Power Meter !!
Power Meter !!
Postby TZ2102 » Wed Sep 17, 2014 11:20 am
I want a power meter. I'll never be a professional but I do enjoy training and seeing improvement. I am a student so I also want to keep a check on the expenditure.
I think my options are as follows
- Power Tap Rear Wheel (G3)
---Normal Alloy Wheel (G3 or something) for about 900AUD
--- Reynolds 81mm Carbon Tubular I can get for about 1250 AUD (but I can only do this when I go to the US in a month) - worried about durability and tubular punctures but it is a very good price I understand which is what is drawing me in
- Power2Max (heard they were pretty good (the new ones)) I think its about $900-1000 for the base model
- Stages (not so keen because only the left foot)
- Wait for Precision 4iii (http://www.dcrainmaker.com/2014/09/4iii ... ision.html" onclick="window.open(this.href);return false;)
- 2nd hand? Powertap?
Keen to get some advice.
TZ
EDIT: I am on a 1.5k bike so when I get a proper job after uni will probably upgrade and I it would be good if I can take the power meter with me...I think for all of these you can.
Re: Power Meter !!
Postby petal665 » Wed Sep 17, 2014 12:19 pm
Re: Power Meter !!
Postby apollocreed » Wed Sep 17, 2014 12:45 pm
Knowing where you're fastest and where you're slowest provides you with focus points on improvement.
By comparing regular data from rides you can also determine if your training is working in the right way or not
to the OP, I would love a power meter. However, it's worth thinking whether you can justify it or not? Assuming you've got a bit of time at uni still, may be worth saving now, riding your bike as much as you can and as hard as you can (with a GPS or strava or whatever to satisfy the data and numbers urge) and when you upgrade to a decent bike you can incorporate the cost of a power meter into it
Re: Power Meter !!
Postby petal665 » Wed Sep 17, 2014 12:53 pm
That can be done with a $20 wire bike computer.apollocreed wrote: Knowing where you're fastest and where you're slowest provides you with focus points on improvement.
Re: Power Meter !!
Postby TZ2102 » Wed Sep 17, 2014 12:58 pm
- Alex Simmons/RST
Re: Power Meter !!
Postby Alex Simmons/RST » Wed Sep 17, 2014 1:05 pm
There will always be an as yet unproven new power meter model on the horizon. My advice is to stick with proven models that have service and backup support in place.
I updated my "Which Power Meter?" blog post the other day:
http://alex-cycle.blogspot.com.au/2013/ ... meter.html" onclick="window.open(this.href);return false;
- Alex Simmons/RST
Re: Power Meter !!
Postby Alex Simmons/RST » Wed Sep 17, 2014 1:08 pm
No one NEEDS a power meter and the OP didn't say they did need one.petal665 wrote:Unless you have a power based training program, (which you stick to), you DO NOT NEED A POWER METER. Unless you have a power based training program and do the associated testing you won't notice 'improvement' by just looking at numbers.
They said they wanted one, and came here looking for advice on models suitable for them.
As for assessing improvement and the process and what one can use a power meter for, here's a hint: following a training plan is only one of many dozens of things one can usefully use it for.
As for not noticing improvement, quite the contrary. Once you become reasonably fit, the gains get smaller and power becomes a far more reliable means to assess whether you're making fitness progress, changes that would not be discernible via other means.
- Xplora
Re: Power Meter !!
Postby Xplora » Wed Sep 17, 2014 1:16 pm
Re: Power Meter !!
Postby petal665 » Wed Sep 17, 2014 1:50 pm
My experience is that Stages reads low, Quarqs are more reliable that they used to be, and that Powertaps seem to die a lot. I would never buy a 2nd hand power meter without some form of warranty backup.
Re: Power Meter !!
Postby TZ2102 » Wed Sep 17, 2014 2:04 pm
- kb
- CXCommuter
Re: Power Meter !!
Postby CXCommuter » Wed Sep 17, 2014 2:38 pm
Re: Power Meter !!
Postby TZ2102 » Wed Sep 17, 2014 2:53 pm
out of the 2 powertap wheels which do you suggest...what is the approximate cost of maintenance regarding tubulars...e.g. for clinchers ~a puncture 2 months is like $50 year + maybe a set of tyres so a total of 130$ p.a.
Re: Power Meter !!
Postby petal665 » Wed Sep 17, 2014 3:00 pm
Re: Power Meter !!
Postby TZ2102 » Wed Sep 17, 2014 3:07 pm
Ride 6-10 hours a week, maybe more in the holidays
- toolonglegs
Re: Power Meter !!
Postby toolonglegs » Wed Sep 17, 2014 3:10 pm
Cost me $600 Au new 9 months ago ... New eBay hub and then wheel build.
I would go the clincher to start with ... Less hassle by far.
Personally I don't run my power meter every ride ... Mainly on my TT bike for the moment. Without it I wouldn't have noticed the HUGE power difference between my road bike and TT bike ( 360w vs 300w for 20m! ) ... My puzzle has been working out how to get the power up at least 10% while still staying aero
- Alex Simmons/RST
Re: Power Meter !!
Postby Alex Simmons/RST » Wed Sep 17, 2014 3:15 pm
That's very much dependent on where and how much you ride, but for convenience I'd stick with clincher rims. Easier to swap over tyres when you want and fix out on the road with a spare tube and CO2 inflator. I'd really only bother with tubs for racing.TZ2102 wrote:Thanks Alex,
Powertap have sent me two of their clincher wheelsets to use for aerodynamics testing - one set DT Swiss rims and the other carbon ENVE deeper section wheelset.
Re: Power Meter !!
Postby TZ2102 » Wed Sep 17, 2014 6:18 pm
- Alex Simmons/RST
Re: Power Meter !!
Postby Alex Simmons/RST » Wed Sep 17, 2014 9:47 pm
Suggest talking with a wheel builder who can give sound advice on a wheel build suitable for you and your needs. I only mentioned those wheels as they are pre-built Powertap supplied, instead of buying a hub and building one up yourself.TZ2102 wrote:are the DT Swiss RR 585 a decent rim for it? are they better than the standard G3 Alloy wheel or Velocity Chukker?
Re: Power Meter !!
Postby Baalzamon » Wed Sep 17, 2014 10:18 pm
Re: Power Meter !!
Postby TZ2102 » Thu Sep 18, 2014 8:25 am
- how many spokes is the best? There's no difference in price from 20-32. I weigh 68
- normal or aero spokes? $50 price difference
- aero jacket disc wheel ($60)
- Xplora
Re: Power Meter !!
Postby Xplora » Thu Sep 18, 2014 8:44 am
The inability of the wheel to run as a strong training wheel vs light racing wheel was the key issue to me. It is really clear from a few months of playing with data that you are doing yourself a disservice.
Bear in mind that Alex has more PMs than most people have bikes. He can afford to be choosy
- Alex Simmons/RST
Re: Power Meter !!
Postby Alex Simmons/RST » Thu Sep 18, 2014 12:52 pm
- toolonglegs
Re: Power Meter !!
Postby toolonglegs » Thu Sep 18, 2014 3:03 pm
Re: Power Meter !!
Postby TZ2102 » Thu Sep 18, 2014 4:15 pm
