Torn a calf muscle
Re: Torn a calf muscle
Postby vander » Mon May 11, 2015 10:31 pm
http://www.physiosports.com.au/Paul_Visentini.html" onclick="window.open(this.href);return false;
Postby CKinnard » Tue May 12, 2015 12:00 am
you don't want to fall into stinking thinking like the problem is only one muscle.zill wrote:Sure will do.
But how bad is it to have damaged that muscle? Is that muscle likely to be permanently damaged or can it become stronger than before after being healed?
if you've overloaded and torn one muscle, you've usually got issues with multiple. i.e. a torn medial gastro or soleus is regularly associated with tibialis posterior pathology (tenosynovitis or tendinitis).
It's not rocket science to realize overloading a functional muscle group is unlikely to adversely effect only one muscle in that group.
I'll bet my hat if you get your tib post origin assessed it's tight, hard, and painful++, especially at the bony origin.
And that opens the door to seeing a podiatrist with a special interest in cycling to get cycling orthotics.
Postby zill » Tue May 12, 2015 1:20 pm
Yes, was confirmed by the physio as well.vander wrote:A strain is a tear in a muscle or tendon FYI.
The physio said that this was still possible from "over" cycling and it doesn't have to be from a big sprint, can be just overuse of the muscle possibly over a few days prior as well. Looking back, I shouldn't have done an extra 60 minute climb (while interval training on the climb) after time trailing up it prior.vander wrote: Neil is quite correct here. Little chance of doing it cycling although (very small chance) of doing it sprinting.
I have had a shop bike fit and it feels comfortable enough.
Postby zill » Tue May 12, 2015 1:41 pm
The only pain I can feel is from the lower and slightly inner calf. No pain elsewhere. The foot and ankle feels fine.
Postby NeillS » Tue May 12, 2015 1:57 pm
Postby zill » Tue May 12, 2015 4:10 pm
I've read your posts. This injury occurred one month ago and it still hasn't healed. One leg is still much weaker than the other. Surely that is a tear?NeillS wrote:Read my previous posts. It's almost certainly not damage in the sense of it taking time to "heal", although synovitis is a possibility it sounds like a simple overuse trigger point. Let us know how you go with waiting for it to heal, I'll be curious how you are going 6 weeks from now.
Do you work in this area of sports science?
Postby vander » Tue May 12, 2015 9:52 pm
A lot of things can cause a weaker leg.
I hope you get it sorted quickly.
FYI a complete achillies rupture surgically repaired and going well can be back on an exercise bike 4 weeks post (in a boot still). How quick does that make you think a grade 1 medial gastroc strain should take.
Postby zill » Wed May 13, 2015 8:20 am
The injured leg felt pain in the calf area in the first two weeks when riding and now just feeling weak after riding for 30 min or so.vander wrote:While it is impossible to diagnose over the internet it really doesnt sound like a tear.
The calf obviously is more serious than just being sore since that is usually healed in a couple of days at most. You think it is not a tear then what other possible calf injuries can there be that takes more than one month to heal?
My physio said a small muscle tear should take about a month to heal.vander wrote: FYI a complete achillies rupture surgically repaired and going well can be back on an exercise bike 4 weeks post (in a boot still). How quick does that make you think a grade 1 medial gastroc strain should take.
- JdM
Postby JdM » Wed May 13, 2015 9:00 am
Postby zill » Wed May 13, 2015 9:24 am
Was it a significant tear?JdM wrote:I've had a calf tear take up to 3 months to get anywhere near back to 100% - it can take time.
You said earlier in this thread that you tore it twice. Was it the same area? If so was it because you tried to get back to full training too early?
- JdM
Postby JdM » Wed May 13, 2015 9:32 am
It was a very bad grade one tear according to the physio. I ended up with a lot of scar tissue which then needed to be worked out by a massage therapist as well.
The injury was due to overload without the proper sort of maintenance, I've since addressed a lot of the underlying strength issues as well as the structure of my training.
As I said in my earlier posts, you need to trust your physio and if it isn't healing in the time frame they have advised, go back to them and have it reassessed.
Postby zill » Wed May 13, 2015 9:46 am
Were the scar tissue visible? If not how did the physio know about it?JdM wrote: It was a very bad grade one tear according to the physio. I ended up with a lot of scar tissue which then needed to be worked out by a massage therapist as well.
Was it basically that you tried too much and too hard (compared to what you are use to doing) on one day?JdM wrote: The injury was due to overload without the proper sort of maintenance
- JdM
Postby JdM » Wed May 13, 2015 11:27 am
The first one was nowhere near as bad, but it was still slow. I can't remember exactly, but it would have been 6 weeks or thereabouts from memory.zill wrote:Did both legs take 3 months to heal each or 3 months combined time (1.5 months for each leg)?
Firstly - I'm not a physio or any sort of sports medicine professional. However my understanding from what I have read and the advice I have received is that as the muscle repairs itself the scar tissue is generated as part of this process. You can't see it, but a sports medicine professional such as a massage therapist or physio will be able to feel it while doing deep tissue work.zill wrote:Were the scar tissue visible? If not how did the physio know about it?
The scar tissue doesn't have the same 'elastic' type properties that your muscle fibers do, so it can lead to reduced range of motion and strength. What happened to me was I went back to sport (I was against the clock to be ready for something) and when I took off into a sprint late in a match I felt a pop in the same spot of the calf - It felt exactly like I'd done the calf again however it settled after about two days. Both my physio and massage therapist agreed that I had 'snapped' some of the scar tissue, at which point we got stuck into trying to work it out of the muscle as much as possible.
I can't stress enough though, this was my experience, which doesn't necessarily translate to your situation.
Kind of. It was a combination of things. Lack of conditioning, progressing too fast without building up volume and some bio mechanical issues which were being caused by lack of strength in certain areas - I injured myself running, but these things also apply to cycling, or any other sport for that matter.zill wrote:Was it basically that you tried too much and too hard (compared to what you are use to doing) on one day?
But as I said, you need to go and speak to someone who is qualified to deal with this sort of thing in the flesh. If you can't get this sort of information and advice from your current physio, find a new one.
Postby zill » Wed May 13, 2015 11:42 am
He does give me a message and recommend exercises to do during the week.
Postby CKinnard » Wed May 13, 2015 10:56 pm
I saw a guy 2 years ago from our CC who did a Grade 1 calf tear. I worked it over 6 weeks, then strapped him to start grading his strength and conditioning, and return to sport...12 weeks after RTS, he goes in his first race and feels a twinge. (incidentally, I wanted him strapped but he didn't show up). That took him back to where he was 3 months earlier.
He kind of lost faith in me after that, and went off and saw a host of other physios. Eventually he came back and I said he should see a sports physician and get a MRI. Personally I felt he had poor recovery capacity possibly related to gluten intolerance and ongoing intestinal inflammation. Anyway, he was not impressed with the sports physician who didn't add much to what he'd already been told. I didn't see him riding for about a year after that...had a chat to him recently at the training track, and he'd just had 10 months off the bike altogether to get over the calf issue and gut problems.
The lesson in the story is not everyone tears muscles when they ride hard...so it pays to look for other reasons why you might be prone to tears. Nutrition, sleep, hydration, lumbar and sciatic nerve issues, are all reasons why muscles may be vulnerable. Those who casually dismiss this just don't have much of a clue on the human body.
Postby zill » Wed May 13, 2015 11:24 pm
Thanks for sharing. Looks like I may be out of it for a long, long time but hopefully not. Definitely torn the muscle from an extremely hard ride, one which I obviously wasn't prepared for. Other issues are obviously on the table like nutrition and sleep.CKinnard wrote:I can vouch for JdM's experience. That's very very common and he's done a good job of describing the repair process.
- kb
Postby kb » Thu May 14, 2015 7:38 am
Postby vander » Thu May 14, 2015 8:11 am
I am just going to reiterate here, a minor calf tear should not keep you of the bike for long treated properly.zill wrote:
Postby zill » Thu May 14, 2015 6:11 pm
Postby CKinnard » Thu May 14, 2015 8:11 pm
define properly, as in a full rehab protocol that applies equally to all minor calf tears.vander wrote:I am just going to reiterate here, a minor calf tear should not keep you of the bike for long treated properly.
if you strap, explain your strapping technique/s.
if you ice, when you stop icing.
what criteria do you use to progress exercise? pain? palpation? if strength, how do you quantify? time? please explain.
- AUbicycles
- Site Admin
Postby AUbicycles » Sat May 16, 2015 11:01 pm
The point is that while it may be possible to delve right down into this, it will be difficult to quantify to that satisfaction of all. It may however be beneficial however when discussing this to include in a 'please' when requesting feedback or information as a courtesy.
Postby vander » Sun May 17, 2015 1:10 pm
This is perfectly correct and why I wont go into what exactly I would do for this patient.AUbicycles wrote:CKinnard and vander, lets keep in mind that the discussion will never replace qualified medical advice and because of intrinsic differences, what works for one person may not work for another.
- Xplora
Postby Xplora » Sun May 17, 2015 7:42 pm
Good luck. Injury sucks
Postby zill » Sun May 17, 2015 11:32 pm
Even if the load is really unbalanced? For example, for training mainly doing short intervals on the trainer (burning less than 6000 kj each session) than ride all day outside burning more than 16,000 kj including a TT effort plus intervals?Xplora wrote:You shouldn't be getting injuries when the bike is fit right.
What I've learned is to do base training as well as interval training at the same time. Hence to average about 500km a week.
Slowly improving with the injury. Probably will be light pedaling for another 3 weeks. Treating this period as an off season.
- Xplora
Postby Xplora » Mon May 18, 2015 9:30 am
Look at your training, and take the injury as a learning experience. Most of the value in the PMC is figuring out what is good for YOU. I get away with limited Z2 riding for a while but just racing (Z3 with a ton of Z6 and Z7 efforts) eventually destroys me.
