- green leafy veggies, legumes and nuts for calciumjlh wrote:Squashed, suggest you educate yourself instead of repeating the marketing drivel of the meat and dairy industries.Squashed wrote:..... personally I found vegan was too extreme. you had to take so many supplements just to get the nutrients you need. No dairy means calcium tablets or loads of almonds. Mushrooms for protein if you can tolerate them, otherwise its corn based protein....
- protein from grains, legumes, nuts and veggies
- mushrooms are supposedly for vitamin b but is turns out that is only if you eat the manure they are grown in!
The only supplement you really need is B12 and also zinc if you can't be bothered eating enough nuts, legumes, grains and green leafy veggies.
Of greater concern to everyone is selenium. Australian soils are pretty low in selenium, especially in WA. However, taking supplemental selenium is not recommended either. It is much better to get selenium from food.
http://www.drfuhrman.com/shop/multi_details.aspx" onclick="window.open(this.href);return false;
Oops. I forgot Vitamin K2, which is low in plant foods.
http://www.drfuhrman.com/library/healthydiet_multi.aspx" onclick="window.open(this.href);return false;
