How accurate is max heart rate calculation?
Postby jerrah » Mon Oct 19, 2015 7:55 pm
My max heart rate is calculated as 185 yet on a recent ride I topped 195 and spent a reasonable amount of time really pushing it. I didn't feel like I was pushing my heart at the time. Is this likely to be an accurate number or is my Garmin strap inflating my numbers? Should I be riding slower even though I feel fine?
- RonK
Postby RonK » Mon Oct 19, 2015 8:01 pm
For a more accurate determination, ask your GP about doing an exercise stress test, and have your heart function evaluated at the same time.
Re: How accurate is max heart rate calculation?
Postby softy » Mon Oct 19, 2015 8:16 pm
People don't always know their heart or condition. I had a significant 30% mitral valve leak and didn't even know it. I only found out when i had a medical applying for a new job. So i would suggest before pushing your heart rate get a medical professional to give you advice. Have a full check done too. Better safe than sorry.
People do die in runs and cycling events from heart conditions.
- Derny Driver
Postby Derny Driver » Mon Oct 19, 2015 8:53 pm
A mate of mine for example 220 - 48 = 172, his real max is over 200 (HIGHER)
Chris Froome, 220-30 = 190, his real max is 174. (LOWER)
- Alex Simmons/RST
Postby Alex Simmons/RST » Mon Oct 19, 2015 9:22 pm
Postby kenwstr » Mon Oct 19, 2015 11:27 pm
Ken
- clackers
Postby clackers » Tue Oct 20, 2015 8:04 pm
But it doesn't describe *you*.
- Duck!
Postby Duck! » Tue Oct 20, 2015 11:33 pm
Postby Top_Bhoy » Fri Oct 23, 2015 8:20 pm
For a couple of reasons, I think me knowing my max HR would be a good thing. Do you know how you go about organising one of these and an approximate cost?Duck! wrote:....the only way to test your true maximum is with a cardiac stress test under professional supervision.
- RonK
Postby RonK » Fri Oct 23, 2015 8:21 pm
Postby kenwstr » Fri Oct 23, 2015 11:13 pm
Ken
Postby piledhigher » Fri Oct 23, 2015 11:40 pm
There is a scientific grounding, it is a good approximation of the mean of the population, unfortunately the standard deviation is ~10 beats which means that 95% of the population is +/- 20 beats of the rule and that next 4.7% is with +/-30 beats, and we'll just ignore the last .3% they are really freaks.Duck! wrote:There is no scientific grounding at all to the 220-age formula at all, but somehow it comes up with a reasonable enough approximation for most of the population to use as a starting guide. As others have said, the only way to test your true maximum is with a cardiac stress test under professional supervision.
It's a bit like BMI, a population tool that has lots of anomalies when applied to a single individual but useful in characterising aggregate data sets.
- Derny Driver
Postby Derny Driver » Fri Oct 23, 2015 11:48 pm
Many people have this worry that their heart is like a car engine, if you rev it too high it will eventually blow up. You cannot over-rev you heart. There is absolutely no problem with taking your heart to its 100% maximum beating capacity and keeping it there. You wont hurt it. You will just get tired and have to stop as the lactate builds up.kenwstr wrote:.... Seriously, there is no way I will submitt to a full blown stress test, way to dangerous IMO.
Ken
It is also not an easy thing to do, to get your heart to go to 100% maximum. You need adrenaline and a lot of coersion to get it there.
Postby Top_Bhoy » Sat Oct 24, 2015 5:17 am
If that is the only way then I have to do it but is there an alternative because I believe in going to the doctors only when I am actually ill. Otherwise, it seems an inefficient use of a finite resource not to mention an unnecessary cost to Medicare and me personally.RonK wrote:As I have already posted, get a referral from your GP.
- Alex Simmons/RST
Postby Alex Simmons/RST » Sat Oct 24, 2015 7:14 am
Yep, although there are some risk factors in certain cases that should cause pause before doing such an effort such as personal or family history of heart disease, those that are overweight/obese, smokers, sedentary people, older (e.g. over 35) especially if you have not exercised for a long time, other known medical risk factors, have a current or have had very recent illness/viral infection.Derny Driver wrote:Many people have this worry that their heart is like a car engine, if you rev it too high it will eventually blow up. You cannot over-rev you heart. There is absolutely no problem with taking your heart to its 100% maximum beating capacity and keeping it there. You wont hurt it. You will just get tired and have to stop as the lactate builds up.kenwstr wrote:.... Seriously, there is no way I will submitt to a full blown stress test, way to dangerous IMO.
Ken
I think going "maximal" should be avoided until you've actually been riding/exercising regularly for some time and doing general efforts and hills etc are not causing any obvious sign of distress.
- RonK
Postby RonK » Sat Oct 24, 2015 11:00 am
Yes, quite so. I did a stress test some years ago for exactly the reasons the OP posted. However I was not able to push myself on the treadmill to the quite same heart rate as I was seeing regularly on the bike (I was in my 40's, and was reaching 200 bpm on one particular long fast climb).Derny Driver wrote:Many people have this worry that their heart is like a car engine, if you rev it too high it will eventually blow up. You cannot over-rev you heart. There is absolutely no problem with taking your heart to its 100% maximum beating capacity and keeping it there. You wont hurt it. You will just get tired and have to stop as the lactate builds up.kenwstr wrote:.... Seriously, there is no way I will submitt to a full blown stress test, way to dangerous IMO.
Ken
I did my test at the cardiac unit of a nearby hospital, connected to an ECG and blood pressure monitor. If the doctors (there were two) had detected any abnormal heart function they would have stopped the test immediately, and in the worst case (they joked) I was already in the cardiac unit.
The result of the test was that my heart function was found to be normal, with just a slight increase in blood pressure during the test. After that I was confident to push myself as hard as I could.
- cameronp
Postby cameronp » Sat Oct 24, 2015 11:34 am
I only started using a heart rate monitor when cycling a few months ago. (Coinciding with a shift from "just going out for a ride" to "training to get faster".) At that time, the highest heart rate I'd see on the bike would be high 170s, compared to 190+ which I'd seen previously when running. Then I started seeing my heart get to the low 180s at the end of a long climb, but at that point I'd be gasping for breath and feeling absolutely wrecked. The other day I pushed myself as hard as I could on a local hill and was surprised to see 191 bpm. When I went back to look at the ride data I saw that I actually hit 190 a few times in the ride. I guess that means my max HR when cycling is higher than I thought it was! But it got me wondering - was my body always capable of working that hard and I'd just never pushed myself so much before, or has training improved other aspects of fitness that were limiting me first?
- Derny Driver
Postby Derny Driver » Sat Oct 24, 2015 11:58 am
Yes.cameronp wrote: The other day I pushed myself as hard as I could on a local hill and was surprised to see 191 bpm..... - was my body always capable of working that hard and I'd just never pushed myself so much before?
In fact your max may be more than 191.
It is hard to hit your true maximum.
- Alex Simmons/RST
Postby Alex Simmons/RST » Sat Oct 24, 2015 1:41 pm
That depends on how hard you are prepared to push yourself. Some people know how to "bury" themselves.cameronp wrote:Is it normal for less fit people to find it difficult to attain higher heart rates? Or to rephrase, do you need to do a certain amount of training before you can reach your heart's actual maximum when riding?
In general maximal HR drops a little with fitness. It just might be that some only really push themselves sufficiently hard once they are much fitter.
- foo on patrol
Postby foo on patrol » Sat Oct 24, 2015 2:28 pm
Foo
Goal 6000km
- outnabike
Postby outnabike » Sat Oct 24, 2015 5:19 pm
http://www.news.com.au/national/breakin ... 7580281634" onclick="window.open(this.href);return false;
Shorten has no heart
http://www.sbs.com.au/news/article/2015 ... ing-moment" onclick="window.open(this.href);return false;
Bill Shorten has no heart - or, at least, a heart rate monitor has been unable to find it.
The opposition leader's awkward moment played out in Melbourne on Friday after he offered to try out a smartphone stethoscope.
Holding the device to his chest, he waited a few moments for his heart and breathing rates to register on the smart phone.
But after 10 seconds, there was nothing.
"Oh, well," joked one of the designers of CliniCloud.
"Technology in progress."
Mr Shorten's minders were noticeably tense, but their leader shook off the malfunction.
"That's all right, I just have a very low blood pressure," Mr Shorten said.
- ItsDank
Postby ItsDank » Mon Nov 09, 2015 4:59 pm
This.Duck! wrote:There is no scientific grounding at all to the 220-age formula at all, but somehow it comes up with a reasonable enough approximation for most of the population to use as a starting guide. As others have said, the only way to test your true maximum is with a cardiac stress test under professional supervision.
I just had an ECG stress test, echo stress test ultrasound and all the relevant bloods checked.
My HR max recorded is 252 BPM and I'll get up to 220 average with highs of 240 during a crit race. The chest straps are pretty accurate, my Garmin strap was within 2 BPM of the ECG the entire test.
Some people have SVT, some people have naturally high HR's. 220 - your age isn't exactly science.
https://www.strava.com/activities/428497953/analysis" onclick="window.open(this.href);return false;
Anyway, after all that, I'm physically fine. I've always had a naturally high HR and apparently my body can handle it. The advice I've been given is to hold below 240 and don't go higher than that. For you, unless you go to a cardiologist and get tested, you won't know if it's normal or whether you've got a much more serious, underlying issue.
So TL;DR, see a cardiologist if you're worried.
- biker jk
Postby biker jk » Mon Nov 09, 2015 5:06 pm
I note nothing connected to the brain.ItsDank wrote:This.Duck! wrote:There is no scientific grounding at all to the 220-age formula at all, but somehow it comes up with a reasonable enough approximation for most of the population to use as a starting guide. As others have said, the only way to test your true maximum is with a cardiac stress test under professional supervision.
- ItsDank
Postby ItsDank » Mon Nov 09, 2015 5:44 pm
- Derny Driver
Postby Derny Driver » Mon Nov 09, 2015 10:21 pm
My HR max recorded is 252 BPM ....
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
