best pedals for a clumsy person
Postby fishguy23 » Wed Jul 02, 2014 7:22 am
I guess I will need some shoe recomendation too. As joggers wont really work on them.
Its an sram force crankset if that makes any difference.
Re: best pedals for a clumsy person
Postby li2099 » Wed Jul 02, 2014 9:29 am
http://www.bicycles.net.au/2013/03/shim ... ng-pedals/" onclick="window.open(this.href);return false;
Postby thecaptn » Wed Jul 02, 2014 9:38 am
All of my bikes have these:
http://www.this link is broken.au/shimano-pd-m520-pedals/" onclick="window.open(this.href);return false;
I'm pretty sure they come with cleats incuded. You just need to be sure that the shoes you buy are compatible with SPD cleats.
Pete
- bigfriendlyvegan
Postby bigfriendlyvegan » Wed Jul 02, 2014 9:39 am
Yep, the Click Rs are the way to go.li2099 wrote:Maybe the Shimano Click R:
- m@
Postby m@ » Wed Jul 02, 2014 9:46 am
If you're set on a road-specific pedal, I guess Speedplay X or light action are the next best thing.
Shoes - get something that fits, with the stiffest sole you can afford. I love my Giro Gauges.
- outnabike
Postby outnabike » Wed Jul 02, 2014 10:31 am
I reckon all these click in pedals are a Japanese trick to sell band aids and knee pads.
Print this out and read it every time you have a clip stack.....really.
Postby fishguy23 » Wed Jul 02, 2014 11:05 am
Shoes - get something that fits, with the stiffest sole you can afford. I love my Giro Gauges.[/quote]
No preference really, I know you can also get clip ons for mtb. But assume they would be harder to use given the terrain.
Thanks also to everyone else. I now have some stuff I can go and look at a the LBS.
- m@
Postby m@ » Wed Jul 02, 2014 12:41 pm
Quite the opposite!fishguy23 wrote:No preference really, I know you can also get clip ons for mtb. But assume they would be harder to use given the terrain.
Crank Brothers pedals are four-sided; all other MTB pedals I'm aware of are double-sided. Almost all road pedals are one-sided, and tend to hang vertically - so you need to use the toe of your shoe to flip the pedal over before locking in the front of the cleat, then stepping down.
Speedplay are the obvious exception (double-sided), but do still need more care to locate the cleat on the pedal than Crank Bros.
The disadvantage of MTB pedals is a smaller cleat/shoe interface. If you're racing in A grade and/or buy cheap, flexy shoes, this might be significant...
Postby rjk » Wed Jul 02, 2014 1:17 pm
+1 and you can get click r pedals that are flat on one side so you can use normanl shoes if you wantbigfriendlyvegan wrote:Yep, the Click Rs are the way to go.li2099 wrote:Maybe the Shimano Click R:
- bigfriendlyvegan
Postby bigfriendlyvegan » Wed Jul 02, 2014 1:22 pm
Read the click r review, they're designed to avoid clip-stacks.outnabike wrote:Hi fishguy23,
- biker jk
Postby biker jk » Wed Jul 02, 2014 1:45 pm
- rodneycc
Postby rodneycc » Wed Jul 02, 2014 5:04 pm
I kind of know where outnabike is coming from as I agree clipless pedals are slightly more dangerous than flats/platform in an emergency (there isn't that instant foot down). But I've been converted more than a year now of regular use and can notice the efficiency from the clipless to when I go back to the flats and haven't got that same connection and my feet hit the chain stays and the pedal stroke just seems really ugly.
Postby fishguy23 » Fri Jul 04, 2014 4:38 pm
put the cleats on the set of shoes i bought. practicing on a the bike and its easier than i thought it would be. ive done as recommended above and have loosened them to the lightest setting. after a few rides it should become easy enough to do.
- trailgumby
Postby trailgumby » Sat Jul 05, 2014 7:44 pm
I've just gone to Speedplay Zeros on the road bike and after 6 months theyre only just starting to wear wear in and become easy to get into. Not at all beginner friendly IMO.
If I'd known about the light action id have gone with them.
That said, the free float is the next best thing to a Shimano mtb pedal. Very knee friendly.
Postby klement » Sat Jul 05, 2014 8:18 pm
- outnabike
Postby outnabike » Sun Jul 06, 2014 12:42 pm
fishguy23 There are friendlier cleats as well.fishguy23 wrote:Thanks everyone for the recommendations, i bought myself a set of the Shimano PD-M520.
If you find them a bit tricky to learn with, the SM-SH56 featured on the link may be worth a try.
Shimano SM-SH51 SPD Standard cleats
Shimano SM-SH56 SPD Multiple Release Cleat Set
http://www.this link is broken/au/e ... -prod10969" onclick="window.open(this.href);return false;
- biker jk
Postby biker jk » Sun Jul 06, 2014 1:39 pm
The Light Action while requiring less force to disengage do so at a much greater angle than the Zeros (so more foot travel is needed). Even with the Light Action you're not going to unclip quickly in an emergency (don't ask me how I know ).klement wrote:Trailgumby, I'm in the same boat. I bought the zeros as my first cleats/pedal combinations and two weeks later, they are still incredibly tight. I wish I had bought the light actions as well !
- RonK
Postby RonK » Sun Jul 06, 2014 2:01 pm
Speedplays are overrated anyway, but have you lubricated the clip? New cleats are very sticky - get some Tri-flow on them.klement wrote:Trailgumby, I'm in the same boat. I bought the zeros as my first cleats/pedal combinations and two weeks later, they are still incredibly tight. I wish I had bought the light actions as well !
Also have you mounted the cleats on the shoes with the correct spacers so they don't distort and jam?
You should be able to move the clip fairly easily, pushing it with the tip of a screwdriver. If you can't then you have a lubrication or installation problem.
Postby fishguy23 » Sun Jul 06, 2014 6:24 pm
- biker jk
Postby biker jk » Sun Jul 06, 2014 6:39 pm
No, the C shaped spring should be able to be moved not the cleats sliding against the shoe. If the screws mounting the cleats to the shoe are overtightened then the C shaped spring won't move at all and won't be able to clip in. All this information is in the instructions.fishguy23 wrote:Sorry just on the last post, so my cleats on the shoe where they screw in. That should be able to slide up and down? Along the runner sorta thing? Or should they be firm in position
- Duck!
Postby Duck! » Sun Jul 06, 2014 6:41 pm
The last couple of posts relate specifically to the Speedplay brand of pedals, in which the design is essentially reversed from everything else in that the locking/releasing mechanism is incorporated into the cleat on the shoe, rather than in the pedal.
- Duck!
Postby Duck! » Sun Jul 06, 2014 6:42 pm
I don't think you're talking about the OP's Shimano pedals....biker jk wrote:No, the C shaped spring should be able to be moved not the cleats sliding against the shoe. If the screws mounting the cleats to the shoe are overtightened then the C shaped spring won't move at all and won't be able to clip in. All this information is in the instructions.fishguy23 wrote:Sorry just on the last post, so my cleats on the shoe where they screw in. That should be able to slide up and down? Along the runner sorta thing? Or should they be firm in position
Postby fishguy23 » Sun Jul 06, 2014 7:09 pm
- biker jk
Postby biker jk » Sun Jul 06, 2014 7:20 pm
No, I though klement was asking. My mistake.Duck! wrote:I don't think you're talking about the OP's Shimano pedals....biker jk wrote:No, the C shaped spring should be able to be moved not the cleats sliding against the shoe. If the screws mounting the cleats to the shoe are overtightened then the C shaped spring won't move at all and won't be able to clip in. All this information is in the instructions.fishguy23 wrote:Sorry just on the last post, so my cleats on the shoe where they screw in. That should be able to slide up and down? Along the runner sorta thing? Or should they be firm in position
- outnabike
Postby outnabike » Sun Jul 06, 2014 7:29 pm
Some good info on positioning.fishguy23 wrote:Thanks i had already done them up tightly and they both clip in and out nicely. But was just clarifying, im completely new when it comes to road bikes so any advice is great.
http://sheldonbrown.com/shoe-pedal.html" onclick="window.open(this.href);return false;
