biker jk wrote:Duck! wrote:Here's a couple of pics of my cleat position, which hopefully clarifies the point...
The way you have set your cleats will make your feet splay out a fair bit. Usually, the cleat needs to point towards the small (not large) toe side to have your feet aligned straight on the pedals.
Snipped
biker are we looking at the same photograph? Just looking at the pic the toe would be left and the rule is pointing to the to isn't it? The big toe wouldn't extend further over than that stud.
As no one seem interested in reading this stuff I will post it. Note that is all based on correct fit and not hot air.
http://sheldonbrown.com/shoe-pedal.html" onclick="window.open(this.href);return false;
A good way to start with cleat alignment is to note how your feet rest on plain pedals. You may also want to ask for the help of an experienced bike shop mechanic who uses the New England Cycling Academy Fit Kit, with its R.A.D. (Rotational Adjustment Device). If a foot feels like it wants to rotate, then it does. In tough cases, you do well to seek professional help from a sports orthopedist. You may need orthotics (shoe inserts, or wedges under the cleats) to align your feet, and/or "knee savers" (pedal axle extenders).
http://sheldonbrown.com/gloss_e-f.html#fitkit" onclick="window.open(this.href);return false;
Fit-Kit ©
A proprietary system for fitting a bicycle to a rider, devised by Bill Farrell, of Lebanon, New Hampshire. The Fit-Kit has two principal parts:
1. Bicycle fitting: Various dimensions of the cyclist's body are measured, then entered into a book of tables (or a computer program) which will then suggest a frame size, starting saddle height, top tube/stem length, and seat tube angle.
2. Cleat fitting: Fitting pedal cleats to the cyclists shoes, using a special pair of floating pedals with indicators. (Known as the R.A.D.--Rotational Adjustment Device) The indicators on the R.A.D. show the natural angle of the cyclist's foot on the pedal. By adjusting the cleats so that the foot engages the pedal at i's natural angle, harmful stress to the knee may be minimized.
