Bicycle warning horns
- il padrone
Postby il padrone » Sat Dec 06, 2014 2:35 pm
- il padrone
Re: Bicycle warning horns
Postby il padrone » Sat Dec 06, 2014 2:44 pm
http://www.orpland.com/" onclick="window.open(this.href);return false;
- yugyug
Postby yugyug » Sat Dec 06, 2014 3:07 pm
- wombatK
Postby wombatK » Sat Dec 06, 2014 7:24 pm
And that's exactly what an Air Zound does, for about half the cost of the first one, and a fraction of the weight.yugyug wrote:Like the sound of the first one. Seems reasonable to be using a sound drivers are habituated to.
23 ounces (0.65 kg), no thanks.
- il padrone
Postby il padrone » Sat Dec 06, 2014 7:29 pm
Gotta disagree with that view on two points:wombatK wrote:And that's exactly what an Air Zound does, for about half the cost of the first one, and a fraction of the weight.yugyug wrote:Like the sound of the first one. Seems reasonable to be using a sound drivers are habituated to.
1. Airzound has just one tone. The two tones of this Loudbicycle is what gives it a real car-horn sound;
2. Airzound runs out of air pretty quick after a few days of use. The Loudbicycle claims a battery charge that will last 1-2 months.
- ldrcycles
Postby ldrcycles » Sat Dec 06, 2014 7:36 pm
- il padrone
Postby il padrone » Sun Dec 07, 2014 10:29 am
Hardly worth the breath to argue then, eh?Oxford wrote:I haven't listened to these horns of these threads,
- il padrone
Postby il padrone » Sun Dec 07, 2014 12:29 pm
You commented:Oxford wrote:And if you read my post, I made no specific comment on the horns the subject of the thread, in fact I made it clear that I had not even heard them, you even quoted me, so what your point is I have no idea.
The Loudbicycle horn is just that, a two-tone horn, just like a car horn, what distinguishes it from most bike horns (including the Airzound). Like I hinted at, good to listen to the sound first. That's why I put up the video, rather than just a photo.Oxford wrote:I haven't listened to these horns of these threads, but if you want something that people will notice, you need something that plays an out of tune chord. Harmonious in tune chords sound pleasant (3 notes), one with an out of tune note sounds terrible and will catch peoples attention for this reason.
- il padrone
Postby il padrone » Sun Dec 07, 2014 2:08 pm
- wombatK
Postby wombatK » Sun Dec 07, 2014 5:16 pm
I had listened to it, but still think it's not a better solution than the airzound. The Airzound is loud enough and sufficiently like a truckil padrone wrote: The Loudbicycle horn is just that, a two-tone horn, just like a car horn, what distinguishes it from most bike horns (including the Airzound). Like I hinted at, good to listen to the sound first. That's why I put up the video, rather than just a photo.
air horn in sound that the lack of a second tone really doesn't matter. Drive by ear drivers and iPodded pedestrians hear it and react.
It would be nice to have something that was smaller, just as light, and less dependent on regular pumping up. There have been
other attempts at 2-tone car-like horns (google galeforce), but it looks like they didn't last long on the market. The heavy kickstarter
thing will go the same way I suspect.
- g-boaf
Postby g-boaf » Sun Dec 07, 2014 5:52 pm
Even out of breath I can still be pretty loud if needed.fat and old wrote:Whats wrong with yelling?
The first one seems good - but I doubt it will fit on the very chunky frames that all of my bikes have.
Postby fat and old » Sun Dec 07, 2014 6:00 pm
Well that's good, because if I'm at the yelling stage, things are not going well and I've never had trouble finding the breath...Oxford wrote:Hard to do when you're out of breath, or breathing in after just expelling your lungs. Also I have found that you're voice cannot penetrate in the same way an airhorn can, its just another noise whereas an airhorn or possibly this kickstarter horn sound like a horn which has a distinct purpose that people understand. You hear an airhorn you know something is going down, you hear yelling, its just white noise. No different to people saying they prefer to call out to people on shared pathways rather than use a bell. A bell has a specific meaning that most understand, talk and its just white noise. In my very short commute to work, hopefully shorter sooner my bell works just fine, every person I encounter understands and appreciates it. Yelling sounds like abuse and is often rightly taken as such by the recipient.fat and old wrote:Whats wrong with yelling?
TBH, those horns seem pretty abusive to me anyway. And potentially dangerous.
Postby fat and old » Sun Dec 07, 2014 6:24 pm
The potentially dangerous comment was with regards to using them on peds, or on vehicles in some situations.
Each to their own, you like them, go nuts
- il padrone
Postby il padrone » Sun Dec 07, 2014 7:59 pm
Such horns are designed for on-road use (where this sort of thing is the standard for warnings), not for blasting pedestrians on the bike paths (where it would be regarded as abusive).fat and old wrote:TBH, those horns seem pretty abusive to me anyway. And potentially dangerous.
Not quite sure how you could regard a horn as "dangerous" however
Postby RedlandSteve » Sun Dec 07, 2014 8:39 pm
- il padrone
Postby il padrone » Sun Dec 07, 2014 8:54 pm
I did the same, for much the same reason - plus it took away a bidon cage, and required removal and transport when the bike was parked for longer time periods.RedlandSteve wrote:I put away my AZ. I found it split my attention away from just immediately evading the hazard. Its use just never came naturally for me.
Postby Top_Bhoy » Sun Dec 07, 2014 11:07 pm
+1RedlandSteve wrote:I put away my AZ. I found it split my attention away from just immediately evading the hazard. Its use just never came naturally for me.
...noting that I also found it created a hazard by scaring pedestrians not attuned to recognising them thus causing peds to jump into my path in panic.
Postby jasonc » Mon Dec 08, 2014 10:11 am
Steve - I'll grab it off you if you don't want it any more. mine stopped working after a few crashes....RedlandSteve wrote:I put away my AZ. I found it split my attention away from just immediately evading the hazard. Its use just never came naturally for me.
Postby RedlandSteve » Mon Dec 08, 2014 1:24 pm
Going to hang onto it in case I have a change of heart. If I can think of a better place to mount it where I do not have to split attention to use I may put it back on again. Also, the plastic mount clip fatigued and broke after some UV exposure, had to dodgy up with some cable ties to secure it back onto my flat handlebars.jasonc wrote:Steve - I'll grab it off you if you don't want it any more. mine stopped working after a few crashes....
Postby jasonc » Mon Dec 08, 2014 1:25 pm
Postby jasonc » Mon Dec 08, 2014 2:38 pm
