What does the wrong size bike feel like?
Postby Azee » Tue Sep 30, 2014 9:44 pm
When I test ride a bike, how can I tell which size suits me, and what does the wrong size feel like?
- Duck!
Re: What does the wrong size bike feel like?
Postby Duck! » Tue Sep 30, 2014 10:31 pm
A bike that is too small will feel cramped; to the point of feeling like you're going to fall over the front of the bike if it's really undersized for you.
Postby Azee » Tue Sep 30, 2014 11:28 pm
Do a couple of centimeters make such a difference though?
Postby reefer » Wed Oct 01, 2014 1:52 am
Having a frame the incorrect size will most likely cause substantial damage to you. As you can imagine, cycling puts repetitive strain on your body, carried out for hours a day will most definitely injure you.
Take the time to read as much as you can about different perspectives on bike types and fit. Understand how your body fits a bike frame.
Then, try out as many bikes as you can for at least a few hours each. At least 2 bike stores in my area will allow overnight or extended trials.
A bike thats fit for purpose and fits you well is the Number 1 priority.
(I ride for fitness and don’t race, but can ride up to 4 hours a day. Comfort is important to me as it brings efficiency)
- toolonglegs
Postby toolonglegs » Wed Oct 01, 2014 5:41 am
Don't stress over it too much... Saddles move up and down 10-25 cms and forward and back 5-10 cms ( depending on seat post ) ... stems on a road bike can be anywhere between 60-150mm long ( 80-120 is normal'ish range ) .
I have never test ridden a road bike in my life.
Personally I can ride a 58-63cm bike quite happily... some days at work I get given a hire bike for 6 hours riding... maybe I am just not fussy
- cancan64
Postby cancan64 » Wed Oct 01, 2014 7:53 am
Postby Nobody » Wed Oct 01, 2014 8:10 am
- bychosis
Postby bychosis » Wed Oct 01, 2014 9:17 am
Have a look here: http://www.competitivecyclist.com/Store ... orBike.jsp
- ohexploitable
Postby ohexploitable » Wed Oct 01, 2014 10:07 am
both are set up the exact same, i.e. identical saddle-BB height, identical saddle setback, identical saddle-handlebar length, identical saddle-handlebar drop etc.
both feel the same (position-wise)
i don't see any reason why you can't have a bike that's a few cm's off and compensate with appropriate stem/seatpost adjustments
- Gordonhooker
Postby Gordonhooker » Wed Oct 01, 2014 10:54 am
I had an issue trying to work out the best size for me initially because I am short in the legs and long in the trunk and it seemed I was on the cusp of a small to medium frame, for my fixie I ended up going medium and a slightly higher angle on the stem, and flipped my bullhorn bars up and now it fits like a glove.
Postby tron07 » Wed Oct 01, 2014 5:27 pm
- silentC
Postby silentC » Wed Oct 01, 2014 5:44 pm
I wish someone would tell me. I've been riding the same bike for years and I have had different people tell me it is too big AND too small for me. Just call me Goldilocks...how can I tell which size suits me
- Me
- RonK
Postby RonK » Wed Oct 01, 2014 6:04 pm
Since there is a least a consensus that it is the wrong size for you, then the wrong size must feel like the bike you're riding.silentC wrote:I wish someone would tell me. I've been riding the same bike for years and I have had different people tell me it is too big AND too small for me. Just call me Goldilocks...how can I tell which size suits me
- Duck!
Postby Duck! » Wed Oct 01, 2014 8:06 pm
It took a while, but component manufacturers have finally realised that there are different sized riders, so most brake levers these days have some kind of reach adjustment mechanism.tron07 wrote:I got small hands, feel hard to grab the brakes suddenly if my hands are not ready at the brakes level, ie if something jumps in front of me.
Postby rogerrabbit » Wed Oct 01, 2014 8:13 pm
Top tube and seat tube lengths are key aspects, but seat to bar drop is also important. A smaller frame with a short head tube is going to give a pretty big drop to the bars, which also increases the reach by the way. Some racing frames are going to be stiffer, sharper handling and perhaps more harsh as far as transmitting shock to the rider from the road. Other frames are going to have a more relaxed geometry, but may put you in a more upright position with a shorter distance to the bars. This can suit a lot of riders, and I would guess that newer riders will often prefer a more upright position, as May some older riders that are less flexible. I personally prefer a more racing position, even for general riding, but I have been on racing bikes for nearly 40 years. I find I can fit frames from 58 to 62cm in the top tube, but largely compensated for by seat and stem and bar choice and adjustment. I struggle with too much bar drop, and with bars that are too narrow. I would say bar width is a key issue for me. Finally I want a frame that has good balance. This could be a racing or a touring frame, but the bike should be neutral and stable in all circumstances. If it flops into a turn or feels unnatural, then the geometry may be off (usually fork rake to head angle balance in my experience).
Crank length - I ride from 165 to 175 on different road bikes, and I really cannot tell the difference.
After that diatribe, try riding lots of different bikes, and try to get a sense of what works for you, and what doesn't.
Roger
Postby cage » Wed Oct 01, 2014 10:00 pm
viewtopic.php?f=9&t=78945&p=1177427#p1177427
Postby tron07 » Thu Oct 02, 2014 10:02 am
I will research on this to see if I can play with it or not, else will get the shop to adjust on my first service.Duck! wrote:It took a while, but component manufacturers have finally realised that there are different sized riders, so most brake levers these days have some kind of reach adjustment mechanism.tron07 wrote:I got small hands, feel hard to grab the brakes suddenly if my hands are not ready at the brakes level, ie if something jumps in front of me.
Postby Six13 » Thu Oct 02, 2014 1:36 pm
I have a 58 and thats the problem I have with it. I measure the nose of the saddle to the back of the brifters, and also the vertical drop from nose of saddle to top of brifters. While this might not be scientifical, seems to work for me.rogerrabbit wrote: seat to bar drop is also important. A smaller frame with a short head tube is going to give a pretty big drop to the bars, which also increases the reach by the way.
- rodneycc
Postby rodneycc » Thu Oct 02, 2014 11:07 pm
Or get the shop to rotate the bars backwards a little more so the hoods come back your way a little more. I had similar problems with my hands.tron07 wrote:I will research on this to see if I can play with it or not, else will get the shop to adjust on my first service.Duck! wrote:It took a while, but component manufacturers have finally realised that there are different sized riders, so most brake levers these days have some kind of reach adjustment mechanism.tron07 wrote:I got small hands, feel hard to grab the brakes suddenly if my hands are not ready at the brakes level, ie if something jumps in front of me.
