What's the best way to get a PR on a hill?
Postby JoelBelton » Fri Nov 04, 2016 11:53 pm
Thanks.
- cancan64
Re: What's the best way to get a PR on a hill?
Postby cancan64 » Mon Nov 07, 2016 11:18 am
- mikesbytes
Postby mikesbytes » Mon Nov 07, 2016 12:20 pm
Postby macca33 » Mon Nov 07, 2016 2:09 pm
OR, just ride harder - with a tailwind..
Postby Calvin27 » Mon Nov 07, 2016 2:35 pm
Cushy dirt bike
Very cushy dirt bike
Bike crushed by car (RIP)
No brakes bike
Ebike
Postby koshari » Mon Nov 07, 2016 3:38 pm
best way is to find a hill nobody else has ridden, log it and you will be KOM however after a bit of time strava will backfill all the other earlier efforts and you will likely plummet down the order.JoelBelton wrote:I'm only a beginner road cyclist and have just got back into cycling and trying to get a KOM for a short hill in my area. What would be the best way to cycle up this hill, as in a higher or lower gear? Seated or standing in the saddle? And would it be better having a strong tailwind behind me as I'm going up the hill or a tailwind before the turn to the hill for a fast start?
Thanks.
Seriously though as others have suggested, hit it with speed on a day when the wind favours the approach, try and hit the beginning of the segment at a nice pace then start shifting through the gears to keep as much cadence/momentum up , once you hit the big ring on the back get up on the flats to clear your airway out and try to keep feeding your screaming lungs. at this point you will be doing far less speed and the wind advantage of being in the drops will have given way to the requirement to breathe.
of coarse its a moot point on some hills,
https://www.strava.com/segments/2776859
- foo on patrol
Postby foo on patrol » Sat Nov 12, 2016 11:51 am
Foo
Goal 6000km
- Rural Rider
Postby Rural Rider » Thu Feb 09, 2017 7:23 pm
RR
2016 Specialized Allez e5 Sport
- g-boaf
Postby g-boaf » Sun Feb 19, 2017 4:09 pm
That's right, just do laps and laps and more laps of that damn hill and eventually it'll get easier.foo on patrol wrote:Get fitter and stronger and then worry about KOMs.
Foo
- singlespeedscott
Postby singlespeedscott » Sun Feb 19, 2017 5:24 pm
Lighter riders will find the sit and spin technique easier whilst heavier riders, like myself, prefer to stand and muscle their way up.
All this is moot once you hit a cat2 climb or higher. You can only stand for so long and this is why lighter riders make better climbers. They simply have less mass to drag up the hill.
So the simple answer is to climb lots of hills and loss lots of weight.
- Derny Driver
Postby Derny Driver » Sun Feb 19, 2017 9:15 pm
If you know you are just a beginner cyclist, and that many other cyclists are better/stronger/fitter/faster than you, what does a KOM prove? Surely its an exercise in self deception?JoelBelton wrote:I'm only a beginner road cyclist and have just got back into cycling and trying to get a KOM for a short hill in my area...
Thanks.
I dont get it
Postby JoelBelton » Sun Feb 19, 2017 9:25 pm
If you don't get it, then why reply?Derny Driver wrote:If you know you are just a beginner cyclist, and that many other cyclists are better/stronger/fitter/faster than you, what does a KOM prove? Surely its an exercise in self deception?JoelBelton wrote:I'm only a beginner road cyclist and have just got back into cycling and trying to get a KOM for a short hill in my area...
Thanks.
I dont get it
- Derny Driver
Postby Derny Driver » Sun Feb 19, 2017 9:45 pm
I thought someone might explain it to meJoelBelton wrote: If you don't get it, then why reply?
- g-boaf
Postby g-boaf » Sun Feb 19, 2017 9:57 pm
There is an excellent topic on training here:JoelBelton wrote:If you don't get it, then why reply?
viewtopic.php?f=12&t=91287
You should read it. When you have read it and applied the principles, let us know how you've progressed in a month or so.
Postby tcdev » Sun Feb 19, 2017 10:51 pm
Next will be gearing, and that will depend on the hill itself. It's something that you will simply have to practice. A few weeks ago I flew up a hill that I'd struggled on before; I had a fair bit left at the top and, a little surprised if I'm honest - no PR for me that day because I'd got the gearing wrong. On another day on another hill I just got to the top right on my threshold; thought it was too slow but ended up with a PR! I've still got plenty to practice too!
EDIT: I should add, all my successes have been hitting the bottom at the highest possible speed, whilst not blowing out beforehand. The only time I find I'm standing on the way up is when I've got the gearing wrong, and that usually means I've blown it.
2011 Schwinn Sporterra Comp
2021 Giant Contend AR1
- foo on patrol
Postby foo on patrol » Mon Feb 20, 2017 6:59 am
Foo
Goal 6000km
- bychosis
Postby bychosis » Mon Feb 20, 2017 8:27 am
I find I run down to the largest cassette ring then switch down to the smaller front ring. Depending on the hill it might be more useful to switch to the small chainring a couple of gears earlier so you don't need to back off the power as much. I find changing rear gears is easier under load.
- queequeg
Postby queequeg » Wed Feb 22, 2017 11:46 pm
Really, it all comes down to power to weight. There are guys 20kg lighter than me who can basically float up hills, and to simply match their pace with my weight I would need to be putting out 450W avg power for 10 min. You can't cheat the physics, so you have to understand what YOU are capable of.
Of course, you can always do a group ride and get some assistance from friends to snag a KOM. I have seen that done (e.g. Bobbin Head East KOM in Sydney was a calculated effort)
