Narrow handlebars?
- Xplora
Narrow handlebars?
Postby Xplora » Wed Nov 12, 2014 8:08 pm
What experiences have people had with narrower bars? We're starting to compromise some serious leverage once we're down from 44 to 40 across
- rodneycc
Re: Narrow handlebars?
Postby rodneycc » Wed Nov 12, 2014 10:57 pm
Maybe you need a backpack with a couple of bricks it it to test it out
- Xplora
Postby Xplora » Thu Nov 13, 2014 9:21 am
- mitchy_
Postby mitchy_ » Thu Nov 13, 2014 9:30 am
Postby danny the boy » Thu Nov 13, 2014 10:20 am
Postby macca33 » Thu Nov 13, 2014 10:22 am
I'd say stick with 42 - 44cm bars.
- Derny Driver
Postby Derny Driver » Thu Nov 13, 2014 10:31 am
Narrower is more aero which is why we have the trend for super narrow bars on track bikes and why time triallists have their hands almost together in the tuck position.
I have no idea why bikes come standard with 44 cm bars these days. I guess manufacturers think everyone has the build of a gorilla. For about 80 years the standard width was 38cm then someone decided to change it.
My son is 6'2 and uses 42cm bars (I threw away the 44cm ones).
- g-boaf
Postby g-boaf » Thu Nov 13, 2014 10:40 am
Why do you feel you'd benefit from this? More aero, or more comfort? Look at comfort and proper fit as the first priority. If they aren't right, then you won't perform properly because you'll be dealing with aches and pains. Don't just change them for the sake of aero alone. A bike-fitter can pick this easily enough.Xplora wrote:but I feel I'm too open at the front, and would benefit from a bit more aero tuck.
Go talk to Tom Petty at Pave the way (http://www.pavetheway.cc/" onclick="window.open(this.href);return false;) if you want a second opinion. He'll give you no nonsense advice.
- Xplora
Postby Xplora » Thu Nov 13, 2014 11:22 am
I know there are limits around what you can cope with, width wise as well, you never know if you never try That said, I'm noticing I am much more comfortable with the Rotundos than the Bontrager "ergosum" bars, even on the same width.
Postby dalai47 » Thu Nov 13, 2014 12:22 pm
I have continued to go narrower on all bikes - down to 40cm on the road bikes and just bought 37cm Scatto bars for the new track bike. Added benefit of narrow bars on top of aero is being able to slip through smaller gaps...
Frontal area.mitchy_ wrote:f your shoulders are wider than the bars, i fail to see how you'll be more aero?
- coyote
Postby coyote » Thu Nov 13, 2014 9:51 pm
- CXCommuter
Postby CXCommuter » Thu Nov 13, 2014 11:05 pm
I am the exact opposite- used to ride with 44's- kept on tearing muscles in my mid back and getting a sore neck (caveat- I have an old whiplash injury with very, very tight facet joints in my neck), tried 40's at the LBS's recommendations- didn't resolve the issues but definitely helps, also doesn't slow me down. Biggest issue is the lack of usable real estate on the tops.rodneycc wrote:Unless you are a beanpole with no shoulders I wouldn't go there with the 40cm bars. I have 40cm bars on one of my bikes (42cm and 44cm on the others) and I ride a lot with heavy backpacks and find the 42s are fine but the 40 I get stiffness in the neck and shoulders. Its taken me ages to narrow the soreness down to the bars after thinking it was initially a frame size/geo issue and then a stem size issue but the latest theory is the bar size after a number of changes.
My new TCR has 42cm bars on it and I must say I prefer them to both the 40 and 44's, mainly due to being less stress on my back/neck (compared to 44s) but having more leverage and useable real estate than the 40's
Postby warthog1 » Fri Nov 14, 2014 11:28 am
3T ergonova team on the roadie and same shape but alloy on the commuter. They are 40cm c-c at the hoods but splay out to 42cm c-c at the drops = perfect for me. Best bars I've used
Postby fixedlegs2012 » Thu Nov 20, 2014 7:46 am
- m@
Postby m@ » Thu Nov 20, 2014 10:03 am
Whoa - want those ones!warthog1 wrote:
- ni78ck
Postby ni78ck » Thu Nov 20, 2014 3:59 pm
they have a big flare out and are super stiff.
Cervelo S5 VWD - dura ace Di2
- Xplora
Postby Xplora » Thu Nov 20, 2014 6:26 pm
- ldrcycles
Postby ldrcycles » Fri Nov 21, 2014 6:59 am
I've got FSA bars and ride like that all the time. Started off with 44cm bars because they were supposed to be the "correct" size for me, now much happier on 42s and i'll try 40s when i get a chance.Xplora wrote:Not digging the new school bar - traditional bend allows you to rest on the bars doing the TT by The Horns trick.
- rodneycc
Postby rodneycc » Mon Nov 24, 2014 12:23 pm
These at Bikebug are the cheapest around I've seen in a while...Xplora wrote:Not digging the new school bar - traditional bend allows you to rest on the bars doing the TT by The Horns trick. I think it's just about time to pony up some cash and give the 40cm rotundo a crack.
http://www.bikebug.com/3t-rotundo-team- ... -5707.html" onclick="window.open(this.href);return false;
- Xplora
Postby Xplora » Tue Nov 25, 2014 5:28 pm
- toolonglegs
Narrow handlebars?
Postby toolonglegs » Tue Nov 25, 2014 6:06 pm
- Strawburger
Postby Strawburger » Tue Nov 25, 2014 6:27 pm
Im a small guy so the width is roughly my shoulder width (and hip width too )
- mikesbytes
Postby mikesbytes » Tue Nov 25, 2014 8:26 pm
Good question, it made me think. I'm assuming that aero is from the arms being aligned with your torso, not your shoulders as your arms are at the same height as the torso, which is lower than the shouldersmitchy_ wrote:if your shoulders are wider than the bars, i fail to see how you'll be more aero?
Postby CKinnard » Tue Nov 25, 2014 8:51 pm
I agree with Derny and TLL on this. You'll only know when you try.
If you are not regularly out of the saddle sprinting, or climbing up 8+% hills, then there's no real need to stick to 44cm.
I think from a safety pov, narrower bars offer a hell of a lot of advantage. I've seen crashes on commute paths that would have been avoided with narrower bars....and same++ in races. You can get through gaps a lot safer too with narrow bars.
As for aero advantage, focus on getting a lower back angle. But be weary of iliac artery endofibrosus.
http://cyclingtips.com.au/2011/11/exerc ... ofibrosis/" onclick="window.open(this.href);return false;
http://sportsmedicine.about.com/od/bicy ... opathy.htm" onclick="window.open(this.href);return false;
- Xplora
Postby Xplora » Tue Nov 25, 2014 9:18 pm
