cycling safety for side view
Postby commuterbiker » Mon Mar 30, 2015 2:19 pm
Re: cycling safety for side view
Postby peanutz » Mon Mar 30, 2015 4:07 pm
- bychosis
Postby bychosis » Mon Mar 30, 2015 4:13 pm
- casual_cyclist
Postby casual_cyclist » Mon Mar 30, 2015 4:23 pm
I have these, but I have not used them yet.
http://www.aliexpress.com/item/Fashion- ... 6.html?s=p" onclick="window.open(this.href);return false;
Also, mine were under $2 each.
- Mulger bill
Postby Mulger bill » Mon Mar 30, 2015 7:18 pm
Cut the tip off a plastic Presta cap and epoxy it into the Schraeder cap...casual_cyclist wrote:Just watch the valve caps. I can only find them for schrader valves, not presta valves.
- casual_cyclist
Postby casual_cyclist » Mon Mar 30, 2015 7:22 pm
Mulger bill wrote:Cut the tip off a plastic Presta cap and epoxy it into the Schraeder cap...casual_cyclist wrote:Just watch the valve caps. I can only find them for schrader valves, not presta valves.
I meant the valve lights.
but disregard anyway,
$1.63 from AmazonQ: What type of Valve stems do these lights fit on? For example, schrader or presta or both?(This way I'll know if I need to get adapters for what I currently have on bike valves).
A: Shrader or Presta. They come with a little screw-on adapter for Presta valves.
http://www.amazon.com/World-Pride-Bicyc ... B007NEDEWW" onclick="window.open(this.href);return false;
- kx315
Postby kx315 » Mon Mar 30, 2015 8:50 pm
2013 Giant Defy Advanced 0
2016 Giant TCR Advanced Pro 0
- Storm Boy
Postby Storm Boy » Mon Mar 30, 2015 9:06 pm
Reflectors/reflective tape generally only reflect light back in the direction from which it came, so shining a light on it from the bike with the intent of lighting it up will not be effective. The 3M tape is very effective in most circumstances.
Regards,
SB
- find_bruce
- Moderator
Postby find_bruce » Mon Mar 30, 2015 11:04 pm
While I use 3m reflective tape, I have bright lights front and rear with very good side visibility, ie I use a diffuser like this
which gives 180 degrees visibility.
Same thing, done by Mulger Bill
Mulger bill wrote:
Side view from about 15m away...
Postby cp123 » Tue Mar 31, 2015 10:08 am
- MattyK
Postby MattyK » Tue Mar 31, 2015 4:39 pm
http://www.monkeylectric.com/" onclick="window.open(this.href);return false;
Postby gabrielle260 » Tue Mar 31, 2015 6:43 pm
But have you seen what they cost? I almost fell off the chair... Over $1,000 USD each!!!!MattyK wrote:Have seen a bike with these once, and boy do they stand out!
- apsilon
Postby apsilon » Tue Mar 31, 2015 7:02 pm
I think you've added an extra zero. I was looking at them and similar products recently. The base model is about US$40 and the top end US$60gabrielle260 wrote:But have you seen what they cost? I almost fell off the chair... Over $1,000 USD each!!!!
Postby gabrielle260 » Tue Mar 31, 2015 9:59 pm
I'm looking at the pre order of the monkey light pro. The price for outside the U.S. is USD1,075 for 1 light or USD995 with US shipping.apsilon wrote:I think you've added an extra zero. I was looking at them and similar products recently. The base model is about US$40 and the top end US$60gabrielle260 wrote:But have you seen what they cost? I almost fell off the chair... Over $1,000 USD each!!!!
They must be bloody good!
- apsilon
Postby apsilon » Tue Mar 31, 2015 10:24 pm
From a safety POV, the basic model will do the job. Use the other US$950 for something else.
- Bunged Knee
Postby Bunged Knee » Tue Mar 31, 2015 10:35 pm
You can make any messages in it.
- Thoglette
Postby Thoglette » Wed Apr 01, 2015 2:55 am
Wheel reflectors. Old, daggy even. But effective.commuterbiker wrote:any suggestions?
Either solid or material (see rivendell's ones)
Then add wide-angle, low intensity lighting. Per Mulger Bill's suggestion. The joy of old fashioned lights was that they didn't form tight beams - rather they leaked light everywhere, including on you
- queequeg
Postby queequeg » Wed Apr 01, 2015 8:30 am
No reflectors at all, but the tyres include a reflective strip. Just as effective.
- MattyK
Postby MattyK » Wed Apr 01, 2015 9:03 am
Indeed; I haven't seen the full image ones, just the cheaper models. Still extremely colourful and visible.apsilon wrote:I think you've added an extra zero. I was looking at them and similar products recently. The base model is about US$40 and the top end US$60gabrielle260 wrote:But have you seen what they cost? I almost fell off the chair... Over $1,000 USD each!!!!
On my commuter I run reflective tyres and these spoke reflectors (12 on each wheel). Very visible, but only when I'm being lit by someone.
Another idea I've seen is to wrap a knog light around your hub.
Or there are these spoke lights: http://www.this link is broken/au/e ... -prod64511" onclick="window.open(this.href);return false;
Postby caneye » Wed Apr 01, 2015 10:05 am
http://fibreflare.com/" onclick="window.open(this.href);return false;
I am going to use a tyre valve LED light. bought a whole bunch of them online for a cheap price. It fits my presta valve tyres. There's a plastic cap provided that fits between the LED light and the presta valve.
- kb
Postby kb » Wed Apr 01, 2015 10:24 am
Postby ball bearing » Wed Apr 01, 2015 10:28 am
Designshine. Expensive, but effective.
- il padrone
Postby il padrone » Sat Apr 04, 2015 1:36 pm
Users browsing this forum: Google Feedfetcher
