Altitude readings - GPS versus Barometric
- limbot
Postby limbot » Fri Oct 24, 2014 10:50 am
Bit of a difference here The top one is via a Galaxy S3 running Strava, the bottom using a Garmin 1000
Here's how the S3 records the altitude
Here's how the Garmin records the altitude.
Interestingly enough I've done this ride about 3 times and the S3 records as around 1300 M for the 3 rides. It's worth noting that the ride is on a fairly heavily forested area on a hillside ( it's the Pipeline Track Mount Wellington).
Distance is pretty close on both and I did do some backwards/forwards riding that the other rider didn't while waiting/checking on other riders
Looking at other rides recorded with the S3 however this problem doesn't occur, it's obviously just the location of this ride.
Worth considering when deciding on what device to record with
- SheikYerbouti
Re: Altitude readings - GPS versus Barometric
Postby SheikYerbouti » Fri Oct 24, 2014 10:59 am
- sogood
Postby sogood » Fri Oct 24, 2014 11:22 am
- limbot
Postby limbot » Fri Oct 24, 2014 11:23 am
- silentC
Postby silentC » Fri Oct 24, 2014 11:31 am
So if you were 3/4 of the distance between two contours but it was relatively flat up to that point, they might read you higher than you actually are. I'm sure it's more complicated than that. I've written to them about a couple of issues along those lines but you basically get a shrug of the shoulders.
- Me
- limbot
Postby limbot » Fri Oct 24, 2014 11:37 am
. For devices without barometric altimeters, we consult elevation databases to determine the elevation at each point in the activity. The resolution of these databases can vary based on location. For example, the USGS National Elevation Dataset (NED), which we consult for activities located in the US, generally has a 10 meter resolution though some small areas have a 3 meter resolution. For activities located outside of the US, we consult the ASTER and SRTM databases which have a resolution of 30 meters and 90 meters respectively.
- silentC
Postby silentC » Fri Oct 24, 2014 11:41 am
I was looking at one yesterday which shows about a 2 metre change in elevation as you cross the road.
- Me
Postby lobstermash » Fri Oct 24, 2014 11:54 am
- MattyK
Postby MattyK » Fri Oct 24, 2014 12:08 pm
http://www.strava.com/activities/118880736" onclick="window.open(this.href);return false;
Postby Great Scott » Fri Oct 24, 2014 12:40 pm
That's to do with atmospheric changes. I use a Garmin 510.lobstermash wrote:I find that when it's raining/wet, my 510's barometer goes well out of whack, giving all sorts of strange altitude profiles and usually under-reading by a long way - not quite as extreme as your example though!
Riding down Beach Road (Melb), if I have cold cloudy front passed over, my elevation will drop -10 to -20m below sea level and returns to normal when weather front has passed over.
- silentC
Postby silentC » Fri Oct 24, 2014 1:25 pm
If you look at the contours, you can see that the zig-zagging sections in the elevation chart correspond to where you are riding parallel to the steepest parts of the terrain, so the change from one contour to the next is compressed. Every time your route crosses the contour line, they are putting you proportionally higher or lower, even though your elevation is not changing that much because you're basically straddling the contour line all the way. They would be assuming a straight line between contours, which is the only thing they can really do.MattyK wrote:I did 20km on the Great Ocean Road once, Strava/iPhone logged 1000m+ of climbing... Must have thought I was jumping up and down the cliffs or something.
- Me
- biker jk
Postby biker jk » Fri Oct 24, 2014 1:35 pm
Actually, it's due to water getting into the barometer sensor hole in the Garmin. I've had the same experience as lobstermash in the rain where the Garmin has stopped recording any altitude change and/or giving a -2% slope when climbing. If you use a cover for the Garmin it's less likely to happen.Great Scott wrote:That's to do with atmospheric changes. I use a Garmin 510.lobstermash wrote:I find that when it's raining/wet, my 510's barometer goes well out of whack, giving all sorts of strange altitude profiles and usually under-reading by a long way - not quite as extreme as your example though!
Postby Great Scott » Fri Oct 24, 2014 1:57 pm
I've never heard of "contours" being used when discussing GPS, that's an old paper mapping concept isn't it?.silentC wrote:If you look at the contours, you can see that the zig-zagging sections in the elevation chart correspond to where you are riding parallel to the steepest parts of the terrain, so the change from one contour to the next is compressed. Every time your route crosses the contour line, they are putting you proportionally higher or lower, even though your elevation is not changing that much because you're basically straddling the contour line all the way. They would be assuming a straight line between contours, which is the only thing they can really do.MattyK wrote:I did 20km on the Great Ocean Road once, Strava/iPhone logged 1000m+ of climbing... Must have thought I was jumping up and down the cliffs or something.
GPS has poor accuracy at calculating vertical height, triangulation of satellites simply struggle because there being asked to estimate a distance which is near parallel to their line-of-sight. Vertical accuracy can be as bad as +/-20m up/down (varies).
Your device tracks your position by logging GPS data points every 0.1-2.0 secs depending on your device settings. Garmins can be adjusted, phones generally cant. Higher number of data points translates to better the accuracy.
At each GPS data point, your device attempts to calculate your position XYZ from scratch. With the vertical estimate being poor, your elevation points are logged up/down eg. -10m to +10m even if you may be riding on near level ground.
Barometric data is far more accurate because it records changes in pressure (converted to elevation.) It take the previous data point recorded and adjusts the elevation based on the change. Even if you don't calibrate your starting altitude, it will still more accurately record overall climbing and ascending for a ride.
Strava has elevation correction as an option for those using GPS altitude data. I have mates record ridiculous climbs on their Iphones, eg. 4500m going up Mt. Buffalo (1400m?). They dont correct it because it looks good on their stats.
- silentC
Postby silentC » Fri Oct 24, 2014 2:24 pm
Now if you look at the contours on the actual overlay map on Strava, you will see that when the route meanders either side of a contour line, there is a lot of fluctuation in the elevation plot. I am drawing the conclusion that this is because their extrapolation is placing you somewhere along a line between point A and point B and then estimating an elevation based on the difference between the two and how far along it you are.
From what I can gather, they don't use GPS elevation data at all if they can avoid it. They prefer altimeter, but use elevation data cross referenced to the GPS lat and long in preference to the GPS calculated elevation.
- Me
- silentC
Postby silentC » Fri Oct 24, 2014 2:39 pm
c1
__\
___\
____\_____c2
___________\
What Strava thinks it looks like:
c1
____\
______\
________\
__________c2
___________\
So you are riding along an elevation at C2. If your route takes you closer to the slope, then Strava will plot you higher up than you actually are because it can't know that you're on a plateau since the elevation database doesn't have fine enough resolution.
- Me
- wombatK
Postby wombatK » Fri Oct 24, 2014 2:47 pm
Have you actually done that ? I've owned three Garmin devices (705 and two 500's) and a Bryton Rider 35 which also has a barometric altimeter.Great Scott wrote: Barometric data is far more accurate because it records changes in pressure (converted to elevation.) It take the previous data point recorded and adjusts the elevation based on the change. Even if you don't calibrate your starting altitude, it will still more accurately record overall climbing and ascending for a ride.
None of them produce anything but rubbish for their altitude plots ... you can calibrate them all you like, and then ride around a 5 km loop like Sydney Olympic Park and find elevation increases by 5m or more per 5km lap. Every time you do it (i.e. irrespective of weather conditions). And I've been at -20 to -100m altitude so many times it's a wonder I'm still breathing.
On the other hand, I've checked the height accuracy of my various GPS devices (car, phone, pocket PC etc.,.) against a number of different trig stations and found them to be within a few meters on height and latitude and longitdue.
Provided you can see the sky, the GPS data or even the interpolated data that Strava and other elevation lookup tools produce is better than
the barometric sensors readings any of my devices gives.
- biker jk
Postby biker jk » Fri Oct 24, 2014 3:56 pm
Just to back up this point my Garmin recorded my altitude as -100m when I was on the Pacific Hwy, 1km north of the Hawkesbury river. I had to set the altitude to 30m manually for the readings to make any sense on the ascent of Mt White.wombatK wrote:Have you actually done that ? I've owned three Garmin devices (705 and two 500's) and a Bryton Rider 35 which also has a barometric altimeter.Great Scott wrote: Barometric data is far more accurate because it records changes in pressure (converted to elevation.) It take the previous data point recorded and adjusts the elevation based on the change. Even if you don't calibrate your starting altitude, it will still more accurately record overall climbing and ascending for a ride.
- sogood
Postby sogood » Fri Oct 24, 2014 4:17 pm
- Tim
Postby Tim » Fri Oct 24, 2014 5:06 pm
Water in the sensor will definitely upset the readings, but, when a front is approaching this is a different situation.biker jk wrote:Actually, it's due to water getting into the barometer sensor hole in the Garmin. I've had the same experience as lobstermash in the rain where the Garmin has stopped recording any altitude change and/or giving a -2% slope when climbing. If you use a cover for the Garmin it's less likely to happen.Great Scott wrote:That's to do with atmospheric changes. I use a Garmin 510.lobstermash wrote:I find that when it's raining/wet, my 510's barometer goes well out of whack, giving all sorts of strange altitude profiles and usually under-reading by a long way - not quite as extreme as your example though!
As a cold front approaches the barometric pressure will gradually decrease. When the front is very close and as it passes overhead the air pressure will suddenly rise until it has passed through and returns back to the approximate pre-frontal lower pressure . The Garmin is fooled into thinking you have rapidly descended in altitude ie. descending altitude leads to higher pressure.
Having said that, my Edge 800 produces some very whacky elevation readings. Very rarely the same on identical consecutive rides. It all depends on the constantly changing air pressure/s on the day/s.
- sogood
Postby sogood » Fri Oct 24, 2014 5:16 pm
True scenario. That's also why one needs to activate continuous calibration in the settings, so that the unit will make a decision by incorporating both the baro and GPS data input. If one wants to record the barometric reading for weather prediction, then one needs to set 'fixed elevation' in the settings. Otherwise and if there's good GPS signal, 'Continuous' calibration is best. With the crossing of a front and depending on the rate of change, there may still be a dip or blip, but it'll soon be normalised. That's just a fact of this technology. In any case, aircrafts also use barometer for altitude readings.Tim wrote:...when a front is approaching this is a different situation.
- biker jk
Postby biker jk » Fri Oct 24, 2014 6:07 pm
Where is the "continuous calibration" setting on the Garmin 800?sogood wrote:True scenario. That's also why one needs to activate continuous calibration in the settings, so that the unit will make a decision by incorporating both the baro and GPS data input. If one wants to record the barometric reading for weather prediction, then one needs to set 'fixed elevation' in the settings. Otherwise and if there's good GPS signal, 'Continuous' calibration is best. With the crossing of a front and depending on the rate of change, there may still be a dip or blip, but it'll soon be normalised. That's just a fact of this technology. In any case, aircrafts also use barometer for altitude readings.Tim wrote:...when a front is approaching this is a different situation.
- sogood
Postby sogood » Fri Oct 24, 2014 6:16 pm
Good question. It's on my Garmin Oregon 650.biker jk wrote:Where is the "continuous calibration" setting on the Garmin 800?
Given that the thread is not device specific and I occasionally use my O650 or iPhone on rides, I was just suggesting that there are various settings that may come into play on this. My new iPhone6 now has a barometric sensor but it seemed to be buried and controlled by iOS presets. I am still testing its performance characteristics.
Postby BaldPatch » Fri Oct 24, 2014 7:10 pm
Erroneous readings of gradient and elevation can also occur when riding in the rain.Great Scott wrote:That's to do with atmospheric changes. I use a Garmin 510.lobstermash wrote:I find that when it's raining/wet, my 510's barometer goes well out of whack, giving all sorts of strange altitude profiles and usually under-reading by a long way - not quite as extreme as your example though!
There is a small barometric pressure sampling port on the front right of the Garmin, when water enters this port it affects readings.
- Tim
Postby Tim » Fri Oct 24, 2014 7:38 pm
If it's on the 800 I've never been able to find it and I know the 800 menu items back to front.biker jk wrote:Where is the "continuous calibration" setting on the Garmin 800?
Weirdly though a very few time a message has popped up along the lines of "Automatic Elevation Calibration" or words to such effect on startup, but I've only seen it once or twice. I thought maybe the barometric elevation reading may have been being calibrated to the installed mapping software contours.
- sogood
Postby sogood » Fri Oct 24, 2014 7:45 pm
