How To Choose The Correct Size Of Road Bike Frame
- RonK
Postby RonK » Sun Oct 05, 2014 12:30 pm
Mods please make this thread a sticky.
Agreed, pedal spanner with 1m breaker bar applied, it aint going nowhere, ever!
Reason: Made sticky
Re: How To Choose The Correct Size Of Road Bike Frame
Postby Blinding » Sun Oct 05, 2014 9:40 pm
Postby tron07 » Mon Oct 06, 2014 10:02 am
Postby cyclebee » Sat Feb 07, 2015 12:03 pm
There were a lot of talking in the video, but frankly, I did not think it answered the question - "How to choose the correct size road bike frame?"RonK wrote:Ok, this is an faq on the forums, and this video by the Global Cycling Network has gone some way to helping you answer it. It's well worth your while to subscribe to the GCN, and invaluable if you are a beginner cyclist, as they have produced an excellent range of videos to address many of the faq that arise over and over, such as how to perform a basic bike fit, how to position cleats, what tools you need, and how to clean your bike, and many, many more. If fact there are very few questions I can think of that are not answered. And there's some great humour too. Check them out.
Postby Jason1170 » Sat Sep 19, 2015 5:10 pm
- ValleyForge
Postby ValleyForge » Sun Sep 20, 2015 11:16 am
Probably best in a separate post, rather than tagged on here.Jason1170 wrote:I am after advice in relation to buying a 2014 Giant TCR, I am 189cm tall and going by the Giant sizing guide I should need a large. I have got mixed advice from bike shops who have said I need a large or I could ride a M/L. Can anyone give me some advice.
Too many variables to consider. On the face of it, yes you would be an L. But you could ride some brand's M/L quite happily, say in a flat bar configuration with a long stem and a lot of seat setback and be pretty OK for rides < 1Hr. But I doubt that's what you're looking for!
And there is fashion to consider - when I was working in my LBS in the 80s, you encouraged buyers up a size - better chest expansion with more reach, lower profile, more aero. Then maybe 10yr ago it was more like a M frame, put the pole up a lot, sitting forward on the seat, stack slammed down.
Don't ask me now where the fashion is! You just need an LBS which will listen to you and give you a good test ride.
Postby ozbiko » Sat Jan 23, 2016 11:52 am
- singlespeedscott
Postby singlespeedscott » Sat Jan 23, 2016 5:56 pm
- ProBikeFit
Postby ProBikeFit » Fri Feb 05, 2016 2:38 pm
If you are ave height say 180cm a 54 to 56cm frame would suit keep in mind Italian frames and Cannondale run traditional shape frame (shorter steerer tube) while Cervelo and Trek use longer steerer tubes on equivalent size frame to Italian. regards ProBikeFit
PS what is wrong with your back?
Postby Dufer91 » Mon Feb 08, 2016 7:15 pm
2016 Polygon Path 2 - 29er City Bike https://www.bicyclesonline.com.au/2016- ... -city-bike" onclick="window.open(this.href);return false;
What do you guys think?
Postby Harrys767 » Tue Feb 16, 2016 5:06 pm
Good on you for getting the motivation to shed the kgs. That's why I got into cycling initially. I don't know the specifics of that model, but in general so,etching like that bike will be a good starting point. It's a relaxed posture and you won't need to worry about damaging the frame. As you get lighter, more flexible and faster you will start to naturally look around at "better" bikes. ie bikes that suit your riding style more (road, hybrid etc). I've just purchased my first proper road bike and am loving it.
I'd recommend that you buy a basic bike computer as the data will be a big motivator (distance and average speeds etc). But make sure includes a heart rate monitor as you have the ability to monitor your heart rate zone and can keep it in the best band for weight loss.
I'm a relative newly, so plenty of other will have opinions too.
Good luck!
Postby Dufer91 » Tue Feb 16, 2016 9:58 pm
Postby AlMac » Tue Mar 08, 2016 3:17 pm
It will help you get the right frame and then set it up comfortably.
Well worth the investment.
One of the best you can make.
Postby Ant_S » Tue Apr 26, 2016 4:22 pm
I've bought 3 bikes new and all have been big to varying degrees, the latest cost me over $2k and is about right with a 90mm stem. However it took me to work that out and buy & install the stem...
None of the staff offered me any fit services, none of them set the bikes up for me properly to test ride (they just eyeballed the seat post at best) and overall I've done my own 'fit' just from riding.
I do agree totally on the Bike Fit side, I got a basic $50 fit done on a wind trainer at my trusted LBS and that alone confirmed my thoughts. Sadly though you sometimes have to buy where the deal is best so you have to rely on your own knowledge & instincts.
I think being careful of effective c-c Top Tube is important, as some frames are fairly 'square' while others are more stretched.
Postby CyclingPat » Mon May 09, 2016 1:09 pm
AlMac wrote:The simple answer is to get a Bike Fit.
I would second this.
Bought a MTB a while back from a proper bike shop. Unfortunately I was naive, knew nothing about bike fit and the salesman sold me whatever and I was on my way. Wasn’t long before I was getting lower back and right hip pain. Fast forward to second bike (roadie) purchase from a different LBS who knew their stuff and took to time to do a proper bike fit. Ordered in the right sized frame, not just what was sitting on the shop floor, and made all the adjustments needed. Long term, rides like a dream.
Postby cyclebee » Mon May 09, 2016 6:28 pm
Postby TheWall » Mon May 09, 2016 7:40 pm
Yep...was new to riding roadies and bought a bike that was simply too small...they "fitted" me alright ..was pressured by the LBS and I felt compelled as colleagues parents owned it...anyways did my best and even did the 165k Brisbane to Noosa in 09 on it but was so broken by the end of that ride I did not cycle for almost three years...when I bought a correctly sized bike...and was fitted correctly!cyclebee wrote:Anyone had a 'bad' bike fit?
Postby bikingburrito » Sat Jun 25, 2016 8:22 pm
My last bike was a trek 7.5fx 51cm and my current bike is a Cube sl cross pro with a 56cm frame
and it fits better and is more comfortable than the 51cm.
Each bike brand has a unique size and you have to experience a few different bikes for yourself
as the previous comment states that a "bike fit" is not the total be-all and end-all solution.
You can make a smaller frame suit a larger rider but you can't make a bigger frame suit a smaller rider.
Postby Ivanerrol » Mon Dec 05, 2016 6:16 pm
I was fortunate that one of the bikes was the right size but with trial and error got it comfortable.
The other bike I put up with for a few hundred K's until - it just wasn't the right size - put it back on the auction site.
I went to one of the LBS's were the owner, not only being the main fitter was also a fitness instructor, Pilates instructor and had studied bone structure and chiropractery.
I learned more in one hour than years of self trial and error would ever achieve.
First question was very important - what sort of cycling do you want to do?
I was fitted up with my hybrid. However the flat bar roadie was completely different.
Endorsement for Bike fit. Make sure you go to an LBS who insists on one before choosing the size.
Postby RobertL » Thu Jan 12, 2017 5:44 pm
I presume that for whatever style of bike, from whatever manufacturer, I could safely just buy the biggest frame size option. Would that be right?
- singlespeedscott
Postby singlespeedscott » Thu Jan 12, 2017 6:55 pm
No. At 190cm your not the tallest cyclist that I know and you would best served visiting a reputable shop or bike fitter to determine what size frame you require. The style of riding you wishto do will also influence the size frame you will rideRobertL wrote:I'm 190 cm tall with average leg to torso ratio but quite long arms.
- silvinator
Postby silvinator » Mon Jan 30, 2017 3:48 pm
Silvie
"Janeway" Trek Madone 4.5 WSD 2012
- Rural Rider
Postby Rural Rider » Sun Feb 12, 2017 5:15 pm
RR.
2016 Specialized Allez e5 Sport
Postby owly » Sat Feb 18, 2017 6:15 pm
If you have a tall inseam relative to your height (like moi) and arms a bit on the short side, you can forget about those charts!
- singlespeedscott
Postby singlespeedscott » Sun Feb 19, 2017 5:19 pm
56cm is a very small frame for a someone as tall as you. Do you have short legs for your height/Rural Rider wrote:Bike Sizing? Don't believe the manufacturers advice on Frame Size. I just went through this with all data and charts telling me that at 183cm tall, I am a size 58 Frame! Went to the Bike store and right away the Sales cat says ... 'Oh no you're not' ... in complete contradiction of what the Manufacturing Frame Data states. Turns out I was absolutely perfect for a 56 Frame size and one size smaller than what that very Bike Company stated I should be on. So bottom line ... if you can, go physically sit on the bike - you'll save yourself a lot of trouble.
RR.
Out of interest was the bike already on the floor or did they order it in after sizing you up?
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
Users browsing this forum: OnTrackZeD
- All times are UTC+11:00
