Comedian wrote:
The thing that struck me about it (and motorex dry) is they are like none of the other lubes that I tested. They look very similar to a normal oil like Morgan Blue when they go on, but they dry. I would say they almost behave like a hybrid of the dry and wet oils. It probably isn't quite as clean as a pure dry - but that could be because it's lasting 2-4x longer than the normal dry would have.
When you do go to try and clean things they don't behave normally ... as I've mentioned I used two cans of degreaser trying to get the regular off the crank. It just ignored the degreaser and the film stays.
So the upshot of that ramble is that if your "application" needs a persistent coating that can be applied and let to dry then it might be interesting. I think it would be completely unsuitable for delivery on the go with other fluids.
the "application" currently uses a grease which is a blend of PTFE/PFPE (Ultimox) - which is the much cheaper alternative to Krytox - an oil like lube, which is typically used in SCUBA applications also.
(Its a moving rubber/leather/plastic piston inside of a metal sleeve)
Only the 2nd ride so far so little data, but its still a bit "wet" (i used the light ProX version), and its a little grey when wiped down.
Feels a lot like the silicon lube I use on the other stuff.
Silent & shifting really well.
Just ordered 2 nice wipperman connex sx chains too!
