Which Puncture Patches?
- TonyMax
Postby TonyMax » Sat Mar 21, 2015 2:42 pm
Should I look for self adhesive ones or the ones that use glue?
I'm thinking buying in bulk from eBay would be the way to go?
Tony
Re: Which Puncture Patches?
Postby GAV!N » Sat Mar 21, 2015 3:03 pm
- queequeg
Postby queequeg » Sat Mar 21, 2015 3:15 pm
- biker jk
Postby biker jk » Sat Mar 21, 2015 3:28 pm
- trailgumby
Postby trailgumby » Sat Mar 21, 2015 4:55 pm
Standard cheapo self-vulcanising patches with rubber glue work best.
- Storm Boy
Postby Storm Boy » Sat Mar 21, 2015 5:18 pm
Regards
SB
- bychosis
Postby bychosis » Sat Mar 21, 2015 5:26 pm
Postby defy1 » Sat Mar 21, 2015 6:21 pm
- bychosis
Postby bychosis » Sat Mar 21, 2015 7:05 pm
- Derny Driver
Postby Derny Driver » Sat Mar 21, 2015 7:13 pm
Better than getting let down by failed patches at the most inopportune times.
For all the effort patching old tubes, only to have it fail coming down a hill or on an unlit road at night ...
Patches are a fools game ...you wont win.
- queequeg
Postby queequeg » Sat Mar 21, 2015 8:18 pm
Postby defy1 » Sat Mar 21, 2015 10:34 pm
Plus its better for the environment.
- Derny Driver
Postby Derny Driver » Sat Mar 21, 2015 10:37 pm
- trailgumby
Postby trailgumby » Sat Mar 21, 2015 10:46 pm
+1defy1 wrote:imho a properly patched tube is a good as a new.
Sounds like you've had a bad off from a failure. I can definitely sympathise with your position.Derny Driver wrote:Ive had bad patch experiences and have been mentally scarred by them.
I've had failures with cheap tubes. Fortunately, caught before I got into an awkward situation.
- il padrone
Postby il padrone » Sat Mar 21, 2015 11:12 pm
From Wikipedia,bychosis wrote:Not sure, but my understanding is that the modern patch kits aren't technically a vulcanising patch, but a chemical bond using adhesive. Vulcanising patches used to use flame/heat to bond the patch to the tube. modern patching is just as effective, a whole lot safer but not actually vulcanising as I understand it. Vulcanising is the process of hardening natural rubber to a usable product. /pedant
Some more interesting info on different cement types here:Rubber cement is simply a mixture of solid rubber in a volatile solvent that will dissolve it. When the cement is applied, the solvent evaporates, leaving the rubber as the adhesive. Almost any rubber (pre-vulcanized or not) can be used. [1] The rubbers used might be natural rubber, gum mastic or gum arabic. Early solvents used included chloroform and benzene. [2] In the United States of America, current formulations include n-heptane. In the UK, a product called Marabu-Fixogum uses acetone.
Special compositions[edit]
Many compositions have included hardeners and/or vulcanizing agents designed to improve the cohesion of the rubber.
http://www.patchrubber.com/tire_repair/ ... _heat.html" onclick="window.open(this.href);return false;
http://bicycles.stackexchange.com/quest ... n-i-buy-it" onclick="window.open(this.href);return false;
Postby tcdev » Sat Mar 21, 2015 11:20 pm
For emergencies I carry a spare tube and the self-adhesive patches, the latter of which I've yet to use (touch wood).
2011 Schwinn Sporterra Comp
2021 Giant Contend AR1
- Bentnose
Postby Bentnose » Sun Mar 22, 2015 7:31 am
- beanspropulsion
Postby beanspropulsion » Sun Mar 22, 2015 7:38 am
Common error with proper rubber patches is that people forget to rough up the surface of the tube with sandpaper or the little metal file before applying glue.
Also glue on both patch and tube and let dry for a minute or as I do blow on the glue until it is no longer clear.
I also bought a big tube of rubber cement from the auto shop, it is better than those little tubes.
- Bentnose
Postby Bentnose » Sun Mar 22, 2015 8:07 am
- beanspropulsion
Postby beanspropulsion » Sun Mar 22, 2015 8:28 am
Don't use the self glues patches, they perish after a time.Bentnose wrote:Haven't heard of gluing the patch
Get the proper rubber patches in the little kit.
Postby warthog1 » Sun Mar 22, 2015 11:53 am
+1queequeg wrote:A tube is $5, a patch is about 10c. Unless the tube is really shredded, why not patch?
I've picked up a number of discarded tubes over the years and patched them, all good.
Never had a rapid failure of a patch. I've had the rare occasional slow leak is all.
Postby warthog1 » Sun Mar 22, 2015 11:55 am
Good tip, thanksbeanspropulsion wrote:.
- apsilon
Postby apsilon » Sun Mar 22, 2015 12:59 pm
EDIT: actually, all of mine have also been lower pressure MTB or commuter. Not a high pressure road bike tube. Maybe that's the difference?
Postby eeksll » Sun Mar 22, 2015 6:01 pm
the stick on patch for the tube never failed and lasted at least 1 year.
- isabella24
Postby isabella24 » Sun Mar 22, 2015 7:57 pm
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
