Phone mount for handlebars
Postby alexmcm09 » Tue Dec 16, 2014 4:12 pm
https://www.kogan.com/au/buy/universal- ... cle-mount/" onclick="window.open(this.href);return false;
Re: Phone mount for handlebars
Postby tcdev » Tue Dec 16, 2014 4:49 pm
I haven't, sorry. But I did buy an el-cheapo window mount for my phone and it bounces around like it's on a spring. If you decide to gamble on it, let us know!
2011 Schwinn Sporterra Comp
2021 Giant Contend AR1
Postby lard » Tue Dec 16, 2014 4:59 pm
http://getfinn.com/" onclick="window.open(this.href);return false;
It looks a lot better than the plastic clamp things. It hasn't arrived yet but I'll give a report after I give it a few test rides.
Postby tcdev » Tue Dec 16, 2014 5:12 pm
Postby lard » Tue Dec 16, 2014 6:49 pm
The Finn looks like a better design as it provides some padding between the phone and the bar, and also wraps around just the corners instead of straight across the screen making using the phone on the bar much harder.tcdev wrote:I wonder how it compares to the AUD$1 (shipped) versions on Ebay?
$1 is great, but to keep a $500 phone safe, I don't mind paying a little more.
Postby mick243 » Tue Dec 16, 2014 6:55 pm
Postby irrelevant_apple » Tue Dec 16, 2014 7:18 pm
what several? Of the two I've used; a galaxy nexus and a xperia z3 compact that hasn't happenedmick243 wrote:I tried several, common theme was phone overheating and shutting down
Postby tcdev » Tue Dec 16, 2014 8:06 pm
I'm guessing they were iPhones...mick243 wrote:I tried several, common theme was phone overheating and shutting down
In any case, the Finn (or cheap knock-offs) are very unlikely to cause overheating.
- KGB
Postby KGB » Tue Dec 16, 2014 9:07 pm
What about the Quad Lock?
Postby tcdev » Tue Dec 16, 2014 11:11 pm
I was thinking it was more likely a weather proof case, with no ventilation for generated heat to escape. A recipe for disaster, particularly with bleeding-edge technology pushed to its operating limits.KGB wrote:I assume the overheating was from constantly being in the sun?
Postby mick243 » Wed Dec 17, 2014 12:07 am
And yes, direct sunlight was the culprit, even on nice days....
- m@
Postby m@ » Wed Dec 17, 2014 10:24 am
Postby brensurfer » Thu Dec 18, 2014 5:57 pm
Postby irrelevant_apple » Mon Dec 22, 2014 9:33 pm
The underside plate connection is detachable but wears down due to shocks so super glue or bolts as I have used are required to securely fix it. A silicone strap that doesn't really wear down is cut out of those cheap bandage mounts on ebay and looped around one of the arms once for enough tightness. I note that the clamp arms are prone to becoming loose from inside malfunction, so I'm going to try not overclamping relying on the tight silicone strap and seeing if the arms last that way.
20141222_213830 by irrelevant_apple, on Flickr
20141222_222523 by irrelevant_apple, on Flickr
20141222_215147 by irrelevant_apple, on Flickr
20141222_215117 by irrelevant_apple, on Flickr
20141222_193438 by irrelevant_apple, on Flickr
20141222_193642 by irrelevant_apple, on Flickr
Postby qranked » Thu Jan 01, 2015 2:29 am
Postby irrelevant_apple » Thu Jan 01, 2015 4:37 pm
yeah but their plastic is another layer of poor reflectivenessqranked wrote:I have the zip-in type with clear window. Great if you use GPS but don't need to touch the phone much. Phone will never fall and it's waterproof. I believe they're $5 on ebay?
- bychosis
Postby bychosis » Thu Jan 01, 2015 9:43 pm
Postby qranked » Fri Jan 02, 2015 4:22 am
It's not bad tbh. But I have a windows phone and the screen has sunlight mode so I don't suffer any visibility problems. I'd take that tradeoff for waterproofability anyday.irrelevant_apple wrote:yeah but their plastic is another layer of poor reflectivenessqranked wrote:I have the zip-in type with clear window. Great if you use GPS but don't need to touch the phone much. Phone will never fall and it's waterproof. I believe they're $5 on ebay?
Users browsing this forum: Amazon [Bot]
