So is that something I should be worried about? What would be the solution?Duck! wrote: That's the customary FSA headset sqeak. There's a rubber seal under the conical outer bearing cover above the headset, and it's very common for it to squeak as it rubs on the rim of the headtube. Happens to nearly all of them.
I am thinking of sending it back to the LBS for them to fix it.
