Donating blood and commuting
Postby gresford » Tue Feb 17, 2015 3:42 pm
However I commute by bike 5 days/week so before I go for the first session I would be interested to hear other peoples experiences of how giving blood effects them re cycling.
Since you can only donate every three months anyway I'll just drive or get the train on those days but has anyone found it affected them and kept them off the bike for more than one day?
My commute is 13kms (Earlwood to Sydney CBD).
- im_no_pro
Re: Donating blood and commuting
Postby im_no_pro » Tue Feb 17, 2015 4:12 pm
If(or when, depending on your blood type) they ask you do to Plasma/Platelets follow the same approach. I have never had an issue with either whole blood or Plasma but Platelets knocked my on my proverbial when I did it for the first time a couple of weeks ago. Wasn't allowed out of the chair for about 40 minutes and didnt feel 100% until about 30 hours post donation. Definitely wouldn't have been riding. Suffice to say they politely suggested I stick to Plasma.
Postby dalai47 » Tue Feb 17, 2015 4:21 pm
I commute the same day after donating, I just take it easy...
- CXCommuter
Postby CXCommuter » Tue Feb 17, 2015 5:03 pm
There was a freak out by the doctor when I did an off the cuff medical- lots of tests later (including front and rear inspections for bleeding/cancers) I was advised not to give full blood anymore and was on iron supplements for just over a year to regain my iron stores.
Would be a good idea to get iron stores checked just to make sure.
Postby Scott2468 » Tue Feb 17, 2015 5:43 pm
Much to my delight, we got the convenience and time saving of getting a bus on the work site.
Had to fill in the standard form. On reading this, the nurse had a fit and wouldn't take blood because of the 30 km bicycle commute. Tried this a second time, same result.
I guess you can "change" what you write but I just gave up on that one.
- KGB
Postby KGB » Tue Feb 17, 2015 5:56 pm
Postby nezumi » Tue Feb 17, 2015 7:03 pm
For the first time I would second (third? fourth?) the call of PT or have someone drive you - if you've never donated, you don't know how your body will respond.
I have to remind them every time I got that I cycle daily, as my resting heartrate is around 45bpm - this scares them for a moment, then they are OK.
Once you have donated, they will recommend that you don't ride home. If you do (after the first time, that is!), take it easy.
2015 Merida Scultura 5000
Postby lobstermash » Tue Feb 17, 2015 7:10 pm
Postby nezumi » Tue Feb 17, 2015 7:15 pm
- Mulger bill
Postby Mulger bill » Tue Feb 17, 2015 7:17 pm
I'd suggest for your first few times you take PT, just in case. It will probably take 3-4 donations of whole blood before you can accurately figure your reactions out.
Personally, if I'm riding that day, I take it easy before and after, I've only had one wobbly and I put that down to insufficient hydration and pushing too hard in the morning before heading in.
You'll be right, just listen to your body for a few days afterwards and work out what works best for you.
- ColinOldnCranky
Postby ColinOldnCranky » Tue Feb 17, 2015 7:51 pm
For about twenty years the red cross thought Iwas anaemic as my red cell count was always marginal, often being sent home. It was only one day that a nurse enquired if I had done vgorous exercise recently and then it all fell into place. I was playing, training and coaching squash six day a week plus fitness work on the bike and running.gresford wrote:I have been intending to donate blood for ages and am now finally doing something about it.
In all my years and hundred and something donations I have never has an issue after donating (until just recently something unrelated to this thread). Presumably I was a little more tired but I was never aware of it.
Leave a little time between leaving their chair and saddling up and take it a little easy. Also have a bit of water if you are riding a distance as you will be more prone to dehydration.
- CXCommuter
Postby CXCommuter » Tue Feb 17, 2015 8:15 pm
They check haemoglobin- ie iron in blood, not blood stores (Ferritin) which is your back up supply of iron.KGB wrote:I thought they checked iron levels before donation? Isn't that the finger prick test they do?
- rolandp
Postby rolandp » Tue Feb 17, 2015 11:48 pm
Take it slow, and drink lots of water.
- bigfriendlyvegan
Postby bigfriendlyvegan » Tue Feb 17, 2015 11:52 pm
- ColinOldnCranky
Postby ColinOldnCranky » Wed Feb 18, 2015 12:57 am
It is almost inconceivable that the nurse did not know the reason. I'd suggest that there was a communication misunderstanding and so she was not looking to answer what you asked. She would certainly know what the effect is of exercise.bigfriendlyvegan wrote:I always cycle before and after giving blood. The last time, though, the nurse person said that I shouldn't exercise before donating. I asked her why, but she couldn't explain it, just that it was what she was told. Weird.
Exercise depletes your red cell count. However you can always suggest that you are OK for Plasma or Platelet donations on the day. Might take longer however.
You replace platelets and plasma within a couple or three weeks. Red cells take a couple of months.
- bigfriendlyvegan
Postby bigfriendlyvegan » Wed Feb 18, 2015 11:26 am
Interesting response. How long should you wait after exercising to donate? I ride everyday and it seems silly to me that this would exclude me from donating.ColinOldnCranky wrote:It is almost inconceivable that the nurse did not know the reason. I'd suggest that there was a communication misunderstanding and so she was not looking to answer what you asked. She would certainly know what the effect is of exercise.bigfriendlyvegan wrote:I always cycle before and after giving blood. The last time, though, the nurse person said that I shouldn't exercise before donating. I asked her why, but she couldn't explain it, just that it was what she was told. Weird.
Postby lobstermash » Wed Feb 18, 2015 12:56 pm
I'd have thought that, if anything, exercising beforehand would be beneficial for donating - gets the blood flowing more freely and the veins poking out. I've never been turned away from an appointment, even when I've turned up on the bike and forgotten to wear baggies. I occasionally get asked if I've got a long way to get home on the bike, and a simple nonchalant 'no', or an 'I'll go very easy' satisfies their concern.bigfriendlyvegan wrote: Interesting response. How long should you wait after exercising to donate? I ride everyday and it seems silly to me that this would exclude me from donating.
- ColinOldnCranky
Postby ColinOldnCranky » Wed Feb 18, 2015 1:24 pm
Next day? Immediately after riding in. How long is a piece of string? Often I would ride the whole way in and still be acceptable mostly.bigfriendlyvegan wrote:Interesting response. How long should you wait after exercising to donate? I ride everyday and it seems silly to me that this would exclude me from donating.
After a few donations you will soon know if your red cells are low as they test the red cell count with that pin-prick they give you during interview. If you, like me, are often marginal then they may still get you connected up and take a better test, bleeding off a small jar of blood and sending it for immediate testing. Surprising how often the initial prick-test gets it wrong.
And, as I said before, even if you are habitually on the low side you will still be ok for plasma and platelet donations via aphoresis.
For the record, for an extended time I reduced the aount of exercise a fair bit and my red cell count went right up there where it should be.
Problems with low red cell counts are greater for women. (That makes Shelley Taylor Smith's achievements even more amazing.)
- bigfriendlyvegan
Postby bigfriendlyvegan » Wed Feb 18, 2015 5:07 pm
- im_no_pro
Postby im_no_pro » Wed Feb 18, 2015 5:16 pm
Anyone who has eaten the recalled products is excluded for 2 months based on what I heard this morning.bigfriendlyvegan wrote:OK, we'll find out next Friday when my next donation is scheduled, though I may be excluded for eating frozen berries!
- Mulger bill
Postby Mulger bill » Wed Feb 18, 2015 6:25 pm
Glad I stay away from them then, booked in for the first week of March for number 73.im_no_pro wrote:Anyone who has eaten the recalled products is excluded for 2 months based on what I heard this morning.bigfriendlyvegan wrote:OK, we'll find out next Friday when my next donation is scheduled, though I may be excluded for eating frozen berries!
- bigfriendlyvegan
Postby bigfriendlyvegan » Wed Feb 18, 2015 9:01 pm
I didn't eat the Nanna's one, rather the sub brand one (Creative Gourmet) which wasn't part of the original recall, but has been added just in case. I'll contact the Red Cross tomorrow and ask them. Bloody nuisance.im_no_pro wrote:Anyone who has eaten the recalled products is excluded for 2 months based on what I heard this morning.bigfriendlyvegan wrote:OK, we'll find out next Friday when my next donation is scheduled, though I may be excluded for eating frozen berries!
- im_no_pro
Postby im_no_pro » Wed Feb 18, 2015 10:53 pm
Anyone who has donated since Nov 1 should contact them only if you have had the originally recalled product (at this stage all confirmed cases are linked to that product and they need to id the most at risk existing donations in the system). All recalled products put you on the 2 month exclusion list. Id say your on the benchbigfriendlyvegan wrote: I didn't eat the Nanna's one, rather the sub brand one (Creative Gourmet) which wasn't part of the original recall, but has been added just in case. I'll contact the Red Cross tomorrow and ask them. Bloody nuisance.
- bigfriendlyvegan
Postby bigfriendlyvegan » Wed Feb 18, 2015 11:45 pm
I wouldn't be surprised. The annoying thing is that I normally eat Aussie grown berries I get from the markets, but they get quite expensive. I only bought frozen berries for the first time a few days before the recall, sort of like deciding to go on a cruise on that new Titanic ship you've heard so much about.im_no_pro wrote:Anyone who has donated since Nov 1 should contact them only if you have had the originally recalled product (at this stage all confirmed cases are linked to that product and they need to id the most at risk existing donations in the system). All recalled products put you on the 2 month exclusion list. Id say your on the benchbigfriendlyvegan wrote: I didn't eat the Nanna's one, rather the sub brand one (Creative Gourmet) which wasn't part of the original recall, but has been added just in case. I'll contact the Red Cross tomorrow and ask them. Bloody nuisance.
Postby gresford » Wed Feb 25, 2015 1:38 pm
No berries were consumed by me, the nations blood supply is safe!
