Holding Position
- Toolish
Holding Position
Postby Toolish » Fri Mar 21, 2014 9:31 pm
I have had a fit, but need to get better at staying in the aero position.
Is it a core strength thing, flexibility, or just spending time aero?
- toolonglegs
Re: Holding Position
Postby toolonglegs » Fri Mar 21, 2014 9:40 pm
Personally I have trouble looking very far ahead when in position... my neck takes a lot of conditioning.
Plus the more I train in the TT position the closer my power numbers are to what I can hold on the roadie.
- ldrcycles
Postby ldrcycles » Fri Mar 21, 2014 10:15 pm
Postby thearthurdog » Sat Mar 22, 2014 5:16 pm
Postby MDL » Tue Apr 29, 2014 8:27 pm
So this is what you have been doing on the trainerthearthurdog wrote:Riding an indoor trainer in position helps a lot as well.
MDL
- clackers
Postby clackers » Wed Apr 30, 2014 9:39 pm
Cadel did pilates to improve core strength to let him hold his time trial position.Toolish wrote:
Postby Mjainoz » Mon Nov 10, 2014 9:39 pm
Your fitter is crap or did a crap job. If you can't hold the position you are set up for in your fit, it's not FIT for YOU. More likely some textbook numbers.Toolish wrote:Is there anything that can be done to help hold aero position.
Ring them back and tell em they did a crap fit. Ask for a re fit. Then when you can ride in your new position for a sustainable period ie hours. Go back and get a new fit.
Save your money on Zipps and other bling. Get a good fit and get as aero as you can hold for now. And be prepared to get "re fitted" each year or so till you get slippery as a snake.
Postby dalai47 » Mon Nov 10, 2014 11:16 pm
Disagree - adaption will take time. According to a man who has done a few TT's in his time - Chris BoardmanMjainoz wrote:Your fitter is crap or did a crap job. If you can't hold the position you are set up for in your fit, it's not FIT for YOU. More likely some textbook numbers.Toolish wrote:Is there anything that can be done to help hold aero position.
"Is getting the body comfortable and the right fit as important as aerodynamics?
There are two gaping holes in how position is currently addressed. Aero and efficiency need to be tackled, or at least considered, together. If a better position looses you 20 watts you need to know what the net effect is. If you have just gained 50 watts in aero efficiency then it’s a win. If you recognise that aero is the biggest user of energy how can you decide if a position is good/bad without knowing the effect on aero? The second issue is that position is assessed usually for ‘comfort’ or ‘efficiency’ without allowing any meaningful time to adapt. A friend of mine, who had defined where he wanted to keep his head for optimal results, sewed a metal washer into the back of his skin suit and put a magnet on the tip of his aero helmet. When the two connected there was an audible ‘click’ and he knew this was the position he was shooting for. It took him nearly two months before this head position became his default."
http://triathlete-europe.competitor.com ... s-boardman" onclick="window.open(this.href);return false;
Postby Mjainoz » Tue Nov 11, 2014 2:59 am
Well. I actually agree with you. And i was talking in my post about adaption over time. But if the OP wants to race tomorrow they will be sitting up like a parachute 10ks in Just a side I've dropped about 25mm of stem spacers in three years (more to aero than that of course however...). Had three bike fits in three years. 53yrs old. The adaptions taken time.dalai47 wrote:Disagree - adaption will take time. According to a man who has done a few TT's in his time - Chris BoardmanMjainoz wrote:Your fitter is crap or did a crap job. If you can't hold the position you are set up for in your fit, it's not FIT for YOU. More likely some textbook numbers.Toolish wrote:Is there anything that can be done to help hold aero position.
But back to your point. You are correct.
- clackers
Postby clackers » Wed Nov 12, 2014 11:01 am
Cadel Evans used pilates to help in the adaptation. The core muscles aren't exercised by conventional gym equipment.
- toolonglegs
Postby toolonglegs » Wed Nov 12, 2014 5:27 pm
Postby Parker » Fri Nov 14, 2014 7:03 pm
If going gradually and increasing time doesn't work then the fit or bike is wrong
- jules21
Postby jules21 » Tue Jun 30, 2015 2:42 pm
1. I know I need to spend more time on the bike. it's been sitting in a corner (it needed some work).
2. should I drop the seat height? I've got it set basically where I'd set my roadie seat height, with the leg slightly bent at furthest point (5.30 o'clock). would you normally run a TT bike seat height lower? or should I focus on #1 first to see if it improves with time?
- toolonglegs
Postby toolonglegs » Tue Jun 30, 2015 4:09 pm
I set up my TT bike saddle from BB to about 1 inch behind the nose of the saddle which is where I sit. Makes it about a cm higher than road bike if I sit upright in the middle of the saddle.
I have done a few TT rides in the last month and I am having trouble with the longer crank length ... hips are too tight to be smooth. Sucks getting older!. I also getting very twisted in my position but thats another tale.
I am running a ISM Adamo saddle for TT's. They take a bit of conditioning if you really want to sit on the nose all the time... but once you get used to it you can sit on the nose comfortably for long periods with out any pressure.
- Strawburger
Postby Strawburger » Tue Jun 30, 2015 4:36 pm
