Tips to get consistent sleep
Postby zill » Tue Jan 13, 2015 4:22 pm
Re: Tips to get consistent sleep
Postby CKinnard » Tue Jan 13, 2015 5:13 pm
- drink 500mls water immediately you wake up, and before breakfast, do the same before lunch and dinner. stop drinking an hour before lights out. The idea being to hydrate your body as soon as you get up, which should help you not feel dry after 7pm and wanting to drink.
- make sure you pre and post hydrate adequately around exercise.
- no caffeine after 4pm.
- try not touching alcohol for a month and seeing what diff it makes.
- regularly stretch and breathe.
- practise mind calming techniques before bed. i.e. forget the world and immerse yourself in a book, don't watch tele or utube for entertainment in the 30 minutes before sleep.
- strengthen your lower back and core, practise good posture, sleep on a firm bed. these things will reduce chances of a mechanical cause of neurogenic bladder.
- if prone to anxiety, repeat mind calming stuff...and get your life priorities and goals sorted. always go to bed with a plan to do something first up in the morning i.e. a bike ride to coffee or a good exercise session. This can help you settle to sleep better as tomorrow won't feel as drab.
Postby zill » Tue Jan 13, 2015 5:30 pm
CKinnard wrote:If you are under 35, you really shouldn't be regularly waking up to go to the toilet, even once a night.
I'm usually pretty good with not drinking too much fluids before going to bed.
How much damage (to sleep) does surfing the web while in bed do (in the half hour before falling asleep, note that I usually don't have trouble getting to sleep)?
At the moment my bed is average but decent. How much of a difference would a top of the range bed make?
Postby dalai47 » Tue Jan 13, 2015 5:38 pm
http://www.abc.net.au/news/2013-07-01/a ... rs/4790448" onclick="window.open(this.href);return false;zill wrote:How much damage (to sleep) does surfing the web while in bed do (in the half hour before falling asleep, note that I usually don't have trouble getting to sleep)?
and
http://www.huffingtonpost.com/2014/12/2 ... 72828.html" onclick="window.open(this.href);return false;
Postby Parker » Tue Jan 13, 2015 5:42 pm
Tense your calves x 3
Tense your bum x 3
Squeeze hands x 3
Tense arms x 3
Tense face (squish) x 3
I hold each for a count of ten.
Another tip is ear plugs and face mask, I find that helpful.
Postby zill » Tue Jan 13, 2015 6:02 pm
dalai47 wrote:http://www.abc.net.au/news/2013-07-01/a ... rs/4790448" onclick="window.open(this.href);return false;zill wrote:How much damage (to sleep) does surfing the web while in bed do (in the half hour before falling asleep, note that I usually don't have trouble getting to sleep)?
and
But would they impact more on getting to sleep in the first place rather than about waking up prematurely and then not being able to sleep again? Or maybe it's the second time trying to sleep that the devices really do their damage?
Will try switching off computers and phones at least 1 hour before bed time to see if that makes a difference.
Postby dalai47 » Tue Jan 13, 2015 6:12 pm
From the huffington post link.
iPad readers took longer to fall asleep, felt less sleepy at night and had shorter REM sleep compared to the book readers, researchers found. The iPad readers also secreted less melatonin, which helps regulate your sleep.
Postby Parker » Tue Jan 13, 2015 6:20 pm
If you can't sleep. It's best to get up after 20 minutes and do something else
- Thoglette
Postby Thoglette » Tue Jan 13, 2015 6:35 pm
(good stuff deleted)CKinnard wrote:If you are under 35, you really shouldn't be regularly waking up to go to the toilet, even once a night.
Watch your salt intake carefully too. If you wake up both thirsty and "needing to go" that's probably salt/dehydration related. (INAQuack)
Postby zill » Tue Jan 13, 2015 7:07 pm
Definitely read both articles.dalai47 wrote:Did you actually read either article?
It's just that they really stress the fact that it's about harder to get to sleep.
Also I didn't associate "less sleepy at night and had shorter REM sleep" to waking up in the middle of the night although in thinking about it a bit more, it means if there is only a little incentive to wake up like going to the toilet then it means actually waking up rather than sleeping through it.
Postby CKinnard » Tue Jan 13, 2015 9:22 pm
I recall you are not too overweight. But if you are, further weight loss may reduce the urge to urinate at night.zill wrote:I'm usually pretty good with not drinking too much fluids before going to bed.
The brain has similar requirements to muscle. When you use muscle even at low intensity for long periods, it benefits significantly from being able to rest completely. The brain is the same. We are designed to use our brain an hour or two, then back off for a while, and repeat.....at night we need to respect that calming the mind before sleep more reliably leads to deeper better quality sleep. If you need a strong motive for good "sleep hygiene", just remember exercise is purely a stimulus for the body to adapt to being better at exercise. Much of the actual growth and remodeling of muscle and other systems occurs during nrem sleep, especially the third episode. Regularly going to bed with a brain preoccupied with trivia or worldly problems, will compromise your athletic gains and your optimal long term health.
As for beds, you don't need top of the range (meaning expensive). The first thing to do is get your body fat down to healthy athletic, so you don't wear your bed out sooner. I advise people to buy a firm budget priced mattress, stick it on a slat base, turn it regularly, and toss it as soon as the support mechanisms start to fail. This might be as soon as 4-5 years, but it will still be cheaper than the most expensive you beaut beds that cost 15x more and begin to lose their support within 7 years.
- Semar
Postby Semar » Tue Jan 13, 2015 11:55 pm
Give Progressive Muscle Relaxation a try. There are plenty of guides here in Cyberville, just pick one that appeals. Be sure that you choose one that finishes with you 'feeling' the muscle groups you have relaxed in a methodical survey of your body. Over time, your 'virtual' muscle relaxation process will improve as you become more in touch with the muscles that hold tension. When you have had a piss, go back to bed and do the survey. A relaxed body equals a relaxed mind.
The benefits of PMR are that it will relax you for better sleep and in addition give you a process of returning to sleep.
Postby Parker » Thu Jan 15, 2015 4:47 pm
- flashpixx
Postby flashpixx » Thu Jan 15, 2015 4:54 pm
Parker wrote:Also going to bed and waking up at the same time each day where possible, also ensuring that you only sleep (and have sex) in your bed, that reading and computers should be elsewhere.
+1 to both of these.Parker wrote:Another thing that is good is magnesium, I take that every day and I tend to sleep better, basically I read an article somewhere that it helps your muscles relax and that's what I needed. It might help you sleep through the night.
Riding: Trek Domane SLR 7
- jules21
Postby jules21 » Mon Jan 19, 2015 1:26 pm
- skull
Postby skull » Wed Jan 21, 2015 9:02 am
I probably drink 2-3 litres during the day but stop by around 5PM and the only drink I have after that is a protein shake around 9PM (with about 300ml of water). I also find any wizzes after 6PM are yellowish rather than clear (like I am dehydrated), I am also very overweight at the moment but am working on fixing that again. So annoying.
- Bon
Postby Bon » Thu Jan 22, 2015 12:16 pm
- casual_cyclist
Postby casual_cyclist » Wed Jan 28, 2015 7:14 pm
You may want to get that checked out. I would.skull wrote:I have been on a diet for the last couple of weeks and have also started to train consistently again. I am getting up to go the the loo for a wizz at least 2-3 times a night (even if I go just before bed) and upon waking I am usually busting again.
http://sleepfoundation.org/sleep-disord ... s/nocturia" onclick="window.open(this.href);return false;
- skull
Postby skull » Wed Jan 28, 2015 7:38 pm
Interesting I was up 4 times last night.casual_cyclist wrote: http://sleepfoundation.org/sleep-disord ... s/nocturia" onclick="window.open(this.href);return false;
Patients with severe nocturia may get up five or six times during the night to go to the bathroom.
- casual_cyclist
Postby casual_cyclist » Wed Jan 28, 2015 8:40 pm
Not suggesting you have nocturia as Dr Google is notorious for wrong diagnoses. However, I was hoping the information in the article might prompt you to have your situation checked out by a medical professional. Chances are it is nothing but seriously, go see someone.skull wrote:Interesting I was up 4 times last night.casual_cyclist wrote: http://sleepfoundation.org/sleep-disord ... s/nocturia" onclick="window.open(this.href);return false;
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
