- KGB
Re: Saddle bag stuff recommendation
Postby KGB » Wed Aug 06, 2014 6:33 am
Add:
-Multi tool, I prefer one with a chain tool and spoke key included. -$5 note for emergency snacks or as emergency tyre boot.
-ID, an old licence or something.
I carry one spare tube and some glueless patches. First flat is just a tube swap, then patch any after that. I find the glueless patches a temp job only so will fix everything up once I get home.
Roll your tubes tightly as well to squeeze all the air out and save space.
- KGB
Postby KGB » Wed Aug 06, 2014 6:36 am
Any decent brand multi will do me as long as it has the required tools (chain breaker, Allen keys, small screwdriver, 15mm spanner).
- barefoot
Postby barefoot » Wed Aug 06, 2014 8:51 am
I'm pretty sure it's just one tube, a couple of tyre levers and a multitool. I have a pump attached to my frame.
Most of my riding is with a bunch, so second spare tubes are kind of a community resource. If you flat, you use your spare tube; if you double-flat, you scrounge one.
If I'm out on a short-ish solo ride and somehow manage to double-flat (I can't remember this ever happening), then I'll call for rescue... even if it's a taxi rescue, or a hitch-hike to public transport or whatever. Like I would have to if I destroyed a tyre, or broke a frame or snapped a crank or any of the other possible-but-unlikely breakdowns.
If I'm going for a long solo ride (>100km and/or remote and/or otherwise high risk), I'll carry more... an extra tube and/or patch kit... in a bigger saddle bag that also has space for some food and supplies.
It's a trade-off between travelling light and being self-sufficient. On a solo tour across South America, you'd probably want to take extra spokes, brake pads, spare tyre, gear and brake cables etc. etc.. For a short morning bunch ride, you wouldn't.
Postby WarbyD » Wed Aug 06, 2014 9:03 am
MTB saddle bag has spare tube (I run tubeless, so this is "just in case"), derailleur hanger, quick link, tyre levers and a gel.
Both bikes I carry my pump on the frame (with a cable tie to ensure it stays there on the MTB)
The ID is a good idea.. I really should get around to putting photocopies of my license in them with some emergency contacts..
Postby jasonc » Wed Aug 06, 2014 9:39 am
Postby fergy1987 » Wed Aug 06, 2014 7:34 pm
- Duck!
Postby Duck! » Wed Aug 06, 2014 9:56 pm
I'm not sure why you'd need spooks though, unless they're some form on security system to scare people away.
- Toyopet
Postby Toyopet » Wed Aug 06, 2014 10:40 pm
Equipment carried in a small saddle bag
1 x tube
2 x tyre levers
1 x micro pump
1 x Lezyne dry patch kit, with a few dry patches (wet patches & glue may be better)
1 x presta/schrader adapter, for petrol station air top-ups
Additional – for long group rides, where quick repair time is important:-
Equipment carried in a tool canister bidon – mounted in my second bidon cage on the seat-tube
1 x CO2 kit
1 x mini tool with multiple allen keys and driver bits
Additional – for long isolated rides, where help is almost non-existent:-
Stuffed in the tool canister bidon, or jersey pockets
1 x chain breaker (haven’t busted a chain yet)
1 x additional tube
1 x spare tyre (a $20 note may be sufficient for a temp fix on minor tears)
Anything else
Spare gaffer tape wrapped around a film canister (if you can find one) is more useful and easier to carry than a spare spoke.
You can then tape a broken spoke to the next good spoke and keep on riding.
Postby cp123 » Wed Aug 06, 2014 11:11 pm
Postby eeksll » Wed Aug 06, 2014 11:32 pm
+1, those parktools tyre levers are crap. I always seem to pinch the tube between the lever and the tyre. Doesnt seem to happen with any of my other tyre levers.KGB wrote:Park tyre levers are pretty average. Try and find the flat, wide ones from michelin, continental or pedros. I have some birzman ones which seem pretty good.
- kb
Postby kb » Wed Aug 06, 2014 11:58 pm
- kb
Postby kb » Thu Aug 07, 2014 12:00 am
- barefoot
Postby barefoot » Thu Aug 07, 2014 9:21 pm
Multitools are a compromise between useability and portability. If you're attempting to use one as your day-to-day tool kit, you'll very quickly run into the usability compromise. Nothing beats a proper tool for the job.
A decent set of allen keys is not expensive at all. At least one of my sets cost <$10, and they're nice tools.
If you use a multi-tool chain breaker too much you'll stuff it... and then you'll have a tool with a munged chain breaker that doesn't work properly when you need it (the pin on my multitool chainbreaker is bent now... I got about 15 years out of that one, but it's a pointless inclusion on the multitool now).
What else is on a multi-tool? Screwdrivers (a couple of bucks at the Reject Shop if you can't spring for a decent set at your hardware shed of choice)? Nasty metal tyre levers (better to grab a set of plastic ones)? Aluminium ring spanners that probably won't turn the awkwardly located bolt you need it to turn, and flogs out after about 3 uses?
Don't plan on using your multi-tool for normal workshop use. Grab some real tools.
tim
Postby twowheels » Thu Aug 07, 2014 10:45 pm
http://www.topeak.com/products/Mini-Tools/ALiEN_II
Postby Uncle Just » Thu Aug 07, 2014 10:53 pm
Ghost shifting perhaps?I'm not sure why you'd need spooks though, unless they're some form on security system to scare people away.
Postby WarbyD » Fri Aug 08, 2014 5:05 pm
Postby fergy1987 » Fri Aug 08, 2014 5:38 pm
