Removing cranks with stripped thread
Postby jordyr » Sun Dec 16, 2018 9:34 pm
- find_bruce
- Moderator
Re: Removing cranks with stripped thread
Postby find_bruce » Mon Dec 17, 2018 10:01 am
- P!N20
Postby P!N20 » Mon Dec 17, 2018 10:34 am
Postby twowheels » Mon Dec 17, 2018 10:50 am
- Tim
Postby Tim » Mon Dec 17, 2018 12:43 pm
- uart
Postby uart » Mon Dec 17, 2018 1:53 pm
Yes wedges could work. Grease them so that they slide easily and Insert them so that they go in opposite directions. Then with hammers tap them both inward, at the same time, so that they slide over each other. This will expand the crank off.Tim wrote:I've read of successful removal and no damage with drill chuck wedges.
I actually made a (very crude) pair of wedges like that in about half an hour using just a hacksaw, bench grinder and file. That was to get a tapered drill chuck off, but it's a very similar arrangement to the tapered spindle on an old set of cranks.
BTW. It's weird how many old bikes I come across with the threads totally destroyed on either one side or the other. People cross threading in the removal tool seems to be the problem.
- Tim
Postby Tim » Mon Dec 17, 2018 2:01 pm
I've stripped the thread twice.uart wrote:BTW. It's weird how many old bikes I come across with the threads totally destroyed on either one side or the other. People cross threading in the removal tool seems to be the problem.
First time the crank puller tool wasn't done up tight (with a spanner) and pulled straight out of the crank with the crank threads following.
Second time I didn't remove the crank retaining bolt, inserted the puller, and pulled the thread out again.
I'm a slow learner.
- find_bruce
- Moderator
Postby find_bruce » Mon Dec 17, 2018 2:40 pm
Alloy cranks v steel tool - as you say cross thread & its goodbye to alloy threadsuart wrote:BTW. It's weird how many old bikes I come across with the threads totally destroyed on either one side or the other. People cross threading in the removal tool seems to be the problem.
- Duck!
Postby Duck! » Mon Dec 17, 2018 8:37 pm
A better option if destruction is not an issue is to cut across the butt of the crank, in line with the spindle. You may need a very fine cutting tool like a Dremel or similar to get in to the inner edge of the crank without damaging the frame. Wedge open the slot and the crank should then release from the spindle quite easily.jordyr wrote: the cranks will be thrown out so I've actually resorted to a hack saw around the circumference of the crank where it hugs the BB - I'm open to any tips at this stage....
- OnTrackZeD
Postby OnTrackZeD » Tue Dec 18, 2018 8:15 am
+1P!N20 wrote:Is the bike ride-able? When I stripped the thread on an old Shimano 600 crank I just went for a ride and it came loose within minutes.
Yep I've done it too.
You'll need to loosen the bolts first btw.
Postby Ivanerrol » Tue Dec 18, 2018 9:57 am
Soak the crank ends with Penetrene over night.
If the ends haven't burred over as Duck mentioned the cranks will be much easier to remove.
I used a pickle fork and Penetrene. Pickle fork is a ball joint removal tool. - You need to be careful though.
(Penetrene is also very good for gunked up shifters)
Postby jordyr » Tue Dec 18, 2018 7:42 pm
Thanks for all the help, I'll give the wedges a go under some heat and if all else fails, probably cut straight through both the crank end and spindle on one side with the grinder... will let you know how it goes!
- bychosis
Postby bychosis » Wed Dec 19, 2018 6:33 am
- WyvernRH
Postby WyvernRH » Wed Dec 19, 2018 7:07 am
Like Bychosis says, you don't have to cut the axle. If you are not confident with your skill using a small angle grinder or dremel just use a open ended hacksaw to cut down thru the alloy until you are almost through to the axle and give it a tap and twist with a chisel or old screwdriver in the slot. The hacksaw won't hurt the hardened axle even if you do touch it. A bit of heat carefully applied would help once you have cut the slot. I've had to do this a couple of times with clunkers someone has brought in for me to work on.jordyr wrote:Spot on, I had no idea they were flared over the spindle, and put all my weight behind the crank pullers. Put a lot of effort into unknowingly stripping that thread actually...
- bychosis
Postby bychosis » Wed Dec 19, 2018 12:18 pm
Found this old pic of the home made crank extractor that I attempted to remove a stick crank with. It just stripped the bolt. You can see on the right what I ended up doing with the hacksaw.
The second time with stuck cranks I got as far as almost stripping the thread on the cranks then I went straight for the grinder and chopped them off.
Postby jordyr » Mon Feb 25, 2019 7:43 am
