Which Chain Tool?
- Mulger bill
Which Chain Tool?
Postby Mulger bill » Sun May 01, 2016 7:49 pm
Open to all suggestions tho' compatibility with 8-11 speed chains would be nice.
- biker jk
Re: Which Chain Tool?
Postby biker jk » Sun May 01, 2016 7:54 pm
- Tim
Postby Tim » Sun May 01, 2016 8:04 pm
Not cheap, around $40.00 but bigger and beefier than the typical tool pouch type.
Does what it's meant to without effort.
Replacement pins are available. Mine came with a spare.
Works on all bike chains apparently.
Edit. A few none-too-good reviews on Chain Reaction but I think they're from nuff nuffs. I've never bent a pin and used it for setting Shimano joining pins, no problems.
- Duck!
Postby Duck! » Sun May 01, 2016 8:17 pm
- Mulger bill
Postby Mulger bill » Sun May 01, 2016 8:27 pm
Now that looks interesting. Google seems to concur. Chain Reactions reviews are never my first point for infoTim wrote:Park Tools CT-3.2
Happy with dropping $40 if I'm getting value.
Thanks Duck, Very nice looking pro unit but looks to be hard to find and I doubt the amount of work I do would justify the cost of the CN32.Duck! wrote:I find the Park pins wear down fairly rapidly. I use one at work for 1-8 sp. chains. The cradle is just a tad too wide to comfortably use on 9-11 sp. (unless they've changed it to suit). My main workshop breaker is a Shimano CN32, similar to the 27 referred to above but with nice wooden handles. The pins break eventually rather than wear down, but last a shedload longer than the Park. A spare is supplied, plus they're available separately. It does not fit single-speed chains.
- trailgumby
Postby trailgumby » Sun May 01, 2016 9:19 pm
I have a SuperB one as well that came with my tool set from Torpedo7 nine or so years ago, but the pin in that is not exactly confidence inspiring - I have bent it ever so slightly, I still use it, but I am careful not to muscle on it too hard, and keep the pin on the driver centered on the pin and perpendicular.
But then, it only gets used a few times a year.
Postby macca33 » Mon May 02, 2016 11:11 am
Postby tron07 » Mon May 02, 2016 2:34 pm
I have few cheap tool, I think one should be from Aldi, find it very difficult to get it back inside.
Did something like this guy, and he seems to have lot of trouble to get it back in as well.
https://vimeo.com/2574708
- Duck!
Postby Duck! » Mon May 02, 2016 3:21 pm
Once you've determined if it's OK to reuse the pin, the key is to not push it all the way out; leave it seated in the outer plate, preferably protruding slightly inward to help align the other chain end. Take particular care to ensure the chain remains squarely seated in the cradle on the tool, and that the receiving outer plate is firmly supported by the back of the tool, otherwise it'll blow the plate out & you won't get a secure join.
Postby hedgehog » Mon May 02, 2016 4:17 pm
mostly used on 7 speed chains only once i used it on a 9 speed.
used over 30 times,still works fine.
- jaseyjase
Postby jaseyjase » Mon May 02, 2016 4:54 pm
Ive used from single speed chains to 10 speed with no issues, Ive gone through two of them with both times failing at the chain guide spot (circled below)
Im now using another cheapie that i bought in desperation from a LBS one time, forgot the brand, i think bikehand?
Has served me well in the last 18 months, again using from single speed to 10 speed chains with no issues.
Hand grip is a little small.
Postby hedgehog » Mon May 02, 2016 5:05 pm
but it did not come with the black attachment on the end.
- Duck!
Postby Duck! » Mon May 02, 2016 7:15 pm
My personal one is one of these, does the job pretty well for a cheapie. The adjustable back support (the dark knob on the left) is a good feature which allows the tool to be used with different width chains with good bracing when pushing the pin through.jaseyjase wrote:Im now using another cheapie that i bought in desperation from a LBS one time, forgot the brand, i think bikehand?
- Mulger bill
Postby Mulger bill » Mon May 02, 2016 8:11 pm
Coincidentally, that's the last two to let me down. LBS with a bent pin and Lifeline at the shelf.jaseyjase wrote:In the last few years Ive been using the LifeLine branded chain breaker, i think $10 from Wiggle.
