Hi everyone,
When riding my Lynsey GR260 I very sporadically strike my heel on the left chainstay. The bike came with crappy FSA Gossamer cranks and a BB386EVO bottom bracket. I have replaced them with an ultegra crankset and bb.
So has this change brought my heel closer to the chainstay? Is the Q factor the only thing I have changed or do bb widths have some involvement. The Q factor for ultegra is 146mm while the gossamer is 145mm I think. I found the fsa Q factor on wiggle as their website is hopeless.
The heel strike is not a drama but am curious if the change in crankset has made it worse.
Q factor query
- biker jk
Re: Q factor query
Postby biker jk » Tue Nov 06, 2018 9:55 am
Curious to know the gap between the left hand crank and chainstay. On my Lynskey it is only 5mm but I don't have heel strike. Do you have your cleats at an angle such that your heel is inboard?
Re: Q factor query
Postby macca33 » Tue Nov 06, 2018 10:37 am
In your case, the BB width has stayed the same at 86mm, you've only changed the cranksets. If you state the Ultegra has 146mm Q-Factor, vs the FSA at 145mm, then you've increased your Q-Factor very slightly, not reduced it.
I would also check your cleat alignment.
CAAD10 Berzerker & Focus Mares & Ridley Noah SL
Re: Q factor query
Postby uad782 » Thu Nov 08, 2018 7:38 am
Thanks everyone.
I have 8mm from crank to chain stay. Chain stay widens significantly near heel though. I will check cleat alignment as it appears I turn my heel in sometimes. Maybe something to do with hip rotation etc too.
I am confused about the 86mm though as bike only has a 68mm BB. I am curious is BB is longer such as 86mm do you need a different set of cranks as their axle could be too short??
- Duck!
Re: Q factor query
Postby Duck! » Thu Nov 08, 2018 8:28 pm
It's either a BB30 frame with adaptors/spacers, or English threaded with outboard bearings; either way the assembled width works out the same.uad782 wrote: I am confused about the 86mm though as bike only has a 68mm BB. I am curious is BB is longer such as 86mm do you need a different set of cranks as their axle could be too short??
