Worn chainrings causing skipping
Postby tez001 » Sun Oct 28, 2018 1:29 pm
While riding yesterday when putting power down while standing up, I get what feels to be skipping of the chain or some other part of the transmission, like a crunching sound for about 1/8 of a turn of the crank.
Thought it may have been rear cassette, hanger, adjustment or freehub related but they all check out fine in my opinion.
Which leads me to the chain rings. The previous cassette and chain had no issues with skipping. Im guessing the new cassette and chain have amplified the problem of the worn rings? They've done just under 15,000kms.
Re: Worn chainrings causing skipping
Postby jackthelad » Sun Oct 28, 2018 1:51 pm
Inner ring is fine, still has chamfered markings in place,
Just depends on budget, whether you replace one or 2 rings
SantaCruz Blur XC Carbon
Kona Kula Supreme(Retired/Spare)
Surly Karate Monkey
Ribble Rd Bike
Postby tez001 » Sun Oct 28, 2018 1:55 pm
Looking a the price of chain rings, it's nearly just as economical to buy a whole crankset.
Postby jackthelad » Sun Oct 28, 2018 2:22 pm
Stampage is the Machining marks, of the small changrings, you can still see at the tip off the small teeth
Rolled shoulder, is where you can see the leading Edge of the Big Ring Teeth, are worn past the tip of the teeth..
(visible on small ring for comparison)
and extending and changing the shape of the valley between teeth
Hope that makes sense
Surly Karate Monkey
Ribble Rd Bike
Postby Baalzamon » Sun Oct 28, 2018 4:58 pm
Postby tez001 » Sun Oct 28, 2018 6:17 pm
Having said that, I just found a set of chain rings for $95 odd vs $140 for a whole crankset.
- Duck!
Postby Duck! » Sun Oct 28, 2018 6:40 pm
Big ring is the exxie one (but looking at the inner face of it, it's 105 at best, so not one of the crazy expensive hollow ones; small rings are quite cheap.Baalzamon wrote:Just look at the profile of the big ring vs small ring and you can see the difference in teeth very easily. Does it do the same on small chainring? If not, then buy a new crankset as chainrings as $$$$.
Postby tez001 » Sun Oct 28, 2018 7:14 pm
Duck! wrote: Big ring is the exxie one (but looking at the inner face of it, it's 105 at best, so not one of the crazy expensive hollow ones; small rings are quite cheap.
Spot on, 105 5800.
- StevOz
Postby StevOz » Sun Oct 28, 2018 8:58 pm
Using squirt from new, one chain replaced and 3+ years latter the old girl is still running on the original gears and changing gears sweet.
Next time most likely a rear sprocket change, done at least 12000 kms....most likely many more, just saying a $30 a bottle of the good stuff at $15 a year has proven it's worth ten times.
Postby jackthelad » Sun Oct 28, 2018 9:23 pm
Surly Karate Monkey
Ribble Rd Bike
Postby tez001 » Mon Oct 29, 2018 8:54 am
StevOz out of 12,000kms, have you just run two chains and a cassette?
- StevOz
Postby StevOz » Mon Oct 29, 2018 9:32 am
It's a hybrid Fuji traverse 1.3 with a rear topeak rack and bag which is always loaded with gear and or shopping.
Postby RhapsodyX » Mon Oct 29, 2018 10:09 am
Postby tez001 » Mon Oct 29, 2018 1:24 pm
- Howzat
Postby Howzat » Thu Nov 15, 2018 8:00 am
Is 11-speed noticeably less durable than 10-speed?RhapsodyX wrote:I let my chain get way worn (It died in less than < 3,000Km! Bloody 11S! )
- Tim
Postby Tim » Thu Nov 15, 2018 8:38 am
Not my experience.Howzat wrote:Is 11-speed noticeably less durable than 10-speed?
5,000km per chain.
20,000km per cassette and small 39t ring . 53t ring only used less than 10% of riding, never replaced.
I keep 2 chains on 1000km rotational change, run till 10,000, then 2 new chains on same rotation to 20,000.
10 speed bike odometer 37,000km's and 11 speed odometer 24,000km's on one bike and 12,000 on another.
I don't bother measuring chain wear these days, I just ditch them at 5000km's.
My system seems to work, never had chain skip on sprockets.
Wipe chain clean with a Chux type cloth and oil with Triflow or Purple Extreme every 200km's.
These are road bikes rarely ridden in the rain.
On my touring bike ridden largely on rail trails and dirt roads I have worn chains out in less than 3000km's and chainrings and cassettes in less than 7000km's (9 speed).
