Carbon road frames, what options, threaded BB?
- singlespeedscott
Re: Carbon road frames, what options, threaded BB?
Postby singlespeedscott » Wed Jul 23, 2014 9:11 pm
Postby warthog1 » Wed Jul 23, 2014 9:22 pm
Blame tapatalk
Postby warthog1 » Wed Jul 23, 2014 11:19 pm
http://axaracycles.com/index.php?page=s ... &Itemid=53
http://www.competitivecyclist.com/wilie ... d-xp-frame
Postby usernameforme » Thu Jul 24, 2014 11:56 am
Competitive cyclist is a good online store though, not sure if they ship to AUS.
- jacks1071
Postby jacks1071 » Thu Jul 24, 2014 12:15 pm
I think so (on the L-54 and larger). If you place an order I'll unpack one and check it before sending if that is a must have for you.Bentnose wrote:
So are you saying I could fit a 25mm tyre on a Cuneo? Also when do you expect to have white ones in a large?
Recently anyone asking about wide tyres, I've sold them the Merano wide rim wheels and they run a 23mm tyre which gives them the wide tyre (a 23mm tyre on a wide rim is as wide if not wider than a 25mm tyre on a standard narrow rim) but in a lower profile which reduces the chance of rub. They don't rub on the chain stays, its the seat tube that they can touch.
L-54 size I can't do white, have pleanty of stock in Matt Black.
I can do you a Bella GP in that size though, in White. Its the same frame except with carbon seat stays.
Postby warthog1 » Thu Jul 24, 2014 6:34 pm
That's embarrassing if it isusernameforme wrote:I'd be aware of the first link, looks like a scam to me...
I have had no dealings with them.
I saw that t7 did have them for a sub 1k price but are sold out.
Blame tapatalk
Postby cage » Thu Jul 24, 2014 7:25 pm
http://forums.mtbr.com/bike-frame-discu ... 58856.html
http://www.bikeforums.net/manufacturer- ... nesia.html
- Bentnose
Postby Bentnose » Thu Jul 24, 2014 9:31 pm
- ldrcycles
Postby ldrcycles » Thu Jul 24, 2014 10:06 pm
Postby warthog1 » Fri Jul 25, 2014 10:10 pm
Sorry about that. I have heard some good feedback on those frames. Glad you were on the ball.Bentnose wrote:Yeah first thing I did was check if it was a scam. The Izoard from Competitive cyclist is a bit pricey for me, especially when you add on postage.
Blame tapatalk
Postby usernameforme » Sat Jul 26, 2014 12:56 pm
http://www.competitivecyclist.com/fuji- ... -BLA-S55CM#" onclick="window.open(this.href);return false;
It's a steal if they've got one in your size. We've got a local team sponsored by Fuji, they really rate their Altamira and SST frames
- Bentnose
Postby Bentnose » Sat Jul 26, 2014 4:55 pm
It's BB86 though, good price.usernameforme wrote:Just spotted on competitve cyclist they have some sizes of the Fuji Altamira 1.1 left for $900
Postby usernameforme » Sat Jul 26, 2014 6:02 pm
If you're looking to run shimano BB86 is the shimano standard.
TBH I don't see the fuss about threaded bb (I'm going to get flamed for this), but the press fit standards work well, they generally work out to be lighter and creaking is only an issue if you don't know what you're doing.
Postby warthog1 » Sat Jul 26, 2014 8:18 pm
Some good Ridley options there, depending on your size.
- Bentnose
Postby Bentnose » Sun Jul 27, 2014 8:04 am
I personally find the external BB cups to be the easiest to work on, I have the tools and they won't stop making threaded BB cups any time soon. You said it all in your comment, "it's only an issue if you don't know what your doing", which means I'd probably have to visit a bike shop to get one fitted or have issues learning how to do it, buying the tools etc, I avoid bike shops like the plague generally. I also don't like the marketing hype about extra stiffness as they are no longer limited by the BB shell, I don't need extra stiffness.usernameforme wrote:looking to fit a BB30 crank?
- Bentnose
Postby Bentnose » Sun Jul 27, 2014 8:09 am
Yeah I've looked at them, all aluminium under $1k, probably less than I'd like to spend, c r c are coming up on the end of the current frames they are selling and will most likely have new ones of who knows what soon, so I'm also waiting for them to come out, I'll be ready to pounce. When the Ridley's first came out I'm pretty sure there were quite a few carbon options just under $1K. I'm in no rush, frame this year, gradually buy the other bits to match the frame taking advantage of specials, groupset last so I get the latest, only plan to have it on the road 2016 with a 2016 groupset hopefully.warthog1 wrote:This page is scam free I reckon. http://www.this link is broken/au/e ... t=pricelow
Postby warthog1 » Sun Jul 27, 2014 8:23 pm
In that case can you stretch to a lynskey? Quality remains long after price is forgotten.Bentnose wrote:Yeah I've looked at them, all aluminium under $1k, probably less than I'd like to spend, c r c are coming up on the end of the current frames they are selling and will most likely have new ones of who knows what soon, so I'm also waiting for them to come out, I'll be ready to pounce. When the Ridley's first came out I'm pretty sure there were quite a few carbon options just under $1K. I'm in no rush, frame this year, gradually buy the other bits to match the frame taking advantage of specials, groupset last so I get the latest, only plan to have it on the road 2016 with a 2016 groupset hopefully.warthog1 wrote:This page is scam free I reckon. http://www.this link is broken/au/e ... t=pricelow
- singlespeedscott
Postby singlespeedscott » Sun Jul 27, 2014 9:13 pm
Postby warthog1 » Sun Jul 27, 2014 10:31 pm
I haven't owned one but they have a lifetime warranty. There is a few negatives on the net that I could see but that is apparent for any frame manufacturer.
Blame tapatalk
Postby usernameforme » Mon Jul 28, 2014 8:44 am
Or you'll continually be replacing frames
Linskey probably set it up so if you do get a did, they'll replace it, hopefully with a good frame. Saves a bit of q/c
- ldrcycles
Postby ldrcycles » Mon Jul 28, 2014 9:15 am
Given pretty much every photo online of failed ti frames is cracking, i suspect that other than bad welding the problem is either they are using excessively thin walled tubing, or a grade that is too brittle for the job. If someone gave me a ti frame i wouldn't hesitate to ride it but there's no way i'd be sinking my own hard earned on a time bomb.
Postby warthog1 » Mon Jul 28, 2014 10:03 am
Very well welded apparently.
I have a mate who absolutely loves his.
I'd like to give ti a go at some stage. I haven't got the moula for a Baum however.
I've cracked the other 3 major materials so might as well complete the set.
I hadn't heard it was prone to cracking before. It's probably like anything if you make it too light though.
Blame tapatalk
- Bentnose
Postby Bentnose » Mon Jul 28, 2014 12:20 pm
I have an On One Inbred steel MTB and it is looking a bit scuffed up after 3 years of abuse, less than $200 to replace that with another On One, maybe there is something to be said for riding cheap frames; as long as they ride well.
Postby koshari » Mon Jul 28, 2014 12:39 pm
Postby koshari » Mon Jul 28, 2014 12:40 pm
Recall I heard a similar claim made about CDs many years ago.ldrcycles wrote:Cos titanium lasts forever, or so the advertising goes...
