Best MTB suggestion for single track...advice for buying new
Postby dudleygb » Wed Jun 18, 2014 11:23 pm
I got around $800. I know its not much but could I please get some suggestions.
Maybe some of you out there have recently researched what I'm looking for by chance, could save me some time.
I got a 29er and I love it but shes a bit weary of the larger bike feel. She is however 1.95m tall so I thought a 29er would be a good choice. But since she is really keen on single track, perhaps another type of MTB would suite that style of MTB better?
Its also possible some of this has previously been discussed and I appreciate that, but things seems to change so quick I'm sure there's better designed stuff nowadays etc.
Completely open to discussion, thoughts and ideas. Appreciate the contributions in advance and to learn from seasoned riders in this area.
Re: Best MTB suggestion for single track...advice for buying
Postby mitzikatzi » Thu Jun 19, 2014 8:41 am
Yes a 29er would be a good choice.
- silentbutdeadly
Postby silentbutdeadly » Thu Jun 19, 2014 9:12 am
If I lived anywhere close to the Great Divide then I'd probably shift that way myself but out here in the Great Wide Open...the 29er is a go.
Things like Giant Talon, Merida Big 7 (or the Juliet), Polygon Xstrada, Norco Storm, Haro Flightline, Felt 780, Apollo Aspire etc are all in budget. Bear in mind that none are particularly sophisticated in the fork & wheel department to really chew over singletrack. But they are all a great place to start...and if you wanted the value king then the Giant Talon is the go.
Postby dudleygb » Thu Jun 19, 2014 12:45 pm
hehe, sorry, she is 6ft, 1.83m, my apologies. Still tall thoughmitzikatzi wrote:GLW = 1.95m tall. That would explain why she wanted handlebars wider than 580mm.
Postby dudleygb » Thu Jun 19, 2014 2:44 pm
thx for that. I got the Polygon CX3 for myself a little while ago, and its got fairly decent componentry. If I had a bit more money what would you recommend for a good single track bike? Maybe I get the new one and give the wife my one. She likes the feel of it anyways.silentbutdeadly wrote:For your budget...I would suggest a hardtail 27.5 or 29er. And to be honest...as a rider of 29ers...if the missus wants to work the technical stuff then I'd pitch towards the 27.5...especially at your end of the budget foodchain. The shorter wheelbase and shorter chainstays helps with manoeuvrability in tight and technical stuff.
- silentbutdeadly
Postby silentbutdeadly » Thu Jun 19, 2014 5:09 pm
How long is a piece of string?dudleygb wrote:If I had a bit more money what would you recommend for a good single track bike?
Basically target anything that fits the rider in question AND has short stays, steep-ish head angles, decent driveline (Deore or X7 and up) and decent fork (RS Recon or Fox and up). Leave a bit extra in the kitty for decent wheels and some cockpit adjustments.
- clackers
Postby clackers » Thu Jun 19, 2014 6:00 pm
Calm down, basketball scouts!dudleygb wrote:hehe, sorry, she is 6ft, 1.83m, my apologies. Still tall thoughmitzikatzi wrote:GLW = 1.95m tall. That would explain why she wanted handlebars wider than 580mm.
$800 puts her only in hardtail territory, BTW.
Postby dudleygb » Thu Jun 19, 2014 10:28 pm
does anyone know if the fork on the cx2 can be hardened?
http://www.bicyclesonline.com.au/polygo ... ano-deore/" onclick="window.open(this.href);return false;
- silentbutdeadly
Postby silentbutdeadly » Fri Jun 20, 2014 9:12 am
The Suntour fork can be tweaked to a certain degree but it isn't an air fork so adjusting the sag is not that exact. To be honest, the forks on both this bike is probably the bikes greatest limiting factor (after the the rider of course). I note a sub $200 price on 2103 RS Recon Silver forks at c r c at the moment...and these are a slight step-up on your XC32's.
- trailgumby
Postby trailgumby » Fri Jun 20, 2014 9:26 am
Postby mitzikatzi » Fri Jun 20, 2014 3:34 pm
Postby dudleygb » Fri Jun 20, 2014 5:01 pm
Postby dudleygb » Fri Jun 20, 2014 10:30 pm
http://www.cyclingdeal.com.au/buy/2014- ... /GAL-DEO14" onclick="window.open(this.href);return false;
- trailgumby
Postby trailgumby » Sat Jun 21, 2014 2:40 am
- silentbutdeadly
Postby silentbutdeadly » Sat Jun 21, 2014 9:05 pm
Postby dudleygb » Sat Jun 21, 2014 9:28 pm
yeah u right, those shocks are also crappy.silentbutdeadly wrote:Its a good spec for the dollars but the same caveats apply to this as they did for the Polygon.
if I were to get that recon fork and fit it to that HASA or Polygon, what other parts are needed? Do I need anything else to make it all work and fit?
- silentbutdeadly
Postby silentbutdeadly » Sat Jun 21, 2014 9:34 pm
Postby dudleygb » Sat Jun 21, 2014 9:39 pm
Problem is, c r c take forever to deliver, so if I just get the fork and need a new headset, its another 3 week wait till it arrives.silentbutdeadly wrote:You'll probably need a new headset if the new fork has a tapered steerer. Otherwise, nothing. Trick is to do nothing until you have a bike in front of you...and a plan.
seems like it is tapered, I see the word tapered all over the specs --> http://www.sram.com/rockshox/products/r ... r-tk#specs" onclick="window.open(this.href);return false;
Could you recommend a headset please?
- silentbutdeadly
Postby silentbutdeadly » Sat Jun 21, 2014 9:45 pm
Postby mitzikatzi » Sat Jun 21, 2014 9:50 pm
http://www.this link is broken/au/e ... -prod71593" onclick="window.open(this.href);return false;
http://www.this link is broken/au/e ... prod112969" onclick="window.open(this.href);return false;
http://www.this link is broken/au/e ... -prod71590" onclick="window.open(this.href);return false;
According to MTBR these Manitou Tower forks are the go. Cheap at that price too.
Postby dudleygb » Sat Jun 21, 2014 9:53 pm
Do I need to disassemble to find that out? Or something I can measure. I should probably go study up. I just want to try snag the parts while c r c still have their sale on. I can go check on my bike as a case study. The Silver is definitely going on my CX3 though. What am I looking for? I may as well give it a go, no time like the present.silentbutdeadly wrote:Not without knowing the internal diameter of the headtube. Or the headset type in the bike at the moment.
Postby dudleygb » Sat Jun 21, 2014 9:59 pm
These do look awesome, just for an extra +-120mitzikatzi wrote:A Turn Key Recon Silver fork is still not a very good fork.
Postby mitzikatzi » Sat Jun 21, 2014 10:11 pm
- silentbutdeadly
Postby silentbutdeadly » Sat Jun 21, 2014 10:25 pm
have a look at the hope technical guide for headsets on http://www.hopetech.com" onclick="window.open(this.href);return false;dudleygb wrote:Do I need to disassemble to find that out? Or something I can measure. I should probably go study up. I just want to try snag the parts while c r c still have their sale on. I can go check on my bike as a case study. The Silver is definitely going on my CX3 though. What am I looking for? I may as well give it a go, no time like the present.silentbutdeadly wrote:Not without knowing the internal diameter of the headtube. Or the headset type in the bike at the moment.
it'll show you what to look for
the manitou forks are good but it might be worth considering whether they have local parts support. agree that even recon silver are not that smashing a fork but having owned one and knowingly abused it and serviced it using locally sourced parts...its not a bad place to start.
these days I'd not stump for less than an x-fusion trace or something north of RS SID. Not so keen on Fox from a value perspective but they do work well. that said the last MTB fork I bought was a rigid carbon thing!
Postby dudleygb » Sat Jun 21, 2014 10:25 pm
no, i wasnt being sarcastic Sorry if it seemed like that. I think people spend more on chocolate in a yearmitzikatzi wrote:I know $120 is a lot of money but they are very good forks.
Still, yes, it is a lot of money, but still a great price, and a further 10percent off
