Help with Tyre choice please :)
Postby WITHND » Mon Jul 28, 2014 11:20 am
I have a Jamis Xenith Race bike and it came with 23mm Vittoria Zaffiro Pro Slick Tyres on Mavic Aksium Race wheels.
I have done about 1000km in 3mths including 5wks off the bike when had an injury.
My question is in the dirty and wet weather I have just had my first puncture and on review / cleaning the bike and tyres I can visibly see nuerous other cuts small indents in the rubber, I want to know what would be a good alternative tyre that performs as well as these however might be a little more puncture resistant as I think these two are just about cooked after my 100km on Saturday...
Also not sure that it matters I ride them about between 110PSI and 120PSI depending if dry or wet slightly lower in the wet...
Any help or suggestions are very welcome
Cheers in advance
2015 Jamis Xenith Pro
- jacks1071
Re: Help with Tyre choice please :)
Postby jacks1071 » Mon Jul 28, 2014 11:41 am
The Zaffiro's are right up there durability wise, the only real issue with them is that they are lethal in the wet.
Postby march83 » Mon Jul 28, 2014 11:52 am
my philosophy is to ride something that strikes a balance between not too expensive (so you can stomach throwing them out when they get slashed) and riding nicely (no point riding horrible, heavy rubber if you don't have to). then you just accept the flats as bad luck when they come.
based on this criteria, i run veloflex masters - less than $50 a pop, lovely feel, good enough in the wet and i've only actually managed to flat them once in 6 months. I've had similar good results with conti gp4000s, gp4 seasons and vittoria corsa cx but there are many others that fall into this price range that you could look into (mich pro4, schwalbe ultremos, etc). I've never had an unreasonable amount of flats on any of the more "race" oriented tyres i've run, but i've certainly enjoyed their better ride and lower weight.
as for pressures, 100+ is fine for a ~20mm rim. wider runs softer - i run my 23mm wide rims at about 80psi.
- rodneycc
Postby rodneycc » Mon Jul 28, 2014 12:01 pm
Postby WITHND » Mon Jul 28, 2014 12:01 pm
The tack that flatted me went straight through and was easy to remove however there are numerous cuts small tears or holes that small stones etc have been embedded into thwe tyre that go through to the tube, I removed 3 or 4 that were only just visible I needed to let the air down and use tweazers to get them out, my riding budy suggested if I keep using them I am likely to flat often and better to replace with something better than the ones that came with the bike...
Also thanks March thats what I am trying to figure out, how good or bad are the tyres I am already using and should I just replace with the same or if there is more durable with the same or better performance I would pay extra $ fot them...
I await further responses, maybe I should have done a poll who uses what for winter road biking where wet conditions are going to be encountered
Thanks for replying / feedback I am pretty new to this and have a lot to learn...
Postby WITHND » Mon Jul 28, 2014 12:02 pm
- rodneycc
Postby rodneycc » Mon Jul 28, 2014 12:05 pm
Postby reefer » Mon Jul 28, 2014 12:16 pm
They are a little harsh and I don’t really corner in them over 20km/hr (that just me being conservative, I like my skin).
They are pretty well the best “puncture resistant” tyres you can get. In saying that, I was only able to manage 5 weeks before I punctured them. A Staple went right through the centre of the tyre and both sides of the tube and I was not even in an industrial area. I have noticed that they don’t tend to cut up, I guess due to their tread type and depth and they seem to be made of quite tough rubber (i.e. the moulding leftover bits are still on after 750km).
I am 89kg and run the tyres at 85psi. At their maximum psi, I find them quite harsh.
They are also quite expensive.
- Bentnose
Postby Bentnose » Mon Jul 28, 2014 12:26 pm
Postby lobstermash » Mon Jul 28, 2014 1:28 pm
Tips others have given above, such as running wider tyres and lowering the pressure a little, can help reduce the risk. However, even with tough (pneumatic) tyres, you still get the odd puncture from time to time.
- Storm Boy
Postby Storm Boy » Mon Jul 28, 2014 7:20 pm
The tyres are pretty puncture resistant, grip in the wet has not been an issue. They do seem to get a fair few cuts but it doesn't seem to increase the number of punctures. My rear tyre is currently just through to the casing after around 3000 km, I am 95 kg and run the rear at around 120 PSI. I'm pretty happy with them and looking at buying more as they are pretty good as well as pretty cheap, around $50 per pair of folding tyres on Ebay.
Regards,
SB
- MattyP
Postby MattyP » Tue Jul 29, 2014 1:03 pm
I have 23mm Vittoria Rubino Pro Slick's on my (new) Jamis roadie & they've given me 200km of initial trouble free riding. I'll likely replace them with Vredestein Fortezza Tricomp's when they wear out. 23mm or 25mm will be the big decision....
Regularly checking the tyres for embedded glass/metal can aid in puncture prevention.
- jacks1071
Postby jacks1071 » Tue Jul 29, 2014 1:36 pm
Pin holes through the tyre carcass are okay - its only if you have cuts all the way through so the tube can pop out like a hernia that you definitely need to replace the tyre.WITHND wrote:Thanks Jacks,
If you are frugal, you can use "shoe goo" to seal up the cuts just to prevent debris from getting into the cuts and working its way through.
In general terms the more you spend on tyres the less durable they are as they become more performance orientated.
You might like something like Contintental Gatorskin (Hardshell version if you can get them).
I'm not sure how heavy you are but over inflating the tyres makes them much more puncture prone.
Postby WITHND » Tue Jul 29, 2014 2:40 pm
Postby usernameforme » Tue Jul 29, 2014 9:12 pm
With spring/summer approaching I'd probably try using the regular/slick Zaffiro/Rubino. They'd have slightly less rolling resistance but a bit more prone to cuts.
At your weight I'd say 110 for wet and 120 dry would be spot on for 23mm tyres. If your tyres are wider (25mm) you can drop this by around 10psi. As my general rule of thumb, the tyres should deform slightly when you're riding... eg when riding look at your rear tyre, if it's got a slight bulge I'd say they're inflated just right. If there is no buldge it's too hard and if the bulge is too major I'd put more air in.
Vittoria do have an "iTire" pressure app - which gives you recommendations for tyre pressure I plugged your numbers in and it recommends 100psi... I'd recommend playing with your tyre pressure a little, between 95 and 120psi in about 5psi increments and see which pressure you like the best. I'd go for the most comfortable ride which doesn't feel sluggish.
If you're feeling curious with other manufacturors Continental GP4 seasons or Gatorskins are great for commuting. I personally don't rate Maxxis Refuse tyres but they are very durable - I've run sets down to the casing without extra punctures. I just dislike the "sluggish" feel of them.
Personally, for me, Vittoria Rubino Pro 3 tyres strike the balance of fast rolling, price and durability. These tyres would be slightly faster than your Zaffiro tyres, but would cut more easily. If I want out and out durability I'd go for the Gatorskins. I've never used the GP4 seasons, but I'd imagine that it would strike the balance between these two tyres. Tyres are a VERY personal choice, you've got to decide what you want. There's three main criteria, rolling resistance, price and durability. I'd pick the two that are most important to you.
Postby WITHND » Tue Jul 29, 2014 9:46 pm
I would love to feel faster when the weather gets better later in the year however still going to keep the tubes for now...
Postby Homo Suburbiensis » Tue Jul 29, 2014 9:51 pm
Note:weights are for total i.e. bike+body weight. 45/55 distribution front and back. I think you should lower your pressures just a bit.
Postby softy » Tue Jul 29, 2014 11:05 pm
It is basically a trade off, concrete tyres with good punture pretection or at the other end of the scale, lightweight cotton or silk tyres. And of course ever thing inbetween.
If I was you I would try some of each, give the high end veloflex a go (with latex tubes if your really keen) and then try some gatorskins. If you are okay with gators, stick with them as they are supposed to be tough.
Personally I can't ride the concrete tyres, for me riding is the enjoyment, why ride tyres that are horrid! I just make sure I'm prepared for a flat, boy scout here. I actually run tubs, they give a fantastic feel, but this is for the rare breed, so don't go this way unless you are committed to replacing and running tubular rims.
Good luck.
Postby softy » Tue Jul 29, 2014 11:12 pm
What I do is pump them up to maximum 120psi (as most clicher rims can't go above this) with the front tyre 5 to 10 less. Now go out on them for a little ride, then lower them 5 to 10psi, equally front and back. Continue to do this until the harshness disappears, it happens quite suddenly when you get to the right pressure for your weight. Once you have the value stick to it.
Remember different tyres are different. Cotton tyres can be run higher pressures with comfort whilst polyester ones need to be lower.
- singlespeedscott
Postby singlespeedscott » Wed Jul 30, 2014 2:29 am
I don't think they are anymore puncture resistant then any other general road tyre though.
Definitely lower your pressures. I weigh the same as you and would run 100psi in the back and 80 in the front.
I currently run Challenge Parigi Roubaix and have had reasonable success with them. I run them with 80 in the back and 60 in the front. I have had only a couple of punctures in the last 4000km and they offer a superb ride. They are a large tyre measuring 29mm when inflated on Mavic Open Pro's.
The Veloflex Master's are another good tyre but you won't get the same mileage as the Challenge tyres, mostly due to the narrower width. I stopped using them though as they are more suited to smoother roads rather them the coarse chip bitumen that I usually ride. They also tend to run narrower than advertised. The 25's I ran actually only measured 23mm.
Postby danny the boy » Wed Jul 30, 2014 8:35 am
- neobikes
Postby neobikes » Wed Jul 30, 2014 9:21 am
- jacks1071
Postby jacks1071 » Wed Jul 30, 2014 11:35 am
120psi would be way too high for your weight, you're about the same size as myself.WITHND wrote:Thanks Jacks I am 181cm and weigh 75kg so yeah maybe I am over inflating them running them at 110 to 120 psi (lower end 110 in wet and closer to 120 when dry)
Try this.
Wet 80psi front, 90psi rear
Dry 90psi front, 100psi rear
If you have significant risk of slamming into pot holes on any particular ride, then add 10psi as a safety measure to protect your rims against impact damage.
In the wet, trust me on this - you want a different tyre. Even with the pressures low the Zaffiro's are sketchy at best in the wet.
