Can I have an even more compact crankset?
Postby michael.chaseling » Thu Aug 28, 2014 8:17 pm
I was wondering whether I could change out one or both of my chainrings on my compact for smaller ones. The reason is that the jump from the smaller to the bigger ring is too much to be useful. I find it a little impractical where I ride as I very rarely need the highest gears.
When I am picking up speed, I change up on the back gears until I start cross chaining and rubbing on the front derailleur. Then when I shift to the bigger chain ring, I find I then lose cadence and feel like I need to ride harder and faster. I only change up to avoid the rubbing and cross chaining, not get a dramatic increase in speed, so a smaller outer ring would make sense right?
There are also a lot of hills where I live, and at least once per ride, i find the lowest gear is not quite low enough.
I ride mostly to the pub and back etc so I don't ever need to race flat out.
What do you reckon?
- Derny Driver
Re: Can I have an even more compact crankset?
Postby Derny Driver » Thu Aug 28, 2014 8:44 pm
And what is your cassette, in teeth numbers?
I would think that 34 -46 chainrings with an 11-28 would be good for you.
- Bentnose
Postby Bentnose » Thu Aug 28, 2014 8:54 pm
- MattyK
Postby MattyK » Thu Aug 28, 2014 9:17 pm
- RonK
Postby RonK » Fri Aug 29, 2014 6:29 am
Makes no sense at. If the small ring is so low you have to change to the big ring, smaller will just make it worse.michael.chaseling wrote:when I shift to the bigger chain ring, I find I then lose cadence and feel like I need to ride harder and faster. I only change up to avoid the rubbing and cross chaining, not get a dramatic increase in speed...
Sounds like you need a bigger small ring.
- bychosis
Postby bychosis » Fri Aug 29, 2014 6:46 am
- Derny Driver
Postby Derny Driver » Fri Aug 29, 2014 9:40 am
Ron I think what he means is that once he gets to the 34-11 and is crosschaining he wants to change up to avoid that. When he changes chainrings he ends up in the 50-11 and the cadence is too low. Even if he knocks it back a couple of cogs the gear is still too big and cadence too low so he feels he has to speed up. He would need to change back 5 cogs to the 50-16 to find an equivalent gear to the 34-11 he was comfortable on. By replacing the 50 with something smaller he can minimise the difference or even just ride everywhere in the big ring.RonK wrote:Makes no sense at. If the small ring is so low you have to change to the big ring, smaller will just make it worse.michael.chaseling wrote:when I shift to the bigger chain ring, I find I then lose cadence and feel like I need to ride harder and faster. I only change up to avoid the rubbing and cross chaining, not get a dramatic increase in speed...
Postby Baalzamon » Fri Aug 29, 2014 9:50 am
- mitchy_
Postby mitchy_ » Fri Aug 29, 2014 9:56 am
i beleive Ronk's angle on the situation is that if they had a larger small ring, they wouldn't get to the end of the cassette and need to upshift as quickly. however they would lose lower gears, which they may or may not be using.Derny Driver wrote:Ron I think what he means is that once he gets to the 34-11 and is crosschaining he wants to change up to avoid that. When he changes chainrings he ends up in the 50-11 and the cadence is too low. Even if he knocks it back a couple of cogs the gear is still too big and cadence too low so he feels he has to speed up. He would need to change back 5 cogs to the 50-16 to find an equivalent gear to the 34-11 he was comfortable on. By replacing the 50 with something smaller he can minimise the difference or even just ride everywhere in the big ring.RonK wrote:Makes no sense at. If the small ring is so low you have to change to the big ring, smaller will just make it worse.michael.chaseling wrote:when I shift to the bigger chain ring, I find I then lose cadence and feel like I need to ride harder and faster. I only change up to avoid the rubbing and cross chaining, not get a dramatic increase in speed...
it all depends on more info from the OP however. what rings and cassette he currently has will make all the difference.
- silentC
Postby silentC » Fri Aug 29, 2014 10:08 am
- Me
- Derny Driver
Postby Derny Driver » Fri Aug 29, 2014 11:08 am
Yes good point, but the OP says the smallest gear isnt small enough so a larger small ring isnt an option.mitchy_ wrote:
- queequeg
Postby queequeg » Fri Aug 29, 2014 12:43 pm
When I jump from the 38 to the 46 it is very quick, and I only have to knock it back one or two clicks after shifting up to maintain the same cadence.
- CXCommuter
Postby CXCommuter » Fri Aug 29, 2014 1:03 pm
I also love my 46/38 cross crankset coupled with 11 to 27 is great and capable of hitting 60km/h if needed (not often ). There should be planty of capability to go 46/36 or 48/36 for a better set up.queequeg wrote:Well, on my commuter I run a CX chainset with 46/38 rings. I find this ideal for commuting. paired with an 11-32 cassette (or 12-32).
- Xplora
Postby Xplora » Fri Aug 29, 2014 3:17 pm
- ValleyForge
Postby ValleyForge » Fri Aug 29, 2014 4:28 pm
Would seem the simple solution....silentC wrote:Sounds like a job for a triple to me...
Postby harmonix1234 » Fri Aug 29, 2014 4:53 pm
- mitchy_
Postby mitchy_ » Fri Aug 29, 2014 5:19 pm
yep. my CX is 36/46 on a 110BCD crank.harmonix1234 wrote:Can you put a 36 / 48 combo on a 110 bcd compact crank?
Postby harmonix1234 » Fri Aug 29, 2014 5:25 pm
Postby Stephanebkk » Sat Aug 30, 2014 2:44 am
AgreedMattyK wrote:Don't waste money on a pub bike. Do what everyone else does and shift the rear sprocket down 2 or 3 gears when you upshift the chainring. And vice versa.
Postby slowK » Sat Aug 30, 2014 9:08 pm
On the other hand, I run a 12-30 cassette on the back, so I pretty much just stay in the 46T front ring for most rides I do.
- Mulger bill
Postby Mulger bill » Sat Aug 30, 2014 9:58 pm
Did you drop the front mech to compensate for the smaller ring?slowK wrote:On my old bike, I run 46/34 - replaced the 50T ring with a FSA 46T big ring on my SRAM Rival (34/50 110 BCD) cranks. The front shifting is actually worse, despite the smaller tooth difference - the ramps/pins/teeth shaping of the rings from two different brands are not directly compatible to encourage upshifts. Dropping from the 46 to the 34 is fine, but pushing back the other way is a bit sluggish. It shifts, but just not super quickly.
Postby slowK » Sun Aug 31, 2014 7:15 pm
Yep - did that. It shifts, but just not as quickly (probably an extra half pedal revolution) as the stock big ring. And the gearing is so much more appropriate for my riding that I don't mind at all.
- Bentnose
Postby Bentnose » Mon Sep 01, 2014 4:15 pm
Mulger bill wrote:Did you drop the front mech to compensate for the smaller ring?
There is a CX front mech available which is designed to work with the smaller big rings, don't know how much of a difference it makes.slowK wrote:Yep - did that. It shifts, but just not as quickly (probably an extra half pedal revolution) as the stock big ring. And the gearing is so much more appropriate for my riding that I don't mind at all.
- simonn
Postby simonn » Tue Sep 02, 2014 9:13 am
Shimano CX-70 front derailleur. Ultegra level.Bentnose wrote:Mulger bill wrote:Did you drop the front mech to compensate for the smaller ring?There is a CX front mech available which is designed to work with the smaller big rings, don't know how much of a difference it makes.slowK wrote:Yep - did that. It shifts, but just not as quickly (probably an extra half pedal revolution) as the stock big ring. And the gearing is so much more appropriate for my riding that I don't mind at all.
I've got two. One on my CX 46/36 crankset (Shimano CX-50) 105 5700 shifters and one on my audax bike 46/30 crankset (Sugino OX601D) with campy veloce shifters. Very snappy for both, but not sure if it really makes a difference...
46/30 rocks for anything except racing/fast group rides. 46 is low enough that you rarely have to change at the front, but you have super low gears (I have 13-29 cassette) for the super steep hills (I can do 20% seated). Will probably go a 12-30 cassette next time though (I already had a spare 13-29 cassette).
- Xplora
Postby Xplora » Tue Sep 02, 2014 10:14 am
Audax is a different story - they can't make a low enough gear once you've passed 250kms, even 2-3% feels like 30% that far in.
