Breaking through FTP
Postby Mca.and » Sat Dec 12, 2015 8:25 am
Background is I have been riding fairly consistently over the past 2 yrs (logged 12,000km in 2014 and will be about 14,000 in 2015). I do a mix of racing (A crits and A/B road) and have seen an increase in FTP from about 280/290 to about 330/340. MY training consists mainly of long slow stuff. A typical week may be 350-450km (around 15 hrs) with some of the following thrown in (either a OR b OR c). All sweet spot and vo2 sessions I do on the kickr.
a. Race and 1-2 sweet spot sessions
b. Race and a harder session (vo2)
c. 1-2 sweet spot sessions
I have seen a bit of a plateau in FTP over the past 6 months or so. I just cant seem to significantly bump it up.
I was thinking of trying an increase sweet spot approach. i.e. doing 3 sweet spot sessions at 90% FTP from 40min- 80 min duration per session.
What successes have other people had in raising their FTP with a significant training background (i.e. you have been riding seriously for 2 or more years). I dont really have time for more than 16hrs a week on the bike.
- g-boaf
Re: Breaking through FTP
Postby g-boaf » Sat Dec 12, 2015 1:02 pm
I took the sweet spot approach to get mine up to just over 300w - just doing more of that and mixing it up with some slow/recovery rides.
Postby Cul » Sat Dec 12, 2015 2:52 pm
During the hard weeks I would be aiming to do 3 blocks of 3 or 4 days of intervals, everything from 15sec on/off to 8mins (AT) 110% on the off days take it real easy!..
Change is the spice of life, some times that's all it takes to get over the plateau!
I think I have the same problem, but requires the opposite solution, 3 years of time crunched training has me thinking volume is what I need!
- Xplora
Postby Xplora » Wed Dec 16, 2015 5:38 pm
I've been really getting good results from my weight lifting by cycling through sets of 12, 8, 5 and just did 3 a week ago. I only do 2 sets, after 4 sets was killing me and I couldn't recover to ride.... and the actual weights I was lifting weren't going up too fast. But I keep the volume manageable now, and use the variation of the reps and weight to create variety in the program... and I don't let myself get "too far" in the hole.
Why not do another VO2max session for 3 in a week? Or do a sprint session? Climbing session? Shake it up.
Ultimately, your program is working, you are racing A grade. You have to increase intensity and/or volume and if you can't survive that, by nutrition or rest, then you're maxed out.
Postby ajmit3 » Tue Dec 22, 2015 6:13 pm
- Xplora
Postby Xplora » Wed Dec 23, 2015 5:29 pm
- 3DKiwi
Postby 3DKiwi » Wed Dec 23, 2015 6:35 pm
Postby thearthurdog » Wed Dec 23, 2015 6:57 pm
- ft_critical
Postby ft_critical » Wed Dec 23, 2015 7:34 pm
If you look at the OP's original post his FTP was 250 or thereabouts. I was skeptical, but if you look through his 20 posts, there is a pretty clear description of how he did it. Probably he should be teaching us. I think the capped volume will prevent further improvements.thearthurdog wrote:First of all, a gain of 280/290 to about 330/340 I think is very impressive! I love sweetspot on the indoor trainer. Can't beat it.
- Alex Simmons/RST
Postby Alex Simmons/RST » Thu Dec 24, 2015 7:12 am
Some general principles:
- training gains slow and become harder to obtain as the years of consistent training roll on, but they are still attainable via various mechanisms, mostly via gains in fractional O2 utilisation at threshold and efficiency
- everyone is different in how they respond
- specificity matters
- physiological gains are only one part of the performance improvement strategy, there are many other areas of potential improvement
- there are also many individual factors involved, such as diet, rest of life factors, stress, recovery and sleep, medical, bike set up, psychological, experience, strategic and tactical nous, goals and so on.
- when things stagnate, to break through generally means a change is needed but deciding on what isn't always obvious, although in some cases it's the change of routine that helps as much as what that change is
Postby zill » Sat Dec 26, 2015 4:26 pm
Doing more sweet spot rides will just make you better at ... doing sweet spot rides. If you want to increase your FTP, you need to train at over 100% of your FTP. This will mean shorter intervals at higher intensities.
Postby dalai47 » Sat Dec 26, 2015 11:23 pm
Incorrect. You can push as well as pull your FTP up...zill wrote:If you want to increase your FTP, you need to train at over 100% of your FTP.
Postby zill » Sat Dec 26, 2015 11:36 pm
Postby dalai47 » Sat Dec 26, 2015 11:46 pm
Postby Aussiebullet » Sun Dec 27, 2015 7:17 am
The less time you have to train the harder you need to go or eventually progression will stop, hence the reason very high level athletes tend to spend a lot of time training at lower intensities as well as mixing in some time at higher intensities.
Postby zill » Sun Dec 27, 2015 8:55 am
dalai47 wrote:There are many ways to raise FTP. You don't need to do efforts above FTP to raise FTP. Efforts just below FTP can also raise FTP -by 'pushing' it up.
Ok, sweet spot riding is good to build endurance and lift anaerobic threshold. I'd like to believe that a combination of above FTP and sweet spot riding should be done. However, for incremental gains in FTP after the initial gains from "simply riding" I'd say above FTP intervals is far more important. Hence for the OP, intervals above FTP should be very important.Aussiebullet wrote:Yep SST works just fine at raising FTP and 20min power as does L2, L3 and L4. They are all targeted at raising aerobic capacity.
- Alex Simmons/RST
Postby Alex Simmons/RST » Sun Dec 27, 2015 11:33 am
I would say that nobody can answer the question of what's right for the OP. There is simply insufficient information upon which to make definite statements.zill wrote:dalai47 wrote:There are many ways to raise FTP. You don't need to do efforts above FTP to raise FTP. Efforts just below FTP can also raise FTP -by 'pushing' it up.Ok, sweet spot riding is good to build endurance and lift anaerobic threshold. I'd like to believe that a combination of above FTP and sweet spot riding should be done. However, for incremental gains in FTP after the initial gains from "simply riding" I'd say above FTP intervals is far more important. Hence for the OP, intervals above FTP should be very important.Aussiebullet wrote:Yep SST works just fine at raising FTP and 20min power as does L2, L3 and L4. They are all targeted at raising aerobic capacity.
Postby dalai47 » Sun Dec 27, 2015 11:36 am
I though prefer doing my 20min intervals at 95-100%. I find these a little easier to recover from so can do my next hard session sooner, which is increasingly important as I age. Also more likely to do the session as it hurts just a little less than riding 2*20 above FTP, so mentally easier to prepare for and do.
If doing shorter intervals I will do them at a higher percentage.
Postby zill » Sun Dec 27, 2015 8:07 pm
Usually, I will need one full rest day after a hard interval day. Are you suggesting even one full rest day is not enough after a hard intervals day?dalai47 wrote:Not saying there is no benefit to above FTP intervals.
Not all the time but on average I think if you are not hurting (in a good way i.e. not as a result of an injury) yourself enough than you won't improve as much. Or at least the improvements won't be as fast as you would like.
- g-boaf
Postby g-boaf » Sun Dec 27, 2015 8:23 pm
I remember also some good advice for following up those low rpm intervals (55-65rpm) with a 1 hour easy ride shortly afterwards, just spinning over the legs, keeping the speed and effort low. It helps to stop sore legs quite well.
Same with another rider (who shall remain anonymous) who would follow up a gym session with a 45-60min easy ride for much the same reason.
Postby zill » Sun Dec 27, 2015 8:26 pm
Yes I know and it shouldn't matter how hard you trained the previous day.g-boaf wrote:The rest day doesn't always mean doing nothing, you might just get out and go for a slow ride, easy gear and low power. 1.5 hour would be plenty for that.
Postby Cul » Mon Jan 04, 2016 4:21 pm
It seems one of your original questions wasn’t answered; for some back ground I rode MTB competitively from 16yo to 25yo, enjoying some success at local and state level, placing in a few endurance races. However I stopped riding in 2008 due to a shoulder injury. I began riding again in late 2012, in 2013 I started MTB racing and late 2013 I started road racing, the last 3 years have been quite “time crunched” due to having young children, working long hours, etc… I am hoping this year I can get in more volume, lose some (more) weight and push the FTP w/kg higher.Mca.and wrote: What successes have other people had in raising their FTP with a significant training background (i.e. you have been riding seriously for 2 or more years). I don’t really have time for more than 16hrs a week on the bike.
Mca.and's figures aren’t too dissimilar to mine over a similar period, each test completed towards the end of each year.
2013 - ~9,500kms - 286w
2014 - ~12,690kms - 333w
2015 - ~11,780kms - 339w (spent 2 months off due to injury)
Postby Mca.and » Tue Jan 05, 2016 12:44 pm
I have already started the sweet spot approach so I will keep building on that and will let you know how I go after a month. It will probably take a bit longer than that for significant adaptions but I will release my FTP test results. It has worked well in the past so I anticipate with the right progressive overload I should be able to see an increase.
Numbers aiming for: 350W ftp and 1700w 5s power. Thats an increase of about 10w and 150w respectively.
Training aiming for: 305-310W (sweet spot) for 80-100 minutes. Should provide a solid amount of specificity for the road season. Racing crits is enough training at intensity atm
Postby cerb » Fri Feb 05, 2016 3:35 pm
If you do the same thing repeatedly and your FTP has plateaued, your body obviously thinks it can do enough to meet the demands without needing to improve. So if you've been doing mostly sweet spot, try some HIIT or vice-versa! As mentioned previously, you can push or pull your FTP up. If one method isn't working, try another!
Also, "Simply Riding" provides very limited chance for improvements, particularly when you guys are already doing 10,000+km a year! A team mate used to do 16-20k km a year and was pretty average on the bike because they were basically all 'trash' ('just riding') km. As soon as he put in some specific training to build his FTP and short power intervals he became handy VERY quickly!
- Xplora
Postby Xplora » Fri Feb 05, 2016 4:53 pm
