Seeking info on Wahoo Kickr
Re: Seeking info on Wahoo Kickr
Postby Krank » Fri Jun 12, 2015 4:37 am
Do you Kickr Owners observe a noticeable power drift over time and use with these units?
Krank
Postby Andrew28 » Tue Jun 16, 2015 7:58 pm
I haven't had any noticable problems. I don't have another power meter to use as a comparison however.Krank wrote:How consistent is Power drift on the Kickr?
Krank
I leave mine switched on and rarely perform a spindown.
- Comedian
Postby Comedian » Wed Jun 17, 2015 2:49 pm
During a 20 minute FTP test mine was within 1w of the average power read by my vector pedals.Krank wrote:How consistent is Power drift on the Kickr?
Krank
Postby thecubical » Mon Jun 22, 2015 10:04 am
Postby Bluejay87 » Fri Jul 03, 2015 12:26 pm
I use a similar one and it works okthecubical wrote:Anyone know if the KICKR is compatible with any of these cheaper ant+ sticks, http://www.ebay.com.au/itm/251725519440" onclick="window.open(this.href);return false;
- cancan64
Postby cancan64 » Fri Jul 03, 2015 4:25 pm
I will find out soon... was going to use a blue tooth dongle but zwift doesn't work with Bluetooth so will see how this goes (currently using a Garmin ant+ off my Garmin 910xt but want to sell it)thecubical wrote:Anyone know if the KICKR is compatible with any of these cheaper ant+ sticks, http://www.ebay.com.au/itm/251725519440" onclick="window.open(this.href);return false;
- cancan64
Postby cancan64 » Mon Jul 06, 2015 10:07 am
I do have 4 days off the bike at the end of this week so will redo the ftp on the night of day 4 or morning of day 5
Postby macca33 » Mon Jul 06, 2015 10:57 am
Kickr has 4 modes:-
Sim - for Zwift & other software programs to enable the kickr to vary resistance according to feedback from the program, etc...
Erg - allows you to dial-in a target wattage and the kickr adjusts resistance to keep wattage there no matter your gear sleection/cadence
Level - you choose the level you want to work at - there are a number of power curves
Resistance - manually set a resistance that the kickr holds for you.
I reckon you may not be in the correct setting.
- cancan64
Postby cancan64 » Mon Jul 06, 2015 11:07 am
Postby Bluejay87 » Mon Jul 06, 2015 1:13 pm
Postby lock_ » Wed Jul 15, 2015 2:15 pm
Postby vosadrian » Wed Jul 15, 2015 2:41 pm
My wife uses Hurts ergo quite a bit. We are using the free version and logging with a garmin, as we have garmin ANT cadence and HRM sensors. Just recently we have started having heaps of dropouts on the garmin connection to the KICKR. It is almost unusable and drops out several times a minute causing the Garmin auto-pause to beep continuously. I realise this is likely to be either the Garmin or KICKR at fault, but I was just wondering if you had heard of this and found a solution? I suspect it started when we upgraded the KICKR firmware to 1.3.32, but can't be sure. We would of course be happy to pay to upload from Hurts direct to Strava, but unfortunately we have no way to get the cadence and HR data with Hurts unless we buy BLE sensors. Just wondering if you have heard of this before and have any suggested solutions. I wonder if the BLE connection to Hurts could interfere with the ANT output from the KICKR?
Adrian
Postby lock_ » Wed Jul 15, 2015 3:41 pm
The BTLE connections seem pretty rock solid for me, as in I can control my KICKR from the other end of the house. I suspect it's a KICKR/ANT+/Garmin issue. Hurts Ergo uses the same API as all the other apps, although this new version does contain an updated version of that API.
I get rare, say once per hour, speed drops (with Garmin auto pause). But these are accompanied by large spikes in resistance (jump from say 300w to 500w), I believe this is just my KICKR misreading speed. eg; it thinks I've slowed down and ramps up resistance when I really haven't. Lasts maybe a second. This to me seems more an issue internal to the KICKR than a connectivity problem. I haven't updated the firmware on it however.
In-app purchases in TestFlight beta builds are free (and will likely leave functionality unlocked in final release), so it's worth PM'ing an email address through. You could then do a test run recording on the Garmin and Hurts Ergo and do a comparison of the speed recorded via BTLE and ANT+. I'm interested to see if the same speed drops show up in both. This new version displays KICKR speed, so you probably don't even need to worry about digging through data files...
A simple test may be to position the Garmin down next to the KICKR and see if that helps. I know a few people run a USB extension cable with ANT+ dongle down next to their KICKRs to get Zwift going without issue. You could test for Bluetooth interference by using the KICKR without any apps running, make sure you kill (not just close) all Wahoo apps as they are pretty good at picking up a connection. Then see if the Garmin still reports speed drops. I'm not entirely sure this would stop all BTLE related transmissions from the KICKR though, it must broadcast a "I'm here" message continuously in order to be found by your phone.
Postby vosadrian » Wed Jul 15, 2015 4:43 pm
Thanks for your help. We love your app. It seems to be the easiest way to do intervals with the KICKR. My wife prefers to use an app on her phone that she can get going in a few seconds than to boot up a PC and debug IT issues on that before she can do her workout. We just have to debug the Garmin issues. I will PM you email addresses for the beta.
Thanks again!
- kb
Postby kb » Wed Jul 15, 2015 10:12 pm
Postby vosadrian » Thu Jul 16, 2015 9:17 am
- squizz_08
Postby squizz_08 » Wed Aug 26, 2015 6:49 pm
My Kickr (the second mind, first was already replaced under warranty) has gone from reading a little higher than my P2M power meter to reading at best 10w and at worst 30w lower.
Postby lock_ » Thu Aug 27, 2015 2:52 pm
Anyway, feels (in a very unscientific sense) that I 'lost' about 10w, and over a 20min interval that hurts. Of course it could have just been an off day(s).
- Spaniel
Postby Spaniel » Tue Sep 22, 2015 1:27 pm
The new Skuga app with whole Strava rides is just the thing to replace a rained out ride with a virtual version!
Postby lowrider » Thu Nov 26, 2015 9:56 am
I would only be buying it for structured training as I find it hard to get out and ride these days.
Postby Bluejay87 » Thu Nov 26, 2015 1:54 pm
- cancan64
Postby cancan64 » Thu Nov 26, 2015 5:50 pm
Postby Crawf » Sun Dec 06, 2015 8:57 am
Postby Bluejay87 » Sun Dec 06, 2015 7:50 pm
Only thing to check would be warranty. There is no software bundles.Crawf wrote:Would you be missing out on anything if you purchased one second hand? i.e would you not get any of virtual training stuff? I'm not sure what comes bundled with it for a first time purchaser?
