel foot pump i also have but its not as potent as the vertical.
Yes the good old floor pump is still the most effective type. I've got a really old one here, but unfortunately it's only for car valves and most of my bikes use presta.
Postby SteveTheTiger » Wed Mar 23, 2016 7:28 pm
If anyone sees one in a Sydney metro store, let me know. Cheers
- Mulger bill
Postby Mulger bill » Wed Mar 23, 2016 7:52 pm
Plenty in my localSteveTheTiger wrote:I'm still looking for the small hand pump to carry on the bike. Already got a good floor pump from Aldi at home.
- rodneycc
Postby rodneycc » Wed Mar 23, 2016 10:39 pm
Postby cyclingnolycra » Thu Nov 22, 2018 8:19 am
Postby Philistine » Thu Nov 22, 2018 8:45 am
My Aldi pump has an automatic valve in the head that has never worked properly. If my Presta tube has some air already in it, the pump will usually further inflate it (but no guarantees). If the tube is completely flat - forget it!cyclingnolycra wrote:Sorry to dig up this mega old post, and this may be a stupid question, but how do you get this little aldi pump to work with presta valves? I can't seem to get it to stay on while pumping. Or do I need to get one of those little presta to Schrader adapters?
It is easier to use a Presta / Scrader adapter, and these can be bought on E-Bay for $3.XX for 5. Buy 5 - they are too easily lost!
- Moderator
Postby thomashouseman » Thu Nov 22, 2018 9:16 am
- bychosis
Postby bychosis » Thu Nov 22, 2018 12:15 pm
Mine does the same. Sometimes it just won’t switch over to the correct side. I was going to change the head for one off a zefal pump, but by the time I got around to it the other head had disappeared into the garage parts vortex.Philistine wrote:My Aldi pump has an automatic valve in the head that has never worked properly. If my Presta tube has some air already in it, the pump will usually further inflate it (but no guarantees). If the tube is completely flat - forget it!
Postby Tamiya » Fri Nov 23, 2018 12:33 am
Popped into Reid recently... hmm... that white track pump looks vaguely familiar... https://www.reidcycles.com.au/reid-trac ... white.html except theirs has a 1 hole head that fits both types.
- uart
Postby uart » Fri Nov 23, 2018 5:55 pm
My initial post here was about their little mini pump, but yeah that Reid floor pump does look pretty similar to the latest Aldi one (except for the head). Wow, big price difference though. I think I paid all of about $13 for the Aldi one.Tamiya wrote:Aldi track pump has 2 hole head... sometimes it doesn't flip over, gotta cover 1 hole with finger & give it a stroke. Presta stem gotta go pretty deep in too.
A little tip about that latest Aldi floor pump with the double head. The only complaint I had was that on presta valves it let a lot of air leak out until you flipped up the lever. On narrow tyres I often lost most of the pressure before I got the lever flipped up. The trick I found is to hold the lever just slightly cocked (like about one quarter way or less) with your thumb while you push the head on. This way it holds the pressure properly while you are flipping up the lever the rest of the way.
Postby Tamiya » Fri Nov 23, 2018 8:18 pm
Yeah it's a bit of an acquired skill how to unhook without loosing too much pressure.
But the other odd thing to bear in mind, the presta stem has to poke in pretty far. I was struggling with a presta tyre the other day, it only had ~20mm sticking out of deep rim... couldn't get head to seal on that - but it worked ok earlier as a naked tube. Had to yank more stem out of the rim, needed about 30mm inside the head to seal. (The schrader hole didn't like presta adaptor either, but I didn't try too hard there)
