Hub Dynamos in Australia
- Location: The best place in Australia and the world for bicycle touring!
Re: Hub Dynamos in Australia
Postby Rodgerbiltit » Sun Mar 06, 2016 8:30 am
http://peterwhitecycles.com/wiringinstructions.php" onclick="window.open(this.href);return false;
- il padrone
Postby il padrone » Sun Mar 06, 2016 2:52 pm
The other end of the same dual-cable - two female spade connectors. Probably were supplied with the Secula ??Crawf wrote:IP, what about the Secula, it has two terminals? How does that end need to be terminated?
Postby Turq » Tue Mar 08, 2016 11:59 am
I'd like to get some advice please. I have an Avanti explorer 3 (I believe it is in the 700C type as the wheels state that) it has disc brakes on the front wheels and is a hybrid. Currently no mudguards. I'm thinking of riding it to and from work. As I have no lights I thought a dynamo was a great idea.
I'd like to lights so I can ride on unlit bike paths also. Funds are not unlimited.
I was wondering if anyone could recommend a bike shop in Melbourne that you would recommend to get the dynamo and lights installed set up. I live out on the west of the cbd about 20 km but can travel.
Will I need a new wheel or can they use the current wheel? Any recommendations re lights or dynamos' ? Are the dynamos able to cope with riding off paths and going over gutters etc. Would you recommend a dynamo over lights. I was put off by the limited light time of usb charged lights.
Finally mudguards should they be fitted at the same time ? Sorry for my lack of knowledge.
- RonK
Postby RonK » Tue Mar 08, 2016 12:34 pm
It may well cost less to buy a complete wheel than to have a dynamo hub fitted to your current wheel.
There is no reason for a properly built wheel with a dynamo hub to be any less robust.
Dynamo powered lighting is great - just turn them and forget about them.
SON have had the market to themselves for a long time. Shutter Precision (SP) have given them a good shakeup in recent years, and will be the most affordable. There are many lights to choose from, it will depend on your budget.
Mudguards can be fitted at any time. But if you are making a trip to the bike shop, may as have them fitted.
- find_bruce
- Moderator
Postby find_bruce » Tue Mar 08, 2016 12:42 pm
Edit: ronk mentioned St Kilda cycles - they currently have wheels with SP dynamos for $249 - Road (rim brake) or Hybrid (disc brake)
When you consider an SP dynamo hub will cost ~$200 in Australia, that is a great price for a full wheel.
- rangersac
Postby rangersac » Tue Mar 08, 2016 1:47 pm
If you aren't confident doing it yourself any LBS should be able to fit lights when you get them, it's a pretty simple process that doesn't require specialist tools. For the hub, that St Kilda cycles deal is pretty sweet (although I'm struggling to see the difference between the rim brake and hybrid brake sets, given both rims will accept rim brakes, and the hub accepts a disc!) and I'd go the DM 18 rim option (hybrid) as they are pretty bombproof rims, I use them on my commuter and whilst they are not light they've outlasted offerings from Velocity, Mavic and OEM Giant and Orbea rims that I've destroyed in the past. As Ron has said if you are getting it all done for you might as well get the mudguards done at the same time.
Postby ianganderton » Tue Mar 08, 2016 3:07 pm
Specifications
Needs to fit on a bike without racks or mudguards. Needs to be pretty discrete to avoid theft and tampering when locked up around the city. USB charging very very desirable.
Postby Crawf » Tue Mar 08, 2016 3:40 pm
il padrone wrote: Take the dual cable headlight end, and mount a female spade terminal on one wire, and the ring terminal (supplied with the Edelux) on the other. Crimp tight, solder if you wish, then cover with heatshrink. Spade terminal goes onto the male terminal - in the hole at the base of the light, next to the dynohub lead ; ring terminal connects to your light's mounting bolt........ thus:
Thanks all sorted, came out nice and tidy for a roadie, barely any visible wiring.Rodgerbiltit wrote:This may help?
I had the initial issues and doubt as doing a quick mock up test with the cables draped everywhere with the ends loosely terminated was a no go. But soon as everything was properly soldered and terminated it worked!
- rangersac
Postby rangersac » Tue Mar 08, 2016 4:58 pm
If you want USB charging the only integrated light with USB port that I am aware of is the B&M Luxos. Otherwise there are several separate USB chargers that you can attach (bit of a list here). Front lights will generally fit on the fork crown from a bracket, as you have disc brakes check to see if you have a mounting point for this but there are alternative mounting options depending on the light. For the rear light a good option is the B+M Secula as you can attach this directly to a mudguard, seat stay or use a modified reflector bracket.ianganderton wrote:SP hubs seem to be the goto option atm. What would folks currently recommend for front and rear lights
Specifications
Theft wise you need tools to remove the lights as they are attached permanently, as and they require a dynamo hub to run they are not generally attractive to quick thieves, just make sure you lock up that front wheel securely!
Postby Espresso_ » Tue Mar 08, 2016 6:10 pm
It's also a rather large light, physically - the Luxos, so it is not discreet.rangersac wrote:
However, it is discrete
E
Postby wqlava1 » Tue Mar 08, 2016 7:48 pm
I think the original meaning of the OP was he wanted it to stay attached rather than become discrete.Espresso_ wrote:It's also a rather large light, physically - the Luxos, so it is not discreet.rangersac wrote:
E
Postby ianganderton » Tue Mar 08, 2016 9:56 pm
Firmly attached is obviously good [emoji41]
Postby wqlava1 » Wed Mar 09, 2016 6:11 am
- Mugglechops
Postby Mugglechops » Wed Mar 09, 2016 12:59 pm
Thinking about an exposure revo now with 800 lumens but no usb charging.
Postby wqlava1 » Wed Mar 09, 2016 2:03 pm
The various battery powered lights available in the last few years from China with four-packs of 18650 lithium batteries (like from lt-box.com) spoil us for what a dynamo light can provide. But after several instances of the pack expiring halfway home or on a ride at night, you begin to greatly appreciate the dynohub as an excellent trade-off. I have a Trelock 885 (40 lux) that might have OK intensity where the beam shines, but the beam is so tight that i see nothing much else but the path in front - and I dread another wombat strike or a roo. My E3 pro is a bit better, and the Edelux 2 (80 lux) much better again, but none of them has quite as much light as a $35 battery setup. The cheap and nasty optics of the battery lights has the side benefit of spraying light sideways to give some chance of seeing wildlife. I'm willing to ride any of my dynohub bikes on paths though - within each of their limits. It's much less constraining not to be worried about when the battery might be used up.Mugglechops wrote:I bought an AXA light that is 70lux and has usb charging. Used it for the first time this morning and it's no where near bright enough.
I've seen some of the first amateur beamshots of the new IQ-X (which is now available at xxcycle but not yet at some German sites) in use and that looks very good (and the guy say it's much brighter than Edelux 2) , but still looks like it's quite limited along the path of travel (allowing wildlife to hide) as well as having a cutoff for oncoming traffic, like the Trelock 885.
- RonK
Postby RonK » Wed Mar 09, 2016 2:16 pm
I have a Revo. It's a powerful light and beautifully engineered but is not without its quirks. At lower speeds only two of the four leds are lit. And it has no switch, you cannot turn it off and it takes 10-15minutes or more to discharge.Mugglechops wrote:Thinking about an exposure revo now with 800 lumens but no usb charging.
Oh - and you can get a USB adapter for them. Smart Port Boost cable in either Micro-B or Mini-B USB
- Ross
Postby Ross » Wed Mar 09, 2016 2:54 pm
Postby wqlava1 » Wed Mar 09, 2016 3:48 pm
With respect, maybe you should do a few searches and look it up. Yes the connection of battery light heads to dynamos and the mods to do it are known technology and have been discussed in these forums, but you show no respect to the rest of us in confessing you "CBF". Is your time really worth so much more than all of ours collectively, and are you really that important?Ross wrote:Not sure if this has been covered before (CBF reading 16 pages) but is there a way of hooking up AYUP lights to a dynamo?
- find_bruce
- Moderator
Postby find_bruce » Wed Mar 09, 2016 4:25 pm
That's not a quirk, it's a feature! Just quietly it is one that I would like to be able to emulate. A characteristic of dynamos is that, in simple terms, they produce a constant current ~0.5A while voltage will increase with speed. At 0.5A most LEDs require 2.2v, so more leds requires more speed. 4 leds will not produce any significant light below 6 or 7 km/h while full power for 4 leds is ~20km/h. You will get more light from 2 leds up until 10-12 km/h.RonK wrote:I have a Revo. It's a powerful light and beautifully engineered but is not without its quirks. At lower speeds only two of the four leds are lit.
One or 2 led systems do not need to worry about that - they just produce more light until they hit maximum power at ~12 km/h. The reason the Phillips light which only has 2 leds is so highly rated is not because it produces a lot of lumens, but because the beam shape uses those lumens to maximum effect.
Yeah but no but. ayups require ~1A & dynamos produce 0.5A, so you are not going to get as bright a light. There are fancy ways to produce more power, but efficiency at low speed is an important limitation.Ross wrote:Not sure if this has been covered before (CBF reading 16 pages) but is there a way of hooking up AYUP lights to a dynamo?
- RonK
Postby RonK » Wed Mar 09, 2016 4:58 pm
Perhaps, but anyone coming from a battery light may not be aware and could be quiet dissatisfied with this "feature".find_bruce wrote:That's not a quirk, it's a feature! Just quietly it is one that I would like to be able to emulate.RonK wrote:I have a Revo. It's a powerful light and beautifully engineered but is not without its quirks. At lower speeds only two of the four leds are lit.
Postby wqlava1 » Wed Mar 09, 2016 5:08 pm
If they were dissatisfied with the feature, they'd be marginally less happy with a simpler circuit using all 4 LEDS that had not been optimized, which would give them less light at low speed. You have to use use smart circuits to do this at low speeds whilst not wasting power (valuably generated by one's legs!) at other speeds.RonK wrote:Perhaps, but anyone coming from a battery light may not be aware and could be quiet dissatisfied with this "feature".find_bruce wrote:That's not a quirk, it's a feature! Just quietly it is one that I would like to be able to emulate.RonK wrote:I have a Revo. It's a powerful light and beautifully engineered but is not without its quirks. At lower speeds only two of the four leds are lit.
- Ross
Postby Ross » Wed Mar 09, 2016 6:38 pm
Thanks for your help Bruce.find_bruce wrote:Yeah but no but. ayups require ~1A & dynamos produce 0.5A, so you are not going to get as bright a light. There are fancy ways to produce more power, but efficiency at low speed is an important limitation.Ross wrote:Not sure if this has been covered before (CBF reading 16 pages) but is there a way of hooking up AYUP lights to a dynamo?
- Mugglechops
Postby Mugglechops » Thu Mar 10, 2016 9:27 am
It actually has a better beam pattern than first gen ayups.
- il padrone
Postby il padrone » Thu Mar 10, 2016 8:14 pm
Also AXA Luxx 70 Plusrangersac wrote:If you want USB charging the only integrated light with USB port that I am aware of is the B&M Luxos.
- il padrone
Postby il padrone » Thu Mar 10, 2016 8:19 pm
The down-side of Ayups compared to the top-quality (or even mid-quality) European dynamo headlights is that the Ayup is just a concentric beam - lacks any optics so half your beam output is wasted shining up at the possumsRoss wrote:Not sure if this has been covered before (CBF reading 16 pages) but is there a way of hooking up AYUP lights to a dynamo?
