henders
Postby henders » Sun Oct 12, 2014 11:10 am
am50em
Re: Schwalbe Marathon Plus and tyre size
Postby am50em » Sun Oct 12, 2014 11:14 am
It will fit but will be 3mm narrower.
henders
Postby henders » Sun Oct 12, 2014 11:25 am
am50em
Postby am50em » Sun Oct 12, 2014 11:39 am
Wider tyres are generally more comfortable without much change in rolling resistance.
The total circumference of a 32 tyre will be less so slightly lower gearing overall.
But at this size I do not think the 3mm size will make much difference.
http://janheine.wordpress.com/2013/05/2 ... ters-make/
http://www.slowtwitch.com/Products/Thin ... _4026.html
http://www.bikequarterly.com/images/TireDrop.pdf
Postby Aushiker » Sun Oct 12, 2014 11:56 am
henders wrote:
am50em wrote:It will fit but will be 3mm narrower.
Is this a good thing or a bad thing? Sorry, me a bike noob.
What is your intended use? These tend to be on the heavy side in the world of tyres but offer greater puncture protection.
rangersac
Postby rangersac » Mon Oct 13, 2014 9:24 am
henders wrote: However, my tyre size is 700x35c whereas this one is 700 x 32mm - is this going to fit in my bike?
If you currently have 35mm wide tyres the 32mm will fit. In my experience SMPs tend to run wider than their stated width, although this is somewhat dependent on the rim. Functionally I doubt you'll notice any difference between a 35 and a 32.
De Rosa Macro | Intense Primer | Wayward Cape York | Cotic Rocket
