Hi RhapsodyX,
Baalzamon indicated earlier it was hsCRP. His earlier cholesterol tests seemed to indicate he was less suited to the keto style of diet than you. But as you know, the most accurate indicator was going to be an inflammation test. Just out of curiosity since your other cholesterol numbers are so good, have you had your hsCRP tested? I'd assume not, being younger.
Previous post edited for net carb values. I used to use net values but found most others used gross values, so now I think in gross terms usually.
As you know, low carbers see carbs as the focus, high carbers see fat as the focus. So I can understand why the chart is written the way it is. I'm just adding what high carbers or PB people would find interesting to see. I think we can agree that a large percentage of both fat and carbs together with plenty of processed foods are going to give the worst results for most. As the world wide export of the American diet is showing.
The Ornish diet isn't vegan and that is why the protein is higher. I think we also can agree that high protein is not ideal. From the pics of Ornish, his body shape isn't ideal either. When my (plant) protein was up to 1.4g/kg RW, I appeared to be adding weight too.
Hi Baalzamon,
Thanks for posting the result.
Urinating competitions aside, I hope you sort it out. Make sure you get another test if you can while feeling healthy, to confirm. It may also be some other cause for the inflammation, rather than arterial. If you can't get another hsCRP test, or it comes back high again, it's probably worth getting a CT coronary artery calcification screening test done
without the (radioactive) contrast, just to know for sure. The result that comes back is just a number. Working with older people, I know a number of people who have had it done already.
If it all goes badly then at least you know of a
diet that can stop atherosclerosis. Keto isn't going to suit everyone long term.
Come over the the light side.
(Or the dark side to you)
