Duck's Tech - Compatibility Notes
- Duck!
Postby Duck! » Sat Jun 20, 2015 5:02 pm
Drivetrain:
There is a lot more flexibility here than Shimano will have us believe. Starting with shifter/rear derailleur pairings, all 7,8 & 9-sp. road & MTB, plus road 10-sp (with the probable exception of new 4700 Tiagra) will work in any combination. This is especially handy for people who wish to fit wide-range cassettes into older (more than the last four years or so) drive systems where the rear derailleur is only capable of fitting under a 28T sprocket maximum.
MTB 10-sp. derailleurs & shifters (all marked with the "Dyna-Sys" tag) will NOT work with any road gear. I experimented mixing M770-10 Deore XT 10-sp. with both 6600 10-sp. RD & shifter (two-way switch), and with a 9000 Dura-Ace 11-sp. RD, with no success in any combination.
Road 11-sp. is also a unique family, although indications (yet to be confirmed) are that 4700 Tiagra (which is still 10-sp.) will be a match. Certainly the derailleur & shifter architeture suggest it to be the case.
There are unconfirmed reports that MTB 11-sp. will work with MTB 10-sp, but I am yet to put this to the test. Should this be the case, there will be no compatibility with road 11-sp.
As a general guide, there is no compatibility with other brands. Exceptions are the kind of bottom-dwelling rubbish found on BSOs you would prefer not to use anyway.
Front derailleurs/shifters:
Again, there is far greater compatibility than Shimano would have us believe. Although the geometry of MTB front derailleurs can be quite different to road, and there are several versions of road derailleurs - older conventional (7800, its direct descendents + earlier sets), newer conventional (7900 & relatives) designed for wider chainring spacing, long-arm (9000 & descendents) & flat-bar specific - the differences are so subtle that there isn't really any combination that just doesn't work. Just play with cable tension to get it right.
If setting up a custom-spec component set, pairing the derailleur to the crank is more critical than the shifter - road crank, road derailleur; MTB crank, MTB derailleur. The curve & contouring of the cage is optimised for particular cranks sizes & types, so use that as your guide. Similarly, newer road cranks (7900 & later) which have wider chainring spacing to reduce cross-chaining noise will pair better with a newer front derailleur, which has a little more "swing" to suit.
Front derailleur/shifter compaibility with other brands is reasonably good.
Chains, cassettes, cranks:
As a general rule, things aren't particularly fussy in this area, including mixing other brands. The first major point is simply to ensure that the number of gears in the cassette matches the shifter. Surprisingly, people still get that wrong. Referring back to our 7/8/9 road 10-sp. interchangeability, the leverage ratio - how much cable is pulled to move the derailleur a given distance - is the same. What differs is the amount of cable pulled between the indexing points in the shifter. The exception is 7 & 8-sp. The same sprocket spacing, therefore shifter indexing is used, so you can run a 7-sp. cassette with an 8-sp. shifter and just lock out the 8th gear position. Chains get progressively narrower as more gears are introduced (again the exception being 7 & 8-sp, which are the same). You can go a step either way out of spec without major hassles, but it's not advisable to go more; wider chain doesn't mesh as nicely between the sprockets, so gets noisy, while narrower chain can jam on wider chainrings.
The second major point is inter-brand compatibility. SRAM adopts Shimano standards of sprocket spacing, related chain width and freehub spline pattern (with two exceptions, which I'll get to soon), so there is very high compatibility. The exceptions are MTB 11-sp, which due to SRAM's use of a 10T top gear requires a specific freehub, while Shimano fits on a regular 8/9/10-sp. hub; and road 10-sp to a limited extent. When Shimano introduced 10-sp cassettes, they also brought in a specific freehub with a deeper spline, which will only accept Dura-Ace, Ultegra and 105 cassettes. SRAM, and virtually all aftermarket wheel/hub manufacturers chose to remain with the established shallow spline. The deep spline quietly faded away after about five years. Campagnolo tends to use different spacing, especially for 10-sp, which is wider than Shimano/SRAM. Different freehub spline pattern aside, you can fudge a Shimano cassette to work in a Campag system, although it's not perfect, but the other way doesn't work. 8, 9 & 11-sp. are better matched.
Cranks really don't care too much, you can pretty well run anything.
Brakes:
Standard calipers can be divided into pre-7900, and 7900 & beyond. The pivot leverage was tweaked with the later generation brakes, and it's not recommended to use new calipers with older model levers, but old calipers with newer levers is a passable but not ideal pairing. Mini-V brakes, cantilevers and road mechanical/CX disc brakes can be used with standard road levers, while full-size MTB V-brakes & mechanical discs can only be used with MTB levers. Some low-spec MTB levers have switchable dual cable anchors for cantilever compatibility.
Although road hydraulics are quite new, and brake systems are typically sold complete, there should be little problem mixing road levers with MTB calipers & vice versa - after all, the orignal R785 caliper is basically a reprinted M785 Deore XT model!
Di2:
First-generation (7970) Dura-Ace 10-sp. Di2 is a complete stand-alone system. Its wiring harness is a multi-core system, which is totally incompatible with everything else. All other systems - 10 & 11-sp. Ultegra, 11-sp. Dura-Ace, XTR & Alfine Di2 use the "E-Tube" twin-core wiring to join it all together. Part of the trickery, which to be honest I do not understand, is that the signals are somehow coded for specific tasks, so they go the right way with much simpler wiring.
In contrast to mechanical groups, where the derailleurs are essentially "slave" components that move in response to the cable pull from the shifter, Di2 derailleurs are the "masters" that determine gear compatibility; for 10-sp, use 6770 derailleurs, for 11-sp, 9070 & 6870 do the job, and can be a mix of levels. Given the wider gear range capacity of Ultegra, it's easy to swap a derailleur into the rest of a Dura-Ace system to allow fitting of a bigger cassette. All road E-tube (6770/6870/9070/R785 hydro brake) shifters, including "satellite" climbing, time trial/triathlon & sprint shifters will work in any combination, with the exception that Ultegra sprint shifters can only pair with Ultegra main shifters. What the technical reason is I do not know, but the plug is specially shaped to limit the connection. With suitable junctions, it is not necessary to have the main shift/brake levers; eg, "climbing" shifters can be used for a flat-bar setup. Junction boxes, wiring & batteries are all fully compatible, but do note the external battery can only be charged with its specific charger.
If changing from 10 to 11-sp, it is only necessary to replace the two derailleurs, chain & cassette (after ensuring wheel compatibility!). I don't know the coding behind it, but 11-sp. rear derailleurs will not talk to a 6770 FD & vice versa. It used to work for a short time after 11-sp was introduced, but system updates have removed that compatibility. 9070 & 6870 can be used in any combination.
I do not know if there is any compatibility between XTR & the road groups. My suspicion is that due to the programming particularly involved with the single shifter operation of Synchro shift, that it will not work with road components. Similarly, Alfine is an unknown mixture. Typically Shimano will deny compatibility, and it's one of those niche things that's not widely available to put to the test.
As far as the software interface goes, the E-Tube software is available for download from the Shimano website. The charger for the internal battery has limited capacity to perform firmware updates, and customise shifter button functions & multi-shift settings. It cannot perform system fault diagnostics; this requires the PCE1 interface box.
I thinks that's pretty well covered it all. I'll fill in the gaps around MTB 11-sp & 4700 Tiagra once I've had my hands on some components to play around with.
- rodneycc
Re: Duck's Tech - Compatibility Notes
Postby rodneycc » Sat Jun 20, 2015 6:55 pm
- redsonic
Postby redsonic » Sat Jun 20, 2015 7:42 pm
Postby macca33 » Sat Jun 20, 2015 7:44 pm
- Duck!
Postby Duck! » Sat Jun 20, 2015 8:25 pm
Ah yes, Di2. To keep things nice & tidy I'll drop edits into the OP.rodneycc wrote:Love your work Duck great post mate. I assume all Di2 (both ultegra 6870 and Dura-Ace 9070) can be all mixed and matched? Looking on my next build to put DA cranks and di2 shifters and the rest Ultegra Di2. Wasn't sure if the shifters had to match the derailleurs.
Postby gabrielle260 » Sat Jun 20, 2015 8:31 pm
- coffeeandwine
Postby coffeeandwine » Sat Jun 20, 2015 10:13 pm
Merida 903 from the LBS; Diesel engine
- rodneycc
Postby rodneycc » Thu Jul 09, 2015 3:06 pm
viewtopic.php?f=34&t=85156" onclick="window.open(this.href);return false;
- Duck!
Postby Duck! » Fri Jul 10, 2015 2:01 am
I've answered the relevant bits in your other thread.
- Duck!
Postby Duck! » Fri Aug 07, 2015 2:29 pm
Having just done a 10- to 11-sp. conversion on a MTB & taken the opportunity to have a play, I can confirm that these two shifter/derailleur systems do work together. This is especially handy for those using aftermarket range-extended 10-sp. cassettes that exceed the 36T maximum sprocket capacity of 10-sp. derailleurs, as 11-sp. is capable of fitting under a massive 42T gear.Duck! wrote: Drivetrain:
- MichaelB
Postby MichaelB » Tue Sep 01, 2015 9:55 am
Have seen a variety of comments and 'hearsay' regarding this, but would like your thoughts.
Planning on a two week trip to Dolomites & Alps next year to coincide with the last two weeks of TdF 2016. Plan is to do plenty of riding up some great slopes whilst there. Before I go, there is lots of training to do and some weight to lose, but also, there is some gearing changes that will come for the bike.
Currently running 50/34 & 11-28 11sp 5800 disc setup.
So that I don't die on some of those slopes, a 30 or 32T cassette (Shimano do the 11-32 in 105/Ultegra, as do SRAM) will need to be the base standard. I've also seen the 'Zinn' 1mm washer method writeup (but confused a little as to how it works ...)
Question #1 : Can the 11-32 be used with the std short cage 5800 RD - either with or without the washer?
Then there is also the desire to do something stoopid like tackle the Mortirolo (as it's close to the Stelvio & Gavia). 24km (AT) 7.5% is bad enough, but being foolhardy and up for a challenge, 11.4km (AT) 11% is madness ......
Question #2 : Am I better off planning to use the 11-36 as an 'in case', and install a med cage RD (Can the 11-36 be used with the 5800 Medium cage - specs list only 32T as max capacity) - either with or without the washer?
TIA
- Duck!
Postby Duck! » Thu Sep 03, 2015 2:23 pm
- MichaelB
Postby MichaelB » Thu Sep 03, 2015 6:05 pm
Cheers very much. 11-32, no big-big attempts or Med cage RD, and lots of training.Duck! wrote: .... The 32T realistically is the maximum you'll get.
Ta !!!
Edit :
Ummm, just had a thought - so how did the Pro-Tour guys do it when they put 34/36T on the rear when climbing Angliru in Vuelta ? Or is that because they used SRAM, and with those levers the WiFli system can do it ?
- Duck!
Postby Duck! » Thu Sep 03, 2015 7:18 pm
Postby AndyRevill » Fri Sep 04, 2015 7:05 am
Sorry if this is a stupid question, what's the disadvantage of the medium cage, Why are there two versions? Is it worth having the medium just for when you want to do some big hills or could you just run it full time even if you're only running an 11-28 for most of the time?Duck! wrote: Short version, it can be done, although the medium cage is a safer option due to the extra chain length it allows.
Cheers, Andy
Trek Domane 4.5
- Duck!
Postby Duck! » Fri Sep 04, 2015 2:24 pm
The two sizes stems from the days when triple-ring cranks were the way to extend gear range; the extra length cage is needed to carry the necessary chain to cover the wider gear range. There is no detriment to performance by fitting a tighter cassette with a long derailleur; the clearance between the sprockets & derailleur is the same for both. If it's just occasional hill use, and you currently have a short cage, there is no need at all to replace the derailleur, as long as it is from a series that supports huge sprocket capacity; just avoid big ring/big sprocket.
Only derailleurs introduced in the last four years or so are capable of fitting a 32T sprocket; 4600 Tiagra & 5701 105 (a mid-model update) were the first for 2012 model year, 3500 Sora & 6701 Ultegra (also late-model update) the following year, 2400 Claris, and current 105 & Ultegra (5800/6800) are compatible with 32T. 4700 Tiagra can handle 34T, but compatibility with anything else is questionable. Dura-Ace is limited to 28T.
Postby AndyRevill » Fri Sep 04, 2015 4:54 pm
Cheers, Andy
Trek Domane 4.5
Postby Uncle Just » Wed Sep 09, 2015 11:09 am
I can get a 10 speed 12-30 cassette to work smoothly with either a DA 7800 and a 7900 rear derailleur on two of my bikes. One is a CX with 43cm stays and the other has 42.5cm stays. Maybe the extra capacity has something to do with the stay length?Dura-Ace is limited to 28T
- Duck!
Postby Duck! » Wed Sep 09, 2015 1:49 pm
- Mulger bill
Postby Mulger bill » Fri Apr 15, 2016 4:58 pm
New rotor time for the hardtail and Google skills non existent today
Can I get away with RT76 6 bolt rotors and M596 callipers?
Shaun
- Duck!
Postby Duck! » Sat Apr 16, 2016 11:13 am
You can also use the RT86 IceTech rotor if you tend to get things a bit hot (but the IceTech pads don't fit the caliper).
- Mulger bill
Postby Mulger bill » Sat Apr 16, 2016 4:53 pm
- Duck!
Postby Duck! » Thu Jun 09, 2016 10:38 pm
Some press material for forthcoming 2017-model year componentry was released a couple of months ago, and the related tech info is sneaking into the resources, if you know where to look. Let's start on the road.
R3000 Sora:
Breaking the number sequence, instead of progressing to 3600, this new edition of the Sora group is given the R3000 tag. While it gains the family design trickling down from its big brothers, primarily the four-arm crank and the hidden-cable shifters, Sora remains 9-sp. Given the change in leverage ratio introduced at Tiagra level last year rendering limited compatibility with other 10-sp. gear, I was initially suspicious that the same thing might be done to Sora this time around. Close scrutiny of the compatibility flowcharts clearly indicates that this is not the case, and R3000 is fully compatible with all existing 9-sp. components, and by extension can be played around in mixed-up shifter/derailleur combinations with 7, 8 and non-4700 10-sp.
Disc Brakes:
Nothing drastic here, only the introduction of Tiagra-level, "non-series" RS405. The levers "feature" the same butt-ugly design of the 105-level RS505 introduced last year, but with 4700 (+5800/6800/9000)-compatible 10-sp. mechanical shifting, thus not compatible with older 10-sp. derailleurs. All road hydraulic levers and calipers are cross-compatible.
On The Dirt
M7000 SLX:
This year it's the third-tier SLX group's turn to get a makeover. Not surprisingly, M7000 gets the 11-sp. trickle down from XT and XTR from the last couple of years, but interestingly, also retains a 10-sp. option. Officially the options are 1/2x11 and 3x10, but it's not impossible to mix up other configurations, but a XT or XTR long-cage derailleur would be needed to make a 3x11 set, as the long SLX offering is only for 10-sp, and the 11-sp. version is only available in mid-cage to suit the narrower 1x or 2x configurations. The 11-sp. bits are all fully interchangeable with XT & XTR, while the 10-sp. side retains compatibility with all the previous-generation MTB 10-sp. stuff. The leverage ratios are that close that Shimano & SRAM 11-sp. shifters and derailleur will talk nicely with each other.
M8050 XT Di2:
This is the Big News of the year. XT components are fully two-way compatible with XTR, and also play in limited capacity with road bits. The main new trick introduced with XT is wireless connectivity to E-Tube via Bluetooth. There are two jiggers this can work through; the new MT800 digital display/junction, or WU101, a similar plug-in device to the existing D-Fly. There will apparently be a tablet/smartphone version of the E-Tube software to come, so you can use that or the standard software on a laptop to do all the setup works without plugging in. As far as I understand, the full system diagnostics still need to be plugged through the PCE1 interface box, so the wireless connection is just for button customising, Synchro programming and general updating.
The good bit is this is fully compatible with all other E-Tube-based Di2 systems (in short, everything except original 7970 Dura-Ace 10-sp.). One little catch is, the system will only support one wireless chip, so if you already have a D-Fly unit, you'll have to take it out to fit the new one.
I think that's about it for now; I will add more as it becomes known.
- MichaelB
Postby MichaelB » Fri Jun 10, 2016 8:44 am
The term "munted" comes to mind.Duck! wrote:Updates for 2017 model:
...RS405. The levers "feature" the same butt-ugly design of the 105-level RS505 introduced last year.....
If I was buying a new disc bike, I'd either be opting for the old shimano levers or defecting to SRAM, as they look sooooooooo bad.
Great effort re the notes on compatability
Wonder what the new DA levers will look like ?
- Duck!
Postby Duck! » Fri Jun 10, 2016 7:42 pm
