Melatonin supplements
Postby zill » Thu Dec 10, 2015 12:25 pm
The GP recommended i take 2mg of Melatonin 2 hours before bedtime. He says it's safe but I'm not sure as I've never taken chemicals before as supplements. I'm worried that once I start taking it, I will become reliant on it and my body will produce less and less melatonin in the future. But then again, this sleeping pattern cannot continue either as its interfering with my life a bit.
- sogood
Re: Melatonin supplements
Postby sogood » Thu Dec 10, 2015 12:41 pm
Postby Aussiebullet » Thu Dec 10, 2015 12:46 pm
Postby warthog1 » Thu Dec 10, 2015 1:14 pm
- kb
Postby kb » Thu Dec 10, 2015 1:27 pm
http://re-timer.com/" onclick="window.open(this.href);return false;. Haven't used it but am tempted to get one for the wife
Postby warthog1 » Thu Dec 10, 2015 2:05 pm
I tried some over the counter bioglan crud a few years back. I just looked it up again and cant find the dosage per tablet listed as milligrams or micrograms.zill wrote:I've had sleep problems for 1.5 years mainly due to waking up after only 3 to 4 hours of sleep then usually able to sleep again for 3 more hours but not all the time.
I think it has almost no melatonin in it because it had no effect.
Did you get a prescription for melatonin?
I am a rotational shift worker so have trouble sleeping at times too.
I use restavit as infrequently as possible and find it works. Makes you a bit drowsy/less alert the next day, though still better functionally than going without sleep.
I did have a prescription for zolpidem once. That was fairly rubbish, similar to valerian ime
Postby zill » Thu Dec 10, 2015 5:07 pm
This thing seem to be an alternative to melatonin?kb wrote:If the melatonin works, you could try encourage your body to reset its production with something like
Do you know people who have tried it and worked?
Yeswarthog1 wrote: Did you get a prescription for melatonin?
Postby warthog1 » Thu Dec 10, 2015 5:09 pm
Postby zill » Thu Dec 10, 2015 5:40 pm
No, a bit scared. Haven't taken chemical in terms of tablets since primary school I think.warthog1 wrote:Have you tried it yet?
These look promising http://re-timer.com/" onclick="window.open(this.href);return false; though.
I like to be as natural as possible.
Postby warthog1 » Thu Dec 10, 2015 5:49 pm
I haven't read much on it for a while but Sogood is a medical Dr and he is indicating it is one of the safer alternatives.
I would try it short term as directed and see if it resolves your issue.
At least take it once and tell me how you feel the next day. I need a guinea pig. If you never post again I'll know not to chase a prescription for my sleep issues
Only joking I'm sure it's safe in the prescribed dose. Have a google if you are worried.
- kb
Postby kb » Fri Dec 11, 2015 6:38 am
No, I don't. I have friends with a more traditional light box who say that works but is a hassle.zill wrote:This thing seem to be an alternative to melatonin?kb wrote:If the melatonin works, you could try encourage your body to reset its production with something like
Postby zill » Fri Dec 11, 2015 9:21 am
kb wrote:No, I don't. I have friends with a more traditional light box who say that works but is a hassle.zill wrote:This thing seem to be an alternative to melatonin?kb wrote:If the melatonin works, you could try encourage your body to reset its production with something like
But you only have to wear it for a few months or do you permanantely have to wear it?
- foo on patrol
Postby foo on patrol » Sat Dec 12, 2015 2:02 pm
Foo
Goal 6000km
Postby zill » Sat Dec 12, 2015 3:04 pm
But would I need a referral from the GP first?foo on patrol wrote:I've asked before, have you had a sleep study done yet?
Foo
The GP has first prescribed me to take melatonin, however. Tempted to try it now since this problem has been going on for 1.5 years!
- foo on patrol
Postby foo on patrol » Sat Dec 12, 2015 5:55 pm
Foo
Goal 6000km
Postby zill » Sat Dec 12, 2015 8:44 pm
foo on patrol wrote:Yes they do. If he/she won't refer you, get another bloody Dr and one that uses commonsense + it costs you nothing and you'll find out what the hell is going on, all with popping friggin pills first!
Foo
Sounds very interesting. Will go to another GP and try to do one!
Postby zill » Sun Dec 13, 2015 9:58 am
- foo on patrol
Postby foo on patrol » Sun Dec 13, 2015 10:18 am
Foo
Goal 6000km
- sogood
Postby sogood » Sun Dec 13, 2015 12:37 pm
It can be logical as the sleep study will look more deeply at the pattern and excludes other more serious issues eg. Sleep apnoea and others. However, I suspect his suspicion for those other concern is low in your case and that melatonin is a pretty benign and can be effective for some with sleep pattern disturbances eg. Jetlag and others, it's quite reasonable to try melatonin first. Per your description of the history and situation, your GP's approach is quite reasonable.zill wrote:Just thinking back to the conversation with my GP, he told me to try the melatonin and if that doesn't work then do a sleep study. Wonder if that also makes sense?
As suggested, just try melatonin for 2 weeks and see. It's cheap, harmless and may just work for you. If not, then talk to your GP and seek alternate investigations and solutions. Jumping head first into costly options (eg. Sleep study and re-Timer etc) is bad for your wallet and illogical for your circumstance.
You affect the body far more by drinking coffee, coke, wine and beer!
Postby zill » Sun Dec 13, 2015 1:56 pm
My only concern with melatonin was that it might permanently shut down the body's ability to produce it naturally once I stop taking it (after trying it out for a little while). Could this happen?sogood wrote:It can be logical as the sleep study will look more deeply at the pattern and excludes other more serious issues eg. Sleep apnoea and others. However, I suspect his suspicion for those other concern is low in your case and that melatonin is a pretty benign and can be effective for some with sleep pattern disturbances eg. Jetlag and others, it's quite reasonable to try melatonin first. Per your description of the history and situation, your GP's approach is quite reasonable.zill wrote:Just thinking back to the conversation with my GP, he told me to try the melatonin and if that doesn't work then do a sleep study. Wonder if that also makes sense?
- sogood
Postby sogood » Sun Dec 13, 2015 2:01 pm
Postby zill » Sun Dec 13, 2015 2:28 pm
Sounds great will try it.sogood wrote:Never say never in medicine. But if you do, you'll be the first and written up in the annals of medicine as an unique case. In any case, these therapies are meant to be temporary, one to help you back to a more normal pattern and stop. As said, try 2 weeks and see.
Postby chriscole » Tue Jan 26, 2016 10:45 pm
Hiya,zill wrote:No, a bit scared. Haven't taken chemical in terms of tablets since primary school I think.warthog1 wrote:Have you tried it yet?
1. Melatonin is a hormone produced by your body, anyway. It's about as "natural" as you can get.
2. "Natural" does not equal "good", "better" or "safe". Cyanide, arsenic, hydrogen sulfide gas, falling from great heights without a parachute, etc. etc. are all very very natural...but I wouldn't recommend trying any of them anytime soon.
3. "Chemicals" = every damn element & compound in the known universe. You're made of "chemicals". The air you breathe is "chemicals". I know you use it to mean something more akin to "artificlal stuff that I can't pick off a tree or dig up out of the ground" or "stuff that hippies or the latest diet fad promoter would give their seal of approval to", but it's nice to use words properly sometimes. Again, the distinction between "natural" and "chemicals" is almost meaningless, and the conflation of "natural" with "safer" is a logical error.
4. Melatonin tablets prescribed by your doctor and provided by a bona fide quality controlled pharmaceutical company are quite safe.
Cheers.
Postby zill » Wed Jan 27, 2016 10:10 pm
