I've got a set of rs80s. The rear is smooooth as, even thought the rim is worn out.biker jk wrote:Yes, at least 200g heavier! You can't beat the Shimano cup and cone bearings for longevity and weather sealing. My Shimano Tiagra 4400 hubs on the cheap wheelset I built are going fine after five years. Cartridge bearings don't compare and are harder to change unless you invest in a bearing press/puller set.Six13 wrote:Those are heavier than the RS21s, though I do like the 300mm profile
Weight: Front - 906 g / Rear - 1192 g / Shimano
Anyway want to buy RS80 front wheel?
